Scholester
- Joined
- 16 Jan 2012
- Messages
- 1,357
What would you chaps use when fitting new lambda sensors to a new exhaust? I am not sure of the heat properties of Copperslip but I guess High Temp Grease wouldn't stand exhaust heat anyway?
Typical lambda sensors see about 700 deg C.ELA said:Never Seez pure nickel will be the best option
DRZ911 said:Typical lambda sensors see about 700 deg C.ELA said:Never Seez pure nickel will be the best option
:thumb: Bostik Never Seez Pure Nickel Special is good for almost 1500 deg C as an anti-seize compound, so excellent stuff in the prolonged severe temperature environment of a lambda sensor.
Indeed, any copper based grease is also worth considering (although a lower max temperature at approximately 1150 deg C).
:thumb: Yes, no issues in this application.Scholester said:So my tub of Copperslip is fine then?
:thumbs:DRZ911 said::thumb: Yes, no issues in this application.Scholester said:So my tub of Copperslip is fine then?
