996 : 1997-2005 48
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 14
Cayenne : 2003- 8
Macan : 2014- 3
912-914-924-928-944-968 4
Drew1209
PostPosted: Sun Jan 07, 2018 2:25 pm    Post subject: C4 manual gearbox mount Reply with quote
I'm looking to change this when I do the engine mounts, does anyone have a part number for it as I'm struggling to find a supplier.
Are there any upgrades for this part apart from the poly inserts ?
alex yates
PostPosted: Sun Jan 07, 2018 2:28 pm    Post subject: Reply with quote
You can get the mount from OPC but you'll need to remove the gearbox from the car to do it. Personally I'd just fit the powerflex inserts (around £28 ). I presume that's what you mean by the poly inserts? There are others on the market but they're far more expensive.
Used daily....rain, sun or snow.
Drew1209
PostPosted: Sun Jan 07, 2018 2:36 pm    Post subject: Reply with quote
I've got a shot of the tool for changing the mount in situ so thought I'd do it proper while I have the opportunity.
wasz
1999 Porsche 996 Carrera 2
PostPosted: Sun Jan 07, 2018 8:51 pm    Post subject: Reply with quote
Design 911 have an equivalent lemforder mount (might the OE maker) for 16+ vat
http://www.design911.co.uk/fu/prod4744/Gearbox-Mount-996-Rear--EXTENSION-HOUSING-99637505505/
Locosaki
PostPosted: Sat Jan 13, 2018 1:14 pm    Post subject: Reply with quote
Does the 997 gearbox mount fit, looks to be a different design but the housing looks the same size.
Carrera 4 MY99 with full Hartech rebuild
