997 : 2004- 58
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
Dammit
PostPosted: Tue Jun 25, 2019 8:27 pm    Post subject: Reply with quote
They look great, do they fill the new wheels?
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Tue Jun 25, 2019 8:36 pm    Post subject: Reply with quote
Hopefully!!! I'll find out when I get my hands on them.
kurlykris
PostPosted: Tue Jun 25, 2019 10:11 pm    Post subject: Reply with quote
I popped in to see Alex last week as I was up there, they looked good to me MC Grin
I`ll be back up there on Thursday if you need me to pick anything up for you while I`m there Thumb
2006 987.1 Boxster S 3.2 sport chrono
2010 Mercedes E350 AMG Sport
PostPosted: Wed Jun 26, 2019 7:23 pm    Post subject: Reply with quote
Can i ask a question as im seriously confused .. i'm the first to admit mods and me just dont work , too many years fixing the standard cars im afraid .
You are fitting 6 throttle bodys instead of one .. does this allow better air flow to individual cyls ?
I assume the maf will be fitted to a pipe where the original throttle would have been but i'm struggling to see a difference 6 throttles will make over one large one .. and the adjustment for each would need to be perfect.
A lot of work and parts to gain something the system already does ?
Best i can think of is air flow for each cyl would increase a small amount but this is way beyond what i can get my head around .. sorry .
Also thank you .
Indy Mechanic .
Dammit
PostPosted: Wed Jun 26, 2019 7:37 pm    Post subject: Reply with quote
I'm far from an expert, but:
- Throttle response, with each throttle butterfly positioned very close to the intake valve, is very sharp
- You can run much lumpier cams than with a single large throttle
- The ITB butterfly is 50mm wide, which gives an area of 19.63cm per throttle, or ~118cm in total
- A single 82mm throttle gives an area of 53cm, less than half that of the ITB's
- They sound awesome
- If you can see them they look extremely cool
- You'd normally run alpha-n with ITB's, rather than have a MAF in the airflow
PostPosted: Wed Jun 26, 2019 7:45 pm    Post subject: Reply with quote
Thank you .. it helps but ..
- You'd normally run alpha-n with ITB's, rather than have a MAF in the airflow .. i have no idea what that means
Indy Mechanic .
Dammit
PostPosted: Wed Jun 26, 2019 7:50 pm    Post subject: Reply with quote
Sorry, alpha refers to throttle angle, n is rpm - essentially you map the car on a dyno so the ECU knows, for a specific throttle angle and engine speed, what fuel and spark is required. You also need to know air temperature/density, so you can fuel accordingly.
It removes the MAF from airflow, meaning that when the butterflies are fully open there's nothing in the way of the airflow.
PostPosted: Wed Jun 26, 2019 7:58 pm    Post subject: Reply with quote
Aghhh you remove the maf and use a TPS to take its place with a set map in the dme .
Im guessing dme for altitude , its in built , ambient air temp sensor covers the temp .
clever .
Thank you .
Indy Mechanic .
Dammit
PostPosted: Wed Jun 26, 2019 8:01 pm    Post subject: Reply with quote
Air-cooled, so sounds a bit tractor-tastic, but you get the idea:
https://www.youtube.com/watch?v=r5-Q5OHqiGc
kurlykris
PostPosted: Wed Jun 26, 2019 8:45 pm    Post subject: Reply with quote
Wow, that sounds fab Grin
Mad Mark911
PostPosted: Sun Jun 30, 2019 8:16 am    Post subject: Reply with quote
Great thread - I've just read all 40 pages and I'm both in awe and quite jealous! worship
991.1 C2S - Rhodium Silver
Golf R - Lapiz Blue
Honda Civic Type R JDM - All white
Too many previous cars to list ...
NedHan79
PostPosted: Sun Jun 30, 2019 8:24 am    Post subject: Reply with quote
The info in this thread is first class for the rest of us.
I love it Thumb
#modified996mk1
MisterCorn
PostPosted: Wed Jul 03, 2019 8:32 pm    Post subject: Reply with quote
Thanks for the kind words guys. Progress has been a bit slow recently, things are going on in the background on the engine front, and hopefully soon on the bodywork, but nothing fun to share. I'm up to my elbows in doing an air con overhaul on an old Merc whilst the garage was free.....
I have put together a short video of my attempts with a stud extractor on the M96 engine exhaust studs. I'll do another one for using the Stomski jig when that arrives.
Open Youtube Page
Edited to update link to new version of video.
wasz
Paul Ricard
1999 Porsche 996 Carrera 2
PostPosted: Thu Jul 04, 2019 12:11 pm    Post subject: Reply with quote
This is great! You seem to repeat the first minute or so though.
Really helps in knowing whats likely to come out.
What brand of extractor did you use?
Cheers.
996 parts cache sell off
MisterCorn
PostPosted: Thu Jul 04, 2019 12:40 pm    Post subject: Reply with quote
Thanks for the note on the video, I'll check that when I get a chance and correct it. It was a Laser impact stud extractor.
I might get the smaller one as well, to try on the stud that this one was slipping on.
Things are happening on the bodywork finally.
maldren
PostPosted: Thu Jul 04, 2019 5:56 pm    Post subject: Reply with quote
It might be interesting to try it with an impact driver, a lighter weight cordless model rather than the heavy duty mains models that rip things apart!
Mike
TurboRob
PostPosted: Thu Jul 04, 2019 7:07 pm    Post subject: Reply with quote
Fantastic thread MC - enjoying checking in and reading your progress
996.2 C2
MisterCorn
PostPosted: Sat Jul 06, 2019 12:58 pm    Post subject: Reply with quote
Cheers.
Video updated to remove the repeated section and add details of the extractor. Link updated.
PostPosted: Sat Jul 06, 2019 2:09 pm    Post subject: Reply with quote
Blimey, this project hasn't half aged you. Grin
MisterCorn
PostPosted: Sat Jul 06, 2019 3:12 pm    Post subject: Reply with quote
Not really, you just haven't seen me in my work gear without having done my hair and makeup before.
Goto page Previous  1, 2, 3 ... 39, 40, 41 ... 47, 48, 49  Next
Page 40 of 49
