996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
neil_911
PostPosted: Sat Feb 03, 2018 11:35 am    Post subject: Coilpack heat shields Reply with quote
Alright Lads,
Anyone know where you can get 997.2 coil pack heat shields from or is an OPC the only option?
If so has anyone got a part number (for both) to make ordering easier?
I had a quick look on Teile, design911 etc but can't find anything unless i'm looking in the wrong categories.
I had an advisory at last service, having my exhaust replaced for a custom one so seized the opportunity to replace all plugs, packs and heatshields!
Cheers in advance.
Basalt Black 997.2 C2S PDK - for the weekends
Mercedes S500 5.0L V8 - for the commute
PostPosted: Sat Feb 03, 2018 11:50 am    Post subject: Reply with quote
mate , they are only about £16 each from the OPC so not worth looking around
they are not avail as an aftermarket stainless steel option sadly ( a trick missed )
neil_911
PostPosted: Sat Feb 03, 2018 11:53 am    Post subject: Reply with quote
Cheers Phil,
Yeah i knew they weren't expensive but was hoping i could order some from the comfort of my sofa Laughing
Steve997
PostPosted: Sat Feb 03, 2018 2:04 pm    Post subject: Reply with quote
Just fitt3d some on mine. Cheap at 16 from design911.
If you can't find them online maybe call them.
monster
PostPosted: Sat Feb 03, 2018 3:30 pm    Post subject: Reply with quote
Also, they are the same part number for both left and right sides, one is just a reverse of the other when fitting- which is a bit of cost cutting evidence methinks as one fits better than the other!
Thefinn
PostPosted: Sat Feb 03, 2018 4:32 pm    Post subject: Reply with quote
you could try these as well which are supposed to last longer.
https://alternativecarparts.co.uk/shop/997-porsche/heat-shield-spark-plug-covers-997-c2-and-c4/
997.1 C4S CAB
rhino-man
PostPosted: Sat Feb 03, 2018 4:36 pm    Post subject: Reply with quote
I always use this site for general pricing/oem part numbers
https://www.deroure.com/
2010 997.2 C4S
2001 996 C2 Convertible
neil_911
PostPosted: Tue Feb 13, 2018 10:13 am    Post subject: Reply with quote
Cheers for the links guys and help.
I've ordered from porsche in the end. For reference theres 4 in total, upper and lower and they are sided, not the same part number.
I think this is more a gen 2 997 thing as gen 1's do look the same left to right.
£13 each, and 30p for bolts (x12).
I'll post the part numbers when i get my invoice so anyone searching in the future knows the score!
wasz
1999 Porsche 996 Carrera 2
PostPosted: Tue Feb 13, 2018 10:41 am    Post subject: Reply with quote
Always always ask for a discount at OPC
Usually only 10%, but a free pint is a free pint.
neil_911
PostPosted: Tue Feb 20, 2018 7:12 pm    Post subject: Reply with quote
Yeah i get 10% super car drivers discount at my local OPC so all good!
Got them changed yesterday.
Part numbers for anyone else searching....
P9A1.104.307.04
P9A1.104.308.05
P9A1.104.309.04
P6A1.104.310.04
and 12 torx screws P/N P900.385.041.01
Fiddly job changing all the plugs and coil packs, i had to drop the manifolds. But it wasn't that big a drama.
