997 : 2004- 66
996 : 1997-2005 43
993 : 1993-1998 9
964 : 1989-1993 7
Carrera SC : 1977-1983 0
Classic : 1950-1965 1
Boxster : 1997- 15
Cayenne : 2003- 9
912-914-924-928-944-968 4
Beej160
PostPosted: Mon Jan 08, 2018 8:21 pm    Post subject: The value of mesh Reply with quote
Hi guys
Just wanted to check the space behind the front grilles since DIY mesh 1.5yrs ago.
Not even a tiny stone did I find behind the grilles!
Sorry if the pics are sideways PC
2004 996 C4S tiptronic coupe, seal grey/black leather
 Filesize:  1.41 MB
 Viewed:  1024 Time(s)
 Filesize:  1.5 MB
911munKy
PostPosted: Mon Jan 08, 2018 11:57 pm    Post subject: Reply with quote
Nice, I’ve not checked mine yet but hopefully I will find the same.
2000 C2 996
plynchy
PostPosted: Tue Jan 09, 2018 10:22 am    Post subject: Reply with quote
Wow! Surprised
Really must fit some, after 2 years my air con rads are battered with no mesh, still working though, for now. Very Happy
'02 996 Turbo Manual Coupe Lapis/Grey. Unlimited grins.
JS1500
PostPosted: Tue Jan 09, 2018 11:30 am    Post subject: Reply with quote
I replaced one of my AC condensers recently due to leaking, shall do the other side and both coolant rads and maybe add a centre rad too in the next few months... And add some mesh at that point!
2000 996 C4 - Guards Red
Marky911
PostPosted: Tue Jan 09, 2018 3:34 pm    Post subject: Reply with quote
Good result.
I've just done rads and condensers but didn't add mesh as I like the standard front bumper openings and the car does low miles. I think I may add some though to protect all of my hard work.
JS1500-
Read up about 3rd rads before you spend your hard earned cash.
Hartech say -
"I have no problem with anyone fitting a third radiator if they want to but so far our tests suggest it is not an important factor."
Thread here -
http://911uk.com/viewtopic.php?t=89494&postdays=0&postorder=asc&start=20
The above is about 997s but I'm guessing the principle is the same?
Either way read up a bit. I've fitted an LTT, but won't bother with the 3rd rad.
Apologies for thread derailment OP. Thumb
Johnawhiskey
PostPosted: Tue Jan 09, 2018 9:26 pm    Post subject: Reply with quote
Having gone through a couple of rads and condensers mine are being done next week.
C4-STORM
2004 Porsche 996 Carrera 4S
PostPosted: Tue Jan 09, 2018 11:05 pm    Post subject: Reply with quote
Which kit is best without having to remove or cut the OE plastic grills?
I know you can make your own but I would also like to do this but using a pre-made kit.
2004 C4S Coupe 3.6 Tiptronic S ~ Basalt Black ~ Black Crested Sports Seats ~ Alcantara ~ S/R Delete ~ WEVO Engine Mounts ~ K&N Induction Filter ~ DesignTek Sports Exhausts ~ Quad Tips ~ RUF Hubcentrics ~ RUF Sports Springs
maldren
PostPosted: Wed Jan 10, 2018 8:56 am    Post subject: Reply with quote
Don't buy the Rennline kit, it's easier to make your own as the mesh is badly shaped and difficult to bend! Zunsport looks good but it's a lot of money, it was my first choice but Design911 didn't have it in stock. Design911 now have a cheaper kit but it's still expensive, I can't comment as I haven't seen it.
Mike
C4-STORM
PostPosted: Wed Jan 10, 2018 10:46 am    Post subject: Reply with quote
Thanks Maldren. I thought with the Zunsport you had to remove the plastic grills, someone did mention a kit which you can attach and leave the grills in situ??
JS1500
PostPosted: Wed Jan 10, 2018 3:42 pm    Post subject: Reply with quote
Marky911 wrote:
Good result.
JS1500-
Hartech say -
Thread here -
Thanks for the input Marky. Maybe I won't bother with the centre rad... I do have a LTT and new water pump waiting to go on too...
coullstar
PostPosted: Wed Jan 10, 2018 4:10 pm    Post subject: Reply with quote
It costs about £15 to do yourself and is really quite easy.
2000 Audi B5 RS4
JS1500
PostPosted: Wed Jan 10, 2018 4:36 pm    Post subject: Reply with quote
What mesh did you use, Graeme? Sorry if covered elsewhere...
maldren
PostPosted: Wed Jan 10, 2018 8:20 pm    Post subject: Reply with quote
I bought black aluminium mesh off Ebay, easy to bend and very cheap. I used stainless screws to fasten the mesh to the back of the spoiler.
Mike
