997 : 2004- 77
Boxster : 1997- 18
Cayman : 2005- 18
robbiej
PostPosted: Sun Jan 14, 2018 6:25 pm    Post subject: How much are Ceramic Brakes (PCCB) for a 997T replace cost Reply with quote
looking at 997.1.5 and 2x 997.2 tip to PDK
one comes with centre lock wheels and Ceramic Brakes (PCCB) but they cost a lot to replace? I want to drive and use the car and getting ceramic disk chipped could cost me a packet?
does the centre lock wheels reduce my wheel choice?
PostPosted: Sun Jan 14, 2018 6:40 pm    Post subject: Reply with quote
Ceramic discs cost a lot .. they used to be about £2k per disc but i think they are lower than that now .
If you dont track the car then they pretty much last forever .. i dont recall changeing some for wear and tear since they first came out .
They get chipped when people remove the wheel but dont use the correct tool for removeing the wheel .. the wheel can drop and touch the disc .. it doesnt take much to damage one that way .
Other than that they dont chip .
Pretty dam good at stopping the car as well .
Center lock .. hmm .. if you get any tyres changed and its not a Porsche garage then make dam sure they do them up tight enough.
I worked on a car several years ago that had tyres replaced at a fast fit .. nut not tight enough .. wreaked 2 wheels and 3 hubs .. dam expensive repair that was .
maph
PostPosted: Sun Jan 14, 2018 7:02 pm    Post subject: Re: How much are Ceramic Brakes (PCCB) for a 997T replace co Reply with quote
I was quoted more like 4K per disc from Porsche, so yes expensive, set of pads fitted is about £650. If you happened to be unlucky and damaged a disc I would go the refurbish route at approx £1K per disc.
Overall the PCCBs worry people but given the discs should last 150K miles and pads 40K+ I think they will cost no more over steel over the life of the car...... unless you are big into track days in which case as Dermot said I would stick with steel.
CLs will limit your choice of wheels to CLs and it is not possible to use spacers with them. Regarding tyres, many OPCs will price match online prices or you can supply and they will fit. Not sure if they will fit non N rated.......... guess I will find out when I need another pair of MSS.
2012 997.2 Turbo S - ES650
robbiej
PostPosted: Sun Jan 14, 2018 7:39 pm    Post subject: Reply with quote
thx, I know its a first world problem but I don't want to get the wrong one... last car I had for 9 and half years...
PostPosted: Sun Jan 14, 2018 7:54 pm    Post subject: Reply with quote
I think we can safely say i was very wrong about the cost as ive just looked it up ..
Brake Disc,
Notes: (Use Also:, 997.341.901.00, See Technical Manual, Grupp, 46 51 19) RH | valid for Turbo wheel, 19", central lock (I422) / valid for Ceramic brake (PCCB) (I450)
Qty on Car: 1
Price (each): £3,657.66
Ouch is all i can say !
easternjets
PostPosted: Sun Jan 14, 2018 8:04 pm    Post subject: Reply with quote
I had a conversation with an owner who put his car into an OPC for a warranty check and they found cracks in the PCCB's so advised that they needed replacing. He came away over £20k worse off, he had done one track day but as he said they're on a supercar so should be able to take a bit of heat!
Even paying top dollar you can get a set of steel discs and pads for under a grand!
997 Turbo Gen 2
997 Turbo Tiptronic S
Porsche 968 Coupe 1992
Porsche 928 S4
Porsche 911 3.2 Carrera 1985
robbiej
PostPosted: Sun Jan 14, 2018 9:22 pm    Post subject: Reply with quote
there are steel replacements for these but this scares me, well really the wife moaning about a 20K car service bill!
Why did I agree to a joint account...
PostPosted: Sun Jan 14, 2018 9:30 pm    Post subject: Reply with quote
if you dont track these cars then they really are very good .. they last forever as do the pads .. they stop on a dime .
You just have to be sensible with them .. i would recomend them over standard brakes any day of the week !
robbiej
PostPosted: Sun Jan 14, 2018 9:46 pm    Post subject: Reply with quote
look I had just knocked that car off the list....
choice of three cars (could be 4) I didn't sleep last night
eatapeach
PostPosted: Sun Jan 14, 2018 9:59 pm    Post subject: Reply with quote
I've gone/am going through this exact debate. Track cars usually have them replaced with steel discs - if I get any problems I'll do that. The discs can be sent off for refurb ( see the thread on this sub forum http://911uk.com/viewtopic.php?t=125159)
The refurb place is here http://www.rebrake.de/portfolio/porsche/?lang=en
What are the chances that all 4 get chipped or develop cracks? The other option is to replace with steel and put the ceramics in a box until you sell the car.
The original view of 20k to replace is a bit wild, I'm certainly more relaxed about it now having seen that there are options.
Jay.
PostPosted: Mon Jan 15, 2018 3:19 am    Post subject: Reply with quote
Yep. They're desirable so if you're not paying much of a premium then swap them for some new steel brakes and enjoy those, knowing that you can put the PCCB's back on when you need to sell the car.
You could even consider selling them to a member on here, I imagine that'd give you a bit of a return of some of your investment if you're that way inclined.
2004 996 Turbo
Seal Grey
Motec 19" Alloys
AMG Flappy Paddles
1972 Datsun 240z
RB25DET
Devil Z
Follow me on Instagram! @rb.240z
isysman
PostPosted: Mon Jan 15, 2018 5:03 am    Post subject: Reply with quote
I think you’re worrying too much about them. Both my Porsches have PCCBs and they are great. In fact I’d really like to only have cars with them now.
911 GT2RS Build & 981 Boxster S
Sold ~ 987 Boxster S 3.4, 997.1 3.8 Cab, 987 3.2 Boxster S, 986 Boxster 2.5
Disco
Estoril
2010 Porsche 997 GT3
PostPosted: Mon Jan 15, 2018 3:16 pm    Post subject: Reply with quote
Not that wild. It is ~£15k for the disks, another grand or so for the pads and several hundred more for anti-rattle shims, replacement calliper bolts and pad wear sensors. Then OPC labour. And don't forget VAT. The standard answer to the 'how much' question used to be 'about the same as a new Ford Focus', and it is still the same ball park.
Decent steel racing disks with bells are in the £2-3.5k range for a set of 4 though OE Cup disks (which have a somewhat shorter lifespan for track use due to their propensity for thermal stress cracks around their vent holes) from the motorsport catalogue can be obtained for less. Other than steel or refurbishing your PCCBs there is actually a third option too. Surface Transforms make a composite disk that can replace PCCBs - it is a different kind of rotor the the Porsche ceramics and JZM supply them. Not cheap (I seem to recall them being around £8k for the kit including pads but not positive and it may have since changed as that was a couple of years ago), but appreciably less than PCCBs.
Colin
Black 997 GT3 3.8 CS - Acquired for the 2012 season and beyond
Black 996 GT3 Mk2 - Gone, but will never be forgotten
Jam911
PostPosted: Mon Jan 15, 2018 3:20 pm    Post subject: Reply with quote
IF it is a great car take them off and store/sell them and fit regular brakes.
Current '07 997 C4S
Ex '99 2.5 Boxster
eatapeach
PostPosted: Mon Jan 15, 2018 3:53 pm    Post subject: Reply with quote
Well - it seems a bit far fetched as a non track car that all 4 are going to be replaced at the same time. and then you give even more options so yes it's very unlikely that I'm going to get a bill the size of a ford focus to replace the ceramics Grin
jwb1380
PostPosted: Mon Jan 15, 2018 6:30 pm    Post subject: Reply with quote
I've got a 977.1 Targa 4S with PCCB's, it's done 67k miles and the PCCB's look like new. I took the wheels off to measure the disc thinkness (digital micrometer, Mitutoyo) and it looked like the rear discs were half way through there thickness, there's a min thickness on the disc. Also there are 3 wear discs that look like new. Fronts are less worn than the rears?
Anyway, after getting paranoid about the replacement cost, if I do 5kmiles per year that's 12 years before replacements - I don't track the car. They work perfect from cold and don't make any noises. To make the discs last longer pads should be replaced before they wear out. Mine were at 80% left at 50k miles, measure by OPC.
I'm just going to use them and work out what's next when the do expire. I spoke the guys at Surface Transforms, their discs can be recoated at little cost, but £4k/axle. Steels are another option with yellow calipers? Maybe the cost of the carbon discs will have come down in 2027 when they need replaced?
997.1 4S Targa
1967 Morris Cooper S
Cervelo R5 with 303's
jwb1380
PostPosted: Mon Jan 15, 2018 6:43 pm    Post subject: Reply with quote
10year old disc....
997.1 4S Targa
 Filesize:  1.25 MB
 Viewed:  3002 Time(s)
robbiej
PostPosted: Mon Jan 15, 2018 6:56 pm    Post subject: Reply with quote
I chickened out and purchased a steel disk 997.2 Turbo instead....
the interior colour as well on PCCB car, how fickle we are....
yes I might regret it in the future
jotaking
PostPosted: Mon Jan 15, 2018 7:05 pm    Post subject: Reply with quote
A GT3 with PCCB's has just turned my head. I knew the discs were expensive, I thought 10K for the lot???
How wrong was I???
20K!!
Even with "man maths" I'm never going to convince SWMBO of the merits of PCCB!
robbiej
PostPosted: Mon Jan 15, 2018 7:11 pm    Post subject: Reply with quote
so the plan is she drives it curbs the wheels and then I have to have new ones...yes darling its wider than the C2
the things we do to blindside SWMBO
