997 : 2004- 61
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
coullstar
PostPosted: Fri Dec 20, 2019 11:25 am    Post subject: Reply with quote
Good progress. This is going to sound nuts!!
Rosselder83
PostPosted: Fri Dec 20, 2019 12:03 pm    Post subject: Reply with quote
NedHan79 wrote:
Great stuff. Can you not go with the itb’s separately and use an aftermarket Ecu from the likes of motec or link? I think there’s cheaper options as well. The main problem with going stand alone brains are that you loose all of the factory things like limp mode and whatever else. I don’t think it’d be a major issue to a good mapper though. You don’t have boost your worry about blowing it to bits so how bad can it be?
If you used something mega advanced like a Haltech ECU it will probably have more engine protection capabilities than the OEM Porsche Ecu. Ecu technology has come along way since the 996 graced our roads
wasz
1999 Porsche 996 Carrera 2
PostPosted: Fri Dec 20, 2019 12:49 pm    Post subject: Reply with quote
Great stuff!
I'm collecting the bits to run bike ITBs on a Ford Pinto 2.0 in a kit car I inherited.
I'm going to run speeduino open source ECU.
Much simpler engine, no variocam for a start although speeduino could run that.
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Fri Dec 20, 2019 12:53 pm    Post subject: Reply with quote
The standard ECU might well run the ITBs, but it is a compromise between spending a lot of money on getting the standard ECU doibg the job or a quicker and easier tune with an aftermarket one. We intend to try both if possible, the aftermarket choice is the Syvecs S8, I have one ready to go on, it is the same as I run on my turbo. A very capable ECU.
NedHan79
PostPosted: Fri Dec 20, 2019 4:03 pm    Post subject: Reply with quote
The syvecs gets a very good rating in the subaru world, but then again if you have it in your turbo you’ll know what your up against.
I used a Simtek in the p1. Not really for road use but it did the job. My mapper spent ages just trying to get it to idle and then it was out in the road to scale everything. I bought it second hand from a race car. The guy had 2 stages of anti lag mapped in on the side lights and dip beam. That was interesting when we found that out Floor
#modified996mk1
skinny_monkey
PostPosted: Sat Dec 21, 2019 6:45 am    Post subject: Reply with quote
I'd be amazed if the stock ECU could run ITB's. How will it know MAF (unless you're feeding the TB's with a big sealed manifold / collector).
Could potentially run with some kind of piggy back but Think it would be much easier just to go standalone - then the capability I'd all there and you'd just need to do the mapping (which presumably you'd have to do on the stock ECU too - can probably carry over the spark map tho to get you going?)
MisterCorn
PostPosted: Mon Jan 13, 2020 11:38 am    Post subject: Reply with quote
It will be fed from a central plenum, so there is the option to run a MAF if we want to. That is the next part to design.
V2 of the intake manifold has arrived and fits perfectly Smile
MisterCorn
PostPosted: Mon Jan 13, 2020 11:55 am    Post subject: Reply with quote
With a bit of luck the body will be seeing some paint before the end of the week.
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Mon Jan 13, 2020 12:15 pm    Post subject: Reply with quote
Thumb I'll nip round for a nosy once it's got it's new colour.
kingroon
PostPosted: Mon Jan 13, 2020 12:42 pm    Post subject: Reply with quote
MisterCorn wrote:
..the body will be seeing some paint before the end of the week.
Looking forward to seeing that.. Cool
Hasta Luego..
KingRoon
Roon's Porsche Journal
Goto page Previous  1, 2, 3 ... 44, 45, 46
Page 46 of 46
