997 : 2004- 77
996 : 1997-2005 39
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 11
steve1
2002 Porsche 996 Carrera 2
PostPosted: Sun Jan 28, 2018 2:22 pm    Post subject: Tiptronic Reply with quote
Hi guys
Anybody tell me how to check the oil level in a 996 2002 tiptronic please
Steve
2002 996 C2 cab red
PostPosted: Sun Jan 28, 2018 2:44 pm    Post subject: Reply with quote
I'm assuming that you don't have an owners manual. Dont know
This thread is one of many that details the process.
==> http://911uk.com/viewtopic.php?t=87302&start=0&postdays=0&postorder=asc&highlight=check+oil+level
PostPosted: Sun Jan 28, 2018 4:22 pm    Post subject: Reply with quote
Or do you mean the oil in the actual Tiptronic box ?
steve1
PostPosted: Mon Jan 29, 2018 6:56 am    Post subject: tiptronic Reply with quote
Sorry did not explain properly i meant oil in the gear box.
Selected drive and it did not engage until i increased the revs it then selected with a jolt i believe this could be due to low oil level.
Steve
2002 996 C2 cab red
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Mon Jan 29, 2018 7:38 am    Post subject: Reply with quote
Good information here, including how to drain and refill.
https://www.pelicanparts.com/techarticles/Porsche-996-997-Carrera/35-TRANS-Replacing_Your_Automatic_Transmission_Fluid/35-TRANS-Replacing_Your_Automatic_Transmission_Fluid.htm
PostPosted: Mon Jan 29, 2018 8:21 pm    Post subject: Reply with quote
As above .. get to temp so 30-40 undo the bung and i expect nothing will come out .. it never does sigh .. you basically top it up untill fluid runs out.
You will need some sort of pump with an angled end to get into the lvl hole .
Jay.
PostPosted: Tue Jan 30, 2018 4:39 pm    Post subject: Reply with quote
Yup. Make sure you get a pump, and dont use a long tube & gravity like I did. Took almost 2 hours. Fml.
2004 996 Turbo
Seal Grey
Motec 19" Alloys
AMG Flappy Paddles
1972 Datsun 240z
RB25DET
Devil Z
Follow me on Instagram! @rb.240z
G3BML
PostPosted: Tue Jan 30, 2018 6:45 pm    Post subject: Reply with quote
I bought one of these when I changed my tiptronic oil and filter
https://www.amazon.co.uk/Draper-FHP-1L-23242-Multi-Purpose/dp/B008YFX1S6
2003 Guards Red 996 Carrera 4S
PostPosted: Tue Jan 30, 2018 8:01 pm    Post subject: Reply with quote
@ Jay
Strangely enough on the Cayennes you Have to use a gravity fed bottle .. its a pain , takes ages and makes a mess so i totally agree with you .
Also trying to find some step ladders in a workshop is not the easiest .. we dont tend to have them .
Link for the bottle pump is perfect .
Jay.
PostPosted: Tue Jan 30, 2018 8:15 pm    Post subject: Reply with quote
Demort wrote:
@ Jay
It also stinks, and it took me a while to get the smell to stop (presumably as I had spilled it over the gearbox case, so every time it warmed up I could smell it!)
2004 996 Turbo
Seal Grey
Motec 19" Alloys
AMG Flappy Paddles
1972 Datsun 240z
RB25DET
Devil Z
PostPosted: Tue Jan 30, 2018 8:21 pm    Post subject: Reply with quote
I dont mind the smell of gear oil .. in fact i actually like it .. i started as a truck mechanic but tipronic oil .. hmm .. when hot it makes my eyes sting .. horrible stuff .
Brake cleaner in a spray bottle is best for any spills like this .. we get through gallons of the stuff !
Jay.
PostPosted: Wed Jan 31, 2018 4:51 pm    Post subject: Reply with quote
Went through a bunch of it myself, but annoyingly I only have access to the overly expensive spray cans from Halfords!
It worked fortunately, and it's now smell-free, but was a little worrying for around 100 miles Grin
2004 996 Turbo
Seal Grey
Motec 19" Alloys
AMG Flappy Paddles
1972 Datsun 240z
RB25DET
Devil Z
PostPosted: Wed Jan 31, 2018 7:36 pm    Post subject: Reply with quote
Not sure if this is cheap or not but i found 5 ltrs for what seems like a good price .. all you need is a spray bottle to go with it.
https://www.toolstoday.co.uk/sas-brake-cleaner-5-litre
We use 25 ltr drums which is a bit excessive for the average user i guess Smile
steve1
PostPosted: Tue Feb 13, 2018 3:01 pm    Post subject: Reply with quote
Go it checked all, ok level only very slightly low, no leaks.
Think it was a one off hopfully
2002 996 C2 cab red
