997 : 2004- 67
996 : 1997-2005 34
Boxster : 1997- 21
Cayenne : 2003- 3
wasz
1999 Porsche 996 Carrera 2
PostPosted: Wed Mar 27, 2019 3:55 pm    Post subject: Reply with quote
Excellent!
What colour is it going to go?
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Wed Mar 27, 2019 4:03 pm    Post subject: Reply with quote
3AE Viola Metallic
MisterCorn
PostPosted: Fri Mar 29, 2019 7:12 am    Post subject: Reply with quote
I took the oil pressure sender off the cover this morning and fitted it to our Druck pressure indicator to check the outputs from it.
The answer is that it is the same output as this VDO sensor here:
https://vdo-webshop.nl/en/pressure-senders/378-vdo-pressure-sender-0-5-bar-1-8-27-nptf.html
The low pressure warning is activated at approximately 0.37bar, or 5.4psi for you oldies.
I now need to check the pullup resistor on the dial cluster and I can check the gauge accuracy.
rdodger
PostPosted: Fri Mar 29, 2019 9:18 am    Post subject: Reply with quote
https://vdo-webshop.nl/en/pressure-senders/386-vdo-pressure-sender-0-5-bar-1-8-27-nptf.html
Or this one with the warning light?
MisterCorn
PostPosted: Fri Mar 29, 2019 1:28 pm    Post subject: Reply with quote
That's the one.
I mentioned on another thread that I was looking to see how the cup cables fitted and was short of a bracket. Thanks to ontheloop I now have the correct bracket.
This isn't the end of the story for this end of the cables though. Due to the design of the housing, if I screw the plate in at this height I won't be able to put the centre console back in. So I need to shorten the plastic mounting post by 8mm and modify the bracket, or use it as a pattern to make a new one, which is also 8mm shorter on the overturned sections which hold the cables in place.
NedHan79
PostPosted: Wed Apr 10, 2019 9:30 am    Post subject: Reply with quote
Mc just a quick question. How high did you need the car on stands to get the engine out, as in pulled out from underneath as well?
Just doing my homework to see if it’s possible for me to do at home so I can paint the bay.
MisterCorn
PostPosted: Wed Apr 10, 2019 9:42 am    Post subject: Reply with quote
I don't know. I had the engine on a lifting table and lifted the car from it. My lift will go up to about 2m so don't really take much notice.
NedHan79
PostPosted: Wed Apr 10, 2019 9:52 am    Post subject: Reply with quote
Aye that’d be easier. I’m not blessed with much space so I’m trying to figure out how I’m going to get round the problem. I’m guessing it’s very straight forward gettin the engine out. Can’t see too many problems. I think if I could even just drop it down say 18 inches, I could work round it.
MisterCorn
PostPosted: Wed Apr 10, 2019 11:06 am    Post subject: Reply with quote
Infrasilver will know.
coullstar
PostPosted: Wed Apr 10, 2019 11:26 am    Post subject: Reply with quote
Whens the painting to be done?
NedHan79
PostPosted: Wed Apr 10, 2019 12:11 pm    Post subject: Reply with quote
MisterCorn
PostPosted: Wed Apr 10, 2019 12:22 pm    Post subject: Reply with quote
No progress in the last week, he has some other more involved stuff at the moment...
MisterCorn
PostPosted: Wed Apr 17, 2019 7:05 am    Post subject: Reply with quote
I have been away for a week, and had a week of not going a great deal Smile So time to get back on with a few details. I am starting to get the engine ready. The jobs I need to do on the engine are:
Remove both camshaft covers to clean them up and stop the leaks
Fit prototype scavenge pump to the right hand cylinder bank
Fit prototype tappet chest to one bank
Remove IMS bearing cover to flip off the seal from the bearing and cure the leak on the cover
Remove sump to see if it is an x51 version and reseal to stop leaks
Fit stud kit for the exhaust
That is about it, nothing major going on as the engine hopefully won't be in for all that long.
I had already taken the cover off the right hand bank and started doing a bit of cleaning on it. Today I cleaned the cover, coils, and coil tubes. The coils have no cracks so they won't be changed at this point. The cover looks OK but I will be taking it to the acid dippers for a very quick clean. I am conscious of the bearing surfaces in there but the guys there know what they are doing so can just do a quick dip for me to not damage the surfaces.
The aluminium coolant tubes which run under the car will be dipped at the same time, they have had the fittings all removed. Some clips will need replacing.
I am fitting the cup cables to the shift mechanism, which require a plate to hold the cables in place. The standard cup cover plate means that the centre console doesn't fit properly, so I have made up a shorter one which will also require 8mm to be removed from the plastic mounting point on the shifter. This is where I am up to with it so far.
NedHan79
PostPosted: Wed Apr 17, 2019 9:08 am    Post subject: Reply with quote
Good job. I’ve started to read this from the start to pick up the info for my own car Laughing
#modified996mk1
MisterCorn
PostPosted: Wed Apr 17, 2019 8:15 pm    Post subject: Reply with quote
Bracket for the shift housing finished off. I need to pick up a few parts to finish the cable ends off so more will follow. I'm pitting together a video to show all of the details and parts required.
Coolant pipes stripped ready to go for a dip tomorrow.
steve r
PostPosted: Wed Apr 17, 2019 8:33 pm    Post subject: Reply with quote
Look forward to seeing this as I have cup cables to fit to mine.
40th Anniversary
MisterCorn
PostPosted: Sat Apr 20, 2019 6:23 pm    Post subject: Reply with quote
I need a pair of half nuts and a couple of screws, but the cup cables are coming together.
MisterCorn
PostPosted: Thu Apr 25, 2019 6:25 am    Post subject: Reply with quote
Camshaft cover cleaned up and dropped back in to place, with some assembly lube on the bearings. This isn't being sealed yet, so hasn't been torqued up properly, it has just been nipped up so that I can turn the engine over 360 degrees to do the other side and the IMS bearing cover.
Lightweight flywheel has arrived but won't be fitted to this engine as I want to have it balanced with the rotating assembly for the new engine.
MisterCorn
PostPosted: Thu Apr 25, 2019 12:34 pm    Post subject: Reply with quote
Crankshaft turned 360 degrees, exhaust manifold off, exhaust bracket off, coil cover and coils out and then remove the camshaft cover.
All looks OK in there. Next job is to remove the camshafts.
Jamesx19
PostPosted: Thu Apr 25, 2019 6:07 pm    Post subject: Reply with quote
Nice one MC.
You going to have to give it a good pasting in the interests of development then ??? Thumb
1998 C2 Manual + The Full Hartech.
Goto page Previous  1, 2, 3 ... 33, 34, 35 ... 39, 40, 41  Next
Page 34 of 41
