997 : 2004- 76
Boxster : 1997- 14
Cayman : 2005- 17
Cayenne : 2003- 3
Griffter
PostPosted: Sat Mar 02, 2019 9:09 am    Post subject: Reply with quote
NedHan79 wrote:
Nice rims. There dosnt seem to be much after market stuff in the way of wheels for the 996.
Is this due to the expense of different sizes front and rear?
As an ex Subaru owner you’ll be aware of Bola. I think some of their wheels in Matt bronze would look superb on a 996. They do staggered packages for the 996. Are you brave enough? I’m not sure I am!
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Sat Mar 02, 2019 5:42 pm    Post subject: Reply with quote
I have finished stripping the leather off the first set of interior parts I want to retrim.
MisterCorn
PostPosted: Sat Mar 02, 2019 6:24 pm    Post subject: Reply with quote
Not the most exciting of videos, but if you ever want to strip your instrument binnacle cover on a 996, this is how to do it....
Open Youtube Page
MisterCorn
PostPosted: Fri Mar 08, 2019 7:12 am    Post subject: Reply with quote
It has been a bit of a slow week as I've been doing some real work. I have continued with the interior retrim. After taking off the pieces of leather I used them to make patterns in thick paper, then used these patterns to make new pieces out of scrap bed sheets. I'm doing this to make sure that the patterns are correct and the parts fit. I would rather find there is a problem on free scrap sheets than £75/m alcantara. The cotton material for the sheets has similar stretch properties to the alcantara.
The bodyshop are still not ready for the car, but I have now got it ready to do the underseal around the engine / gearbox area.
As always with these things it is 5 hours of preparation, 10 minutes to do the job, then an hour or more to remove the coverings. I am planning to leave it to set over the weekend and be in a position to put the suspension and some pipework back on next week. I need to get it back to where the brakes are working.
I have also bought a full set of suspension uprights as I'm working on a modified brake setup to run PCCB disks, 380mm on the front and 350mm on the rear. I think the yellow calipers should look really good with the purple bodywork. Hopefully some more updates on that next week.
Dammit
Watkins Glen
PostPosted: Fri Mar 08, 2019 8:50 am    Post subject: Reply with quote
Personally I'm voting for the floral interior, I think it'll make the car stand out.
New997buyer
PostPosted: Fri Mar 08, 2019 4:16 pm    Post subject: Reply with quote
Martin thanks for the tip on alcantara. Brilliant! I’m doing some trim pieces myself and you’ve likely saved me a few hundred quid in waste. Thanks for sharing. Floral pattern and all Thumb
MisterCorn
PostPosted: Fri Mar 08, 2019 9:01 pm    Post subject: Reply with quote
I'll try to get more done on the floral interior over the weekend.
First trial fit in the brakes. They will fit. I'll need new adapter brackets.
If only I knew somebody who could knock up a couple for me Question
Jamesx19
PostPosted: Sat Mar 09, 2019 10:23 am    Post subject: Reply with quote
I second Dammits post.
Dunno why your bothering with the alcantara.....
1998 C2 Manual + The Full Hartech.
MisterCorn
PostPosted: Sat Mar 09, 2019 2:31 pm    Post subject: Reply with quote
More floral loveliness.
It isn't stuck on the surface so I can't get it to lie flat. At least it fits though.
FZP
Paul Ricard
PostPosted: Sat Mar 09, 2019 7:24 pm    Post subject: Reply with quote
+1 on the floral. I'm liking the contradiction of this car with the sweetness and light of the floral interior, and street fighter performance of the car. Brilliant Thumb
PostPosted: Sat Mar 09, 2019 7:55 pm    Post subject: Reply with quote
re the calipers .. obviously Alex could make something but my thinking it it needs to be a hard material and not ally .
i would think the spacer needs to be one piece as well .. an extender for the caliper.
My concern would be the shear force on the bolts .. they will need to be longer so the tensile strength would need to be higher than standard ..
But im just guessing here .. not my area of expertise at all im afraid .
Fabric ... again i dont know but is it leather based ? leather and heat make it fit around any object .. that is something ive had to do ... contact glue being the best ive found for bonding things like this .
Start at the center and work out each end .
MisterCorn
PostPosted: Sat Mar 09, 2019 8:31 pm    Post subject: Reply with quote
The spacer will have a pair of bolts to bolt to the upright, then a pair of threaded holes to bolt the caliper to the spacer. The bolt holes on the caliper are a lot further apart than those on the upright.
It will be rather experimental with the alcantara, looking forward to that.
77szymon
2003 Porsche 996 Carrera 4S
PostPosted: Mon Mar 11, 2019 11:12 am    Post subject: Reply with quote
Wheels Thumb
what brand strud extractor are you using?
By the way I'm thinking to take your thread and convert to PDF for better read it is so cool worship
will you use some wax or somthing on all bolts nuts etc?
2003 Porsche 911 996 c4s
1988 BMW 635csi Highline - waiting for full restoration
1999 BMW e36 328i Cabrio - still not finished project.....
2011 Mercedes S350L
2004 Audi a2 1.4 tdi - I can't stress enough how good these cars are
2012 Mercedes C220 cdi Estate AMG Sport Plus Pack - wife
MisterCorn
PostPosted: Mon Mar 11, 2019 3:41 pm    Post subject: Reply with quote
Underseal applied. Not easy to photograph a very black thing, but here goes...
I'll see if there is a brand on the stud extractor, but it won't be anything fancy.
MisterCorn
PostPosted: Mon Mar 11, 2019 3:50 pm    Post subject: Reply with quote
Stud extractor. Most likely just the cheapest on eBay.
Ghianightmare
PostPosted: Mon Mar 11, 2019 5:20 pm    Post subject: Reply with quote
...And use a LH directional drill bit if you really want to help success. They are a little bit more expensive, but worth it. Sometimes the drilling motion and heat will get the stud to move in the right direction.
2002 Seal Grey C4S
77szymon
PostPosted: Mon Mar 11, 2019 9:02 pm    Post subject: Reply with quote
I have some obsession with your build can't stop checking for more Razz
Your and CLR are very motivate builds, I hope I will sort all my problems by the end of this year and do smoothing amazing with my C4S
Thank you for info!
2011 Mercedes S350L
PostPosted: Mon Mar 11, 2019 10:39 pm    Post subject: Reply with quote
Spacers can be made from Mild Steel then blackened - local company does it and the blackened skin protects it from the elements and also hardens the surface (bit like case hardening).
The finished effect seen in the black parts on this assembly jig:
PostPosted: Mon Mar 11, 2019 10:40 pm    Post subject: Reply with quote
I restoration guy I do work for also has many of his parts done in different protective coatings. I can get some options from him too if need be (chroming,etc.)
MisterCorn
PostPosted: Mon Mar 11, 2019 10:55 pm    Post subject: Reply with quote
Sounds good. I'll drop a hub, disk , caliper, and pads off with you when I next see you Thumb
Goto page Previous  1, 2, 3 ... 30, 31, 32 ... 37, 38, 39  Next
Page 31 of 39
