997 : 2004- 76
996 : 1997-2005 42
993 : 1993-1998 9
964 : 1989-1993 6
Classic : 1950-1965 1
Boxster : 1997- 10
Cayenne : 2003- 7
Rioja996TT
PostPosted: Thu Feb 08, 2018 9:58 am    Post subject: C4S front splitter on 996 Turbo Reply with quote
Having just cracked another turbo front splitter, I am balking at paying out £280 for a strip of polyurethane. I note that the C4S splitter has a higher centre section and would thus be far more urban friendly at considerably lower cost. Any downsides to such a replacement? Thanks.
kas750
Estoril
2006 Porsche 911
PostPosted: Thu Feb 08, 2018 10:02 am    Post subject: Reply with quote
Only from an anoraks point of view.
The reality is you will still probably bash the c4s part!
4b4
PostPosted: Thu Feb 08, 2018 11:00 am    Post subject: Reply with quote
Sooo true nooo
2004 996.2 C4S Cabrio Tip in Arctic Silver
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Thu Feb 08, 2018 1:11 pm    Post subject: Reply with quote
The anorak in me also worries that the turbo one is different shaped for a reason, maybe to counteract lift from the bigger rear wing.
I have found that having graunched mine on a steep driveway, sanding it down with fine sandpaper then a coat of plastic conditioner got it looking much, much better.
galahad
PostPosted: Thu Feb 08, 2018 5:22 pm    Post subject: Reply with quote
I believe that is true, but unless you regularly drive at 120+ on the Autobahn I really doubt you'll notice the difference. I do recall reading that the C4S one was so shaped so as to reduce front lift reduction to match the non turbo rear wing.
2003 C4S Black/Black Manual
Sen
PostPosted: Sat Feb 10, 2018 6:18 pm    Post subject: Reply with quote
I was going through about two a year, so fitted the C4S splitter.
Don't seem to ground it as often as turbo one.
Car seems planted at 140.
Basalt 996 Turbo
Previous: Boxster 3.2S, 911SC Sport.
Bund
PostPosted: Sun Feb 11, 2018 8:47 am    Post subject: Reply with quote
I changed mine to the C4s splitter purely because I think it looks nicer.
You will not notice a difference.
Audi B7 RS4 avant, Mercedes W124 E320 Sportline cabriolet, Mercedes 560 SEC, Caterham R300S race car, Caterham Supersport 1600 Race car, Toyota LJ70 Land Cruiser, JCB telehandler
