996 : 1997-2005 29
Boxster : 1997- 17
Cayman : 2005- 20
911_AS
2012 Porsche 991 Carrera S
PostPosted: Tue Jan 09, 2018 11:43 am    Post subject: Battery and Bluetooth questions Reply with quote
I keep my car garaged, as it's a weekend toy. However, with a new born baby, it doesn't get driven as much as I'd like (at the moment!) as the wife's Ford Focus is our daily driver.
On my previous 997, if I didn't drive it for a couple of weeks, the Key Remote button would NOT unlock the door as the car would go into 'Sleep' mode after 'X' days. I would have to insert the Key into the door to unlock it, then quickly into the ignition to disarm the immobiliser / alarm.
Question 1 - how long does it take before the 991 enters 'Sleep' mode? As there is no Lock slot on the 991 door handle, how would I physically unlock the car, IF the button on the key does not work as expected?
Question 2- I stream Spotify audio via my iPhone 8 Plus, which works very well. However, I cannot change the Tracks from the steering column stalk: the Tracks can only be changed by pressing the button beneath the PCM screen, which is a major First World Problem. Is there a way around this, as I'd quite like to control the Track Changes via the stalk on the steering wheel column?
Thanks in advance all.
991.1 C2S. 2012. Basalt Black. PDK.
997.2 C2S. 2010. Meteor Grey. PDK. SOLD.
997.1 C2S. 2006. Basalt Black. Manual. SOLD.
Naturally Aspiring.
weejimmy
PostPosted: Tue Jan 09, 2018 12:40 pm    Post subject: Reply with quote
I am a keen road bike rider so my car can sometimes go for weeks without much use. When that occurs I've noticed with comfort access that the ability to wave over the bonnet to pop the lid and unlock the car by grabbing a handle gets deactivated after a few days. So I have to use the remote to unlock the car. I've not got to the point of having to physically use a key yet!
Never realised you could change tracks via the stalk!
Current: 991.2 C4GTS
Past: 991.1 C4S
Cameo
PostPosted: Tue Jan 09, 2018 12:53 pm    Post subject: Reply with quote
I’ve left mine for 4 weeks and had no problem unlocking or starting the car. I think I’ve read something in the manual about getting in if the key doesn’t work.
I guess the ‘key’ is to not leave the manual in the car Very Happy
No idea about changing tracks with the stalk I’m afraid
pzero
PostPosted: Tue Jan 09, 2018 2:00 pm    Post subject: Re: Battery and Bluetooth questions Reply with quote
Regarding sleep mode - by simply lifting the driver door handle and releasing it the system returns back from sleep mode. You should then be able to open the door in the usual way, ie with remote button on fob. No need for key inserts or trying to beat your personal best to prevent alarm activation.
911_AS
PostPosted: Wed Jan 10, 2018 11:19 am    Post subject: Re: Battery and Bluetooth questions Reply with quote
HAHA!! Thanks PZero. Thumb
Naturally Aspiring.
PostPosted: Wed Jan 10, 2018 7:46 pm    Post subject: Reply with quote
I thought it was the same as tha Panameras .. key lock is under the door handle .. key is in the fob .
If the battery is flat then thats how you get into the car .
 Filesize:  200.32 KB
 Viewed:  2547 Time(s)
911_AS
PostPosted: Thu Jan 11, 2018 4:07 pm    Post subject: Reply with quote
Tip of the Day! Thumb
Thank you Demort.
Naturally Aspiring.
