Hi
I'm going to replace my PCM2.1 (997.1 Turbo) with a Pioneer AVIC. Planning to use the connects2 interface to keep the wiring simple as I have Bose/MOST and steering wheel interface.
Question is - I know that the ASK amp (non-Bose) needs a power trigger from the electric aerial output to trigger it on. Does the Bose need this as well, or does it just pickup from the fibre through the conenct2 adapter?
Also, does the connects2 adapter provide power, or do you need to splice power from somewhere - I assume it provides power now, but older threads suggest needing to run separate power.
Other than that - all looks quite straight forwards. Goung to run the DAB and GPS aerials to the front under the plastic with the windscreen wipers, and run the USB cable for the 'phone probably just to the globe box as there isn't really room in the centre console where I was planning to put it - phone's are just too big these days ...
thanks
pete S
thanks
pete S
