964 : 1989-1993 6
Boxster : 1997- 17
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
pierrebear
PostPosted: Wed Jan 03, 2018 9:21 pm    Post subject: Airbag light Reply with quote
Evening and happy new year fellow 911ukers
Whilst driving home tonight, my airbag light came on (and has proceeded to stay on) - no idea why or how as I was just driving along merrily.
I’ve had a look at some of the older threads but can’t work out if this is something that needs to be fixed immediately or can be ignored until the next time it’s at my local Indy? All thoughts gratefully received as ever.
Pierre
1995 Carrera 2 coupe manual, midnight blue
EX 997.1 Carrera 4S coupe manual, basalt black
EX 2003 Mercedes SL500, green black (dark blue!)
PostPosted: Wed Jan 03, 2018 10:46 pm    Post subject: Reply with quote
What's the battery like? Sometimes a faulty/weak battery can cause the airbag light to come on.
Check the fuses (not sure if there is one?) but reset can only be done with a diagnostic tool and ideal to read the fault codes. If you know someone local with one it's a quick job plugging into OBD2 port.
pierrebear
PostPosted: Wed Jan 03, 2018 11:01 pm    Post subject: Reply with quote
Hmm thanks, Zingers - I didn’t think the battery was particularly weak but it might be. I do get the impression that mine is getting a lot more use now than it did with its previous owner!
Will get the local Indy to plug it in next time it’s in...trying to avoid becoming to much of a regular there though as it’s only recently had the new front discs put on!
SHAKTER
PostPosted: Thu Jan 04, 2018 1:05 pm    Post subject: Reply with quote
I had the same issue and eventually had the guys at Precision take a look. Had to replace the airbag control unit (can't recall if that's what it's called technically). Wasn't cheap! I think it set me back over £500 Surprised Surprised
pierrebear
PostPosted: Thu Jan 04, 2018 10:50 pm    Post subject: Reply with quote
Update: today the light magically vanished whilst on the way to work! On the down side I got splashed by a huge wave whilst driving. An excuse for another valet methinks...
ToreB
Approved Trader
PostPosted: Fri Jan 05, 2018 9:03 am    Post subject: Reply with quote
The most common cause for the air bag light to be lit is that the warning light bulb itself has intermittent contact. The bulb is supervised by the control unit, and any hiccups in the bulb holder or clock instrument connector will cause the control unit to fire a fault, and light the warning lamp.
This problem can be prevented by turning the warning lamp in the bulb holder, as well as pulling out the connector a few times. This will remove any corrosion on the contacts.
As mentioned above, a Porsche compatible OBD tool will reveal the cause for the alarm.
Cheers,
Tore
'95 993 C4
Bergvill F/X
Porsche electronics specialists, products and repair services.
