997 : 2004- 73
996 : 1997-2005 29
Boxster : 1997- 18
Cayman : 2005- 20
Tuizner
PostPosted: Sun Jan 14, 2018 11:11 pm    Post subject: Thorax Ground Issue, Seat Removal and Buckle Replacement Reply with quote
For a while now I have had an intermittent airbag light. OBD showed it to be a Thorax Ground Issue. I searched the 'net but couldn't find a good write up so hopefully this may help others with similar issues.
I found that wiggling the electric cable from the seat buckle to the seat would make the issue go away for a few days then it would return. There is a metal clip that crimps the cable at the back of the seat which may be the issue.
My Solution has been to Replace the Buckle and cable [997 803 183 01].
This write up also shows you how to remove a 997.1 seat.
Thorax light = airbag light:
Steps (20)
1 – move the seat back so you can access the bolts holding the seat to the car
2 – lift up the tabs in the centre of the plastic covers at the seat front
3 – E12 headed bolts
4 – remove 2 at front
5 – move seat forwards to access rear bolts and remove those too.
6 – seat is now free to move – lift up the front
7 – to access the cables. Take off the front connector.
8 –unscrew the two crosshead screws and remove the box at the front. It is still attached by other cables – these can stay – you are just trying to ease access to the yellow connector underneath. Note the path of the cables so that you can reinstall later without pinching between the plastic box here and the seat frame (they go behind and through one of the seat frames but not pictured..
9 – flip out the black doodah at the side which releases the connector and pull the two yellow pieces apart.
10- you can now remove the seat
11 – placing your seat carefully on a bin you can now access the innards
12 – need to trace the cable from the buckle to the yellow connector and remove the zip ties along the way
13 – goes through here
14 – and into here
15 – remove the yellow connector by squeezing in the 4 tabs and gently pulling the connector
16 – you can then remove the seat cable by releasing the tabs and pulling the grey connector to the side.
17 – Now take the buckle off the seat – 17mm
18 – attach the new buckle and thread the new cable – will need to replace any zip ties that had to be snipped to take out the old cable. Replace the connectors and all the screws and boxes under the seat. Note – the main cable between car and seat needs to go behind the seat frame here to avoid crimping when you screw the plastic box back on. Can now reinstall the seat with the 4 bolts.
19 – When all done you will need to clear your codes on POSIP (autel md702 here)
20 – and if you are lucky the Thorax airbag light has gone!
toffeeman
PostPosted: Mon Jan 15, 2018 12:31 am    Post subject: Reply with quote
Nice one. It’s always well received by a forum when a member takes the time and effort to make a “how to” thread. I’ve done it on other forums with previous cars (350Z/M3/etc) and fully intend to continue the trend when I get my 911.
Jam911
PostPosted: Mon Jan 15, 2018 8:53 am    Post subject: Reply with quote
Seconded. Nice work and thanks for taking the time to post.
Current '07 997 C4S
Ex '99 2.5 Boxster
Tuizner
PostPosted: Tue Jan 16, 2018 11:15 am    Post subject: Reply with quote
Short Shift change coming next... Job done but awaiting time to post the How To..
Infinity99
PostPosted: Thu Apr 04, 2019 8:07 pm    Post subject: Reply with quote
Thanks Tuizner!
Have been looking for a write up to help with this very issue!
Quick question, where did you buy the part from (I've tried googling the part number but not getting any hits in UK), also does the cable come with the buckle or was that a separate part number
Thanks again
James M-S
2009 Porsche 997 Carrera 2
PostPosted: Thu Apr 04, 2019 9:12 pm    Post subject: Reply with quote
Great ‘how-to’ Thumb
