996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Tue Feb 06, 2018 4:05 pm    Post subject: Radiator fan needed... non OE OK? Reply with quote
It turns out one of the radiator fans (not the resistor) has failed on my 4S, so I need to replace it.
An OE one from D911 is over £400, but Euro Car Parts have an H Tech branded one for £200, carparts4less have the same for £108, that's quite a saving...
Anyone tried a non OE fan?
crash7
PostPosted: Tue Feb 06, 2018 4:38 pm    Post subject: Reply with quote
If you go OE, get a price from your OPC, it will be cheaper than D911
Euro & Car Parts 4 less are the same company
Thefinn
PostPosted: Tue Feb 06, 2018 4:56 pm    Post subject: Reply with quote
If you go down the ecp or cp4l route create an account and they will send you money off emails every week, normally at the weekend which are sometime better than the ones they have on the site.
If you don't want to make an account you can also always use this "cp15less" discount code for anything over £100 and it gives you £15 off, over £75 cp10less give £10 off and over £50 cp5less £5 off and these always seem to work.
997.1 C4S CAB
PostPosted: Tue Feb 06, 2018 7:31 pm    Post subject: Reply with quote
Something like a fan is fine to use non OEM parts for .
Porsche dont actually make many parts they get other companys to make them so it may turn out to be the same manufactuor !
Robertb
PostPosted: Tue Feb 06, 2018 8:49 pm    Post subject: Reply with quote
Brilliant, thanks guys. Will order up the cheapo one with the discount codes above.
thumbsup
Supplementary question @ Demort... can I change it from the wheelarch side, or do I need to remove the front PU etc?
PostPosted: Wed Feb 07, 2018 7:25 pm    Post subject: Reply with quote
By all means have a go from the wheel arch area but im pretty sure you will end up removeing the PU and the radiator bracket to be able to replace it .
Ive only ever replaced radiators im afraid and the fan is removed from the Rad after it has been removed to swop over .
wasz
1999 Porsche 996 Carrera 2
PostPosted: Wed Feb 07, 2018 8:28 pm    Post subject: Reply with quote
The bumper isn't had to remove and replace at all.
Well worth cleaning out the rads and fitting mesh while its off.
lethallegend72
PostPosted: Wed Feb 07, 2018 9:28 pm    Post subject: Reply with quote
I think I have a spare one in the garage - I just need to make sure I didn’t bin it during my last clear out.... the resistor is broken though. You can have it if it is still there.. I am in Oxford if you are able to pick it up and you haven’t ordered a replacement already.. (it is used)
I bought it off eBay from a breakers a few years ago but the resistor was faulty..
I don’t think it is handed..
Robertb
PostPosted: Thu Feb 08, 2018 2:18 pm    Post subject: Reply with quote
That's very kind... having looked, a new resistor (I could risk splicing the existing one in on the basis that it is the fan that's failed, the resistor may be ok, or not) is nearly as much as a whole fan from CP4Less, so I'll run with the new one. Thanks for the offer though, much appreciated. thumbsup
wasz
PostPosted: Thu Feb 08, 2018 2:29 pm    Post subject: Reply with quote
You just unplug your resistor and fit to the new part. a new fan won't come with a resistor.
Suitable resistors are like £12 a pair from RS Components, solder them up yourself rather than pay Porsche tax.
Robertb
PostPosted: Thu Feb 08, 2018 2:38 pm    Post subject: Reply with quote
Ah, maybe I'm confused... isn't the resistor the long component on the bottom right of this pic?
https://www.eurocarparts.com/search/213330091?gclid=EAIaIQobChMIlYXw2MSW2QIVS7vtCh1uNQFzEAQYAiABEgIR4vD_BwE
wasz
PostPosted: Thu Feb 08, 2018 5:14 pm    Post subject: Reply with quote
You are correct - my mistake.
They do list the resistor as a separate part. I would check to confirm its included! Although probably quicker to buy it as you need one anyway.
I soldered new resistors into mine.
Robertb
PostPosted: Fri Feb 09, 2018 3:16 pm    Post subject: Reply with quote
Fair point... I will check the resistor is included when I order.
pooga
PostPosted: Sat Feb 24, 2018 3:32 pm    Post subject: Re: Radiator fan needed... non OE OK? Reply with quote
Robertb,
Do you have the part no from Euro car parts / carparts4less as the one for 4S - partno 213330120 is over £500 on ECP (£362 with current discount) and £300 CP4L (£259 with current discount)
I can not find the H Tech on both sites for 4S - the only H Tech i can find part no 213330091 is non-4S. is this the one you went for and did you have any problems fitting to 4S?
Robertb
PostPosted: Sat Feb 24, 2018 8:07 pm    Post subject: Reply with quote
Hi, I haven't got round to ordering of fitting it yet... I must confess I was not aware that there was a distinction.
I was just going to run with the one that came up on ECP from my reg no.
I'd be very interested to know if this is wrong, cheers for the heads up... sorry I can't be any help!
MMT
PostPosted: Sat Feb 24, 2018 11:57 pm    Post subject: Re: Radiator fan needed... non OE OK? Reply with quote
Robertb,
Are they different for the 4s?
Looking at this they look like the same part numbers I think.
 Filesize:  171.69 KB
 Viewed:  2016 Time(s)
MMT
PostPosted: Sun Feb 25, 2018 12:09 am    Post subject: Reply with quote
Genuine Porsche 911 996/986 Boxster Radiator Cooling Fan 99662413500 NOS https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F162740172152
pooga
PostPosted: Sun Feb 25, 2018 2:00 am    Post subject: Re: Radiator fan needed... non OE OK? Reply with quote
removing duplicate post
pooga
pooga
PostPosted: Sun Feb 25, 2018 2:01 am    Post subject: Re: Radiator fan needed... non OE OK? Reply with quote
Robertb,
Looking at the parts listing they are different
99662412700 - 4S
99662413500 - Non-4S
not sure if the fans are the same and interchangeable - but the connection + resistor are different
part no
 Filesize:  8.88 KB
 Viewed:  1983 Time(s)
