997 : 2004- 77
996 : 1997-2005 40
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 11
Halcyon
PostPosted: Mon Jan 22, 2018 9:42 pm    Post subject: Wires for reverse & handbrake? Reply with quote
I'm shortly going to have a go fitting a new Double-DIN Pioneer unit - SPH-DA230DAB
I need to hook it up to the reverse signal and the parking brake signal (hand-brake) on my Tip
anyone done this? is it easy / hard? anyone know which wires i need to get at and where they are?
Many thanks Smile
996.2 Carrera 4 Convertible Tip
Halcyon
PostPosted: Tue Jan 23, 2018 10:32 pm    Post subject: Reply with quote
Anybody? Sad
I've spent the evening moving the A/C control panel down - that was a bloomin faff...
The Connects2 double DIN trim and cage should be here tomorrow
Meanwhile...Is there a good cubby box that would replace the CD storage thing?
Halcyon
PostPosted: Wed Jan 24, 2018 6:03 pm    Post subject: Reply with quote
Last try...
it seems that there is a reversing signal wire under the seat for the auto dipping mirror. It's black with a blue stripe?
I've only found info on US sites and they describe it being under the drivers seat, can I presume that on mine that will be the passenger seat?
Does anyone know what box this wire comes out of? A photograph maybe?
And I think I'm going to have to splice into the handbrake switch... anyone know the most accessible place to splice into that?
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Wed Jan 24, 2018 6:07 pm    Post subject: Reply with quote
I have got the wiring diagram somewhere, send me a PM with your email address and I will dig out what I can tomorrow.
Halcyon
PostPosted: Wed Jan 24, 2018 6:23 pm    Post subject: Reply with quote
You got a PM Thumb
Halcyon
PostPosted: Wed Jan 24, 2018 10:34 pm    Post subject: Reply with quote
ok, I don't need the handbrake signal - if you earth the signal wire on the head-unit, it's happy Dont know
Sundayjumper
1999 Porsche 996 Carrera 2
PostPosted: Thu Jan 25, 2018 11:28 am    Post subject: Reply with quote
I'd be interested to know if the black/blue wire works out. My Becker would like a reverse signal but I've never got around to doing it.
PostPosted: Wed Feb 07, 2018 7:59 pm    Post subject: Reply with quote
Aghh ok , found your post after the PM you sent .
If memory seats then pin A12 bk/bu (black/blue) wire under both front seats is one place .
Anti dazzle mirror is another and again the same colour .. actually this is the wire colour for this system so anywhere you find it will probably do .
Couple of images below of the wiring and no i have no idea where the bridge plug is Sad
I can only tell you the wires .. i cant say if its correct for what you want .. as i dont know what you want Very Happy
Basically whats the function of what you are going to connect to this .
 Filesize:  252.1 KB
 Viewed:  1308 Time(s)
 Filesize:  235.07 KB
Halcyon
PostPosted: Thu Feb 08, 2018 1:03 pm    Post subject: Reply with quote
Thanks Demort!
Sorry for the delay in responding - yes, you are right, it's the signal wire for a stereo head unit to let it know that the car is in reverse.
I've read in a couple of places where people had had success attaching the head unit reverse sensor wire to the blue/black cable that signals the anti-dazzle mirror.
I *thought* this would be the simplest place to hook into it as I assumed this wire would be under the seats (wrong, by the look of it! lol)
So either seat should have this wire IF they are memory seats? Hmm, I think mine are just electric, not memory, so it looks like the only option is to remove the passenger seat and see what's there (if anything!)
I'll let you know how I get on Smile
PostPosted: Thu Feb 08, 2018 7:22 pm    Post subject: Reply with quote
As you can see from the diagram the blue/black wire is joined so any connection point on that wire will do .
If you dont have memory seats then you wont have the control unit under the seats it goes to .. ie you wont find that wire under either seat as i understand the diagram anyways .
It may well still be in the wireing harness but thats a lot of cutting it open just to check .
best bet atm seem to be the wires going to the mirror .. from memory they will go up the n/s A post so under the trim there .. probably quickest to pull the interior light and see if you can find the wire there .
Awwww just had a thought if you have got standard park assist then the control unit is under the passenger seat .. as per the diagram that also has the wire going to it .
