997 : 2004- 77
Boxster : 1997- 18
Cayman : 2005- 18
APL911
PostPosted: Fri Jan 12, 2018 2:28 pm    Post subject: Bilstine b4 Dampers with Designtek lowering springs Reply with quote
Hi all.
I am considering fitting the designtek coilovers to my 996.
If I do this, I will have a set of OE spec dampers and designtek lowering springs available.
The front dampers are Bilstine B4 which have only done 500 miles. The springs have also only done 500 miles.
How much do you think this kit would be worth?
I also have a set of OE springs with 67,000 miles on them.
This is just a pipe dream at the moment, and I am not even sure if it is a sensible thing to do given i've just had the front dampers fitted! frustrated
