997 : 2004- 87
996 : 1997-2005 43
Boxster : 1997- 14
Cayman : 2005- 15
Cayenne : 2003- 7
Macan : 2014- 0
9xxnick
PostPosted: Tue Dec 26, 2017 5:49 pm    Post subject: 993 rear PU brackets Reply with quote
Has anyone ever found a source for a stainless steel version of the more complex of the two brackets that support the lower edge of the rear PU at the sides of the car? I know Orangecurry had some of the rears made up but I've never seen the more complicated bracket made up in stainless.
I'm just not that keen on fitting another set of expensive and rot-prone standard ones.
clinchy993
PostPosted: Tue Dec 26, 2017 7:53 pm    Post subject: Reply with quote
I Just went with the factory ones but drilled tiny holes and wax proofed them inside and out then put self tappers in the holes
They look as fresh as the day I fitted them a good few years ago
tim993
2016 Porsche Boxster 981
PostPosted: Tue Dec 26, 2017 8:33 pm    Post subject: Reply with quote
yes as Tony says - do that! Think I may have had mine power coated but can't swear I wasn't dreaming that? Also - forget the costo-millions OPC fasteners and use as much generic stainless or copper as you can find to attach anything buried at the arse-end of the 993. thumbsup
"I don't know what it is about peace conferences, but they always seem to attract terrorists, extremists and nutterists."
1995 993 turbo
wozy
PostPosted: Wed Dec 27, 2017 1:51 pm    Post subject: Reply with quote
How long do you require them to last? My originals have just been replaced at 142K miles and 24 years. They'd held fast through sun rain sleet and snow and as much salt our roads could throw at them.
Porsche Cars of Great Britain launched the 993 in the UK in early December 1993 registering 12 x UK cars on the 6th & 7th of that month; mine is one of them.
993 C2. MBM. C4 mounts, RSRs, RS Short shifter. RS steering wheel. FSDs & M033s
Previous 2.7S, 3.2, 964 and 968CS
clinchy993
PostPosted: Wed Dec 27, 2017 5:21 pm    Post subject: Reply with quote
I just recovered al that silver foil behind the rear PU with silver aluminium tape from Halfords ,looks like it just came from factory ,but no one will ever see it :)
9xxnick
PostPosted: Wed Dec 27, 2017 11:36 pm    Post subject: Reply with quote
My originals were replaced in 2010 (at c70K miles) and one of the replacement complex ones now has enough corrosion on it (at c106K miles) to have allowed it to fail at its lower attachment point. I suppose it's one of those things I'd like to more or less fit and forget rather than something which clearly needs periodic inspection, albeit with the day of reckoning being put off with some aftermarket rustproofing.
As an aside, my car was registered in January 1994 so was close to yours in build date, I assume.
tim993
PostPosted: Thu Dec 28, 2017 12:34 pm    Post subject: Reply with quote
The case for using decent S/S or copper fasteners is pretty clear - they simply mean any subsequent work that involves taking bits off will be that much easier and not require an angle grinder. With items like the main heat shields being fashioned from mike steel then a common way they fail is corrosion around the screw head that holds them in place rather than because the whole thing is shot. So again improving the fasteners can help. Not sure about the PU brackets but it kind of annoys me they should even corrode or rust at all!!
1995 993 turbo
Cameltoe & Heel
PostPosted: Fri Dec 29, 2017 12:27 pm    Post subject: Reply with quote
I had mine powder coated but they were ok to begin with, stainy items would be brilliant but perhaps overkill.
I’ve recently ordered more generic chimney nuts and stainless M8 70mm bolts, washers and nuts for my exhaust clamps. Much better items than those from Porsche without the silly tax for what is a commodity item.
Great tip regarding the Alu tape, I shall get some from halfrauds
Trev
wozy
PostPosted: Sat Dec 30, 2017 1:56 pm    Post subject: Reply with quote
Corrosion is a bizarre thing on a car, and it seems more so on 993s. How can mine be just about the same build age as yours, it's always been used throughout the year (for the first 18 years of its life up north in Cumbria) yet bumper stays lasted twice the mileage and seven years longer. It defies logic.
Millomboy
1997 Porsche 993 Targa
PostPosted: Sat Dec 30, 2017 5:38 pm    Post subject: Reply with quote
They appear to be available on Carnewal website.
Ocean blue targa.
The only true freedom, is freedom from the heart's desires. And the only true happiness, this way lies.
9xxnick
PostPosted: Sun Dec 31, 2017 2:09 pm    Post subject: Reply with quote
Agreed. I have seen similar phenomena with other cars including Alfas, with some rusting badly and others being corrosion-free in the same location. Thankfully the rest of the car is extremely good with even the windscreen pillars and chassis rails only needing a small amount of rust treatment as a preventative measure. I've also waxed the car extensively with Dinitrol. Perhaps my PU supports have become "sacrifificial" under the waxing regime.
The PU supports on Carnewal are the standard factory parts rather than being stainless, though the photo does make them appear slightly silver in colour.
