996 : 1997-2005 43
Boxster : 1997- 13
Macan : 2014- 0
AlanPM
2003 Porsche 996 Carrera 4S
PostPosted: Mon Jan 08, 2018 10:53 pm    Post subject: Short shift kit observation Reply with quote
So I decided my C4S needed the short shift kit treatment so got the kit below
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F281197823074
My mechanic fitted it and as he said by phone, it's great tight and positive!.
Terrific I thought but after I got the car back I noticed the lever was pointing over to the passenger side when in neutral, in fact all gears were positioned left of central with only 5th and 6th just right of centre.
Anyhow on inspecting the lever it does have a bend over to the left from the fulcrum point.
Here's the question, is it just a matter of undiing the fulcrum bolt and turning the lever 180 degrees and re inserting the fulcrum?
I don't see why this shouldn't be the case, I am just after some experienced input.
Thanks, Alan
2003 911 C4S cabriolet, manual,
Polar Silver with Metropol Blue interior, LTT, SSK, wheel spacers, Design Tech CAI, BMC Sports filter, Remap, RS engine mounts.
2007 BMW 335i M Sport
kurlykris
Watkins Glen
PostPosted: Mon Jan 08, 2018 11:38 pm    Post subject: Reply with quote
I`m certainly no expert, but I just found this on google, I always thought the lever was straight Question
I know it`s from a 997, but we can use the 997 GT3 ssk on 996`s
2006 Boxster S sport chrono
2010 Mercedes E350 AMG Sport
911munKy
PostPosted: Mon Jan 08, 2018 11:56 pm    Post subject: Reply with quote
Yes, with the eBay SSK you need to undo the bolt and swap the lever around, most of the adverts mention this but your one just alludes to the fact that it fits both L & R hand drive cars.
2000 C2 996
AlanPM
PostPosted: Tue Jan 09, 2018 3:17 pm    Post subject: Reply with quote
Thanks chaps, that’s all the confirmation I need Thumb
rabbitstew
PostPosted: Tue Jan 09, 2018 3:28 pm    Post subject: Reply with quote
Yep, they come set for LHD.
Bit of a pain if you have it all fitted as you probably have to take the trim all off etc in order to get to the bottom of the leaver to pop it off the mechanism.
Whilst you are in there, i would strongly recommend replacing the nut each side of the pivot arm with nyloc ones. I found the standard non locking nuts they come with had a tenancy to work loose, even after using thread lock.
2008 997.1 Turbo Manual - 585whp thanks to do88 & 9e
2000 Ducati 996
1999 Yamaha R1
1994 Kawasaki ZXR750L2
alex yates
PostPosted: Tue Jan 09, 2018 5:11 pm    Post subject: Reply with quote
You can swap it round in situ....just make sure you lock the ball ens in the cable socket......and don't drop the nut, bolt or washer from the middle of it.
AlanPM
PostPosted: Thu Jan 11, 2018 7:08 pm    Post subject: Reply with quote
Hi guys, thanks so much, I passed this on to the mechanic who did the necessary exactly as you indicated.
On a different note I just improved the view from the lounge window by extending the drive round so I can park the Porsche there, perfect view !
 Filesize:  1.51 MB
 Viewed:  1205 Time(s)
