996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
MattyR
PostPosted: Fri Dec 15, 2017 12:04 am    Post subject: CTEK Battery Changer - educate me please! Reply with quote
So the general consensus is the MCS 5.0 yes?
Anyone happen to know the length of cable from the plug to the conditioner unit?
Can I plug straight into the ciggy lighter in a 1995 993 or direct to battery only?
Will it recondition a drained battery due to lack of use (new battery but drained through car sitting on drive under cover for 2 months!).
Atlas Grau on Ocean Blue Gen 2 997 C2 Carrera
Sold: Aventura Grün 993 C2 Carrera
GT917
PostPosted: Fri Dec 15, 2017 5:40 am    Post subject: Reply with quote
Length is about two meters (too cold outside for checking).
Yes, you can plug it in the cigarette lighter.
Yes, it should recondition your recent but drained battery.
NIBrown
PostPosted: Fri Dec 15, 2017 9:21 am    Post subject: Re: CTEK Battery Changer - educate me please! Reply with quote
[quote="MattyR"]So the general consensus is the MCS 5.0 yes?
Only works if cigarette lighter remains live with key out of ignition, can't remember if they do??
993S with 62K,
MK7.5 Golf GTD (digi dash)
Skoda Yeti 140TDi 4x4 with 152K Smile
Previous
Mk5 Gti Pirelli Edition, Audi TT diesel, Defender 300Tdi CSW,90 Tomb Raider, Golf 7R
Mk6 Golf GTD, Mk5/4/3 Golf Gti, Audi S3
View user's profile Send private message Send e-mail Yahoo Messenger
Endoman
PostPosted: Fri Dec 15, 2017 9:42 am    Post subject: Reply with quote
Ciggy lighter liive with ign. Ctek can supply lead which you can tuck under carpet. Push down on frunk locking cam so you can run a lead into car with bonnet on safety catch, locks and alarm can be activated. Dont forget to pull bonnet release and close before driving off. I fitted a remote socket which indicates battery condition.
gunner
PostPosted: Fri Dec 15, 2017 10:13 am    Post subject: Reply with quote
I have an 'eyelet' connector permanently in place on the battery with the cable run under the carpet to just next to the frunk struts.
Most of the time that cable is connected to a second cable through into the cabin to power my DAB/USB, but can also be plugged into the charger at this point with the bonnet closing as usual.
993 C2 Tip Aventura
Jet Jock
PostPosted: Fri Dec 15, 2017 6:52 pm    Post subject: Reply with quote
The Ctek M S 5.0 is fantastic. I was able to revitalize my old Banner battery(Only after investing in a new Bosch S5 of course). The standard pack comes with eyelets and crocodile connections which work shorterm but you can buy a ‘Comfort Connect Extension Cable’ 2.5 meters long. What I would recommend, if you’re not going to use the cigarette lighter, is the ‘Comfort Indicator with 8mm Eyelet adaptors’. The eyelets on this fit perfectly onto your battery whereas the one supplied are too small and need to be cut and widened to fit. It also has a quick release option on the cable and fuse. I’m not sure what year/model cigarette lighters are ‘live’ when the ignition is off, maybe the Illuminati could divulge?
Baz
993 C2, RSR's, Cargraphic 100 Cell Cat, Turbo Twist Hollows, Brembo Big Reds Turbo Brakes, Big Ovals, Wayne Schofield Remap, KW Supersport set up by Chris Franklin, RS engine and transmission mounts, Fabspeed induction kit, HID conversion...
GT917
PostPosted: Sat Dec 16, 2017 7:29 am    Post subject: Reply with quote
On my 1994 car, the lighter is alive even if the ign is off.
PostPosted: Sat Dec 16, 2017 9:35 am    Post subject: Reply with quote
So what's the difference (apart from the price) between a CTEK and one of These Dont know
jhrfc
1994 Porsche 993 Carrera 2
PostPosted: Sat Dec 16, 2017 10:57 am    Post subject: Reply with quote
I'm pretty sure a wiring mod needs to be made to make the lighter permanently live.
I think over the years a lot of cars have had this done. but it is not possible on tip cars. (i know cos i have one.).
I connected the eyelet cable to the terminals in the frunk and plug it in form there.
J
Allan E
PostPosted: Sat Dec 16, 2017 11:21 am    Post subject: C-tek Reply with quote
About £50!
I have a c-tek which I bought in 2008, still works but the led on the screen is kaput. I also have a similar one as Zingari suggests bought from my favourite German outlet, Lidl for £15, recommended.
1995 Carrera in Guards Red
1987 Mercedes 300SL (R107)
decgraham
PostPosted: Sat Dec 16, 2017 11:27 am    Post subject: Reply with quote
J
I have a 1995 TipS and the cigarette lighter is live with the ignition off and key out, maybe because it's US/EU spec Dont know it hasn't had any wiring mods.
ATB Smile
PostPosted: Sat Dec 16, 2017 11:45 am    Post subject: Reply with quote
I bought one of those in my link and it looks good quality.
I thought my cheapo Halfords tricke charger that came with the 964 was knackered but it wasn't and after 5yrs with me its still going strong worship
The CTEK seems to be the 993 'must have' accessory along with wiper widget, plastic nipple covers under the spoiler, rubber bungs to hide the mirror screws and undercarriage teats Rolling Eyes
Jet Jock
PostPosted: Sun Dec 17, 2017 11:17 pm    Post subject: Reply with quote
Jet Jock
PostPosted: Sun Dec 17, 2017 11:19 pm    Post subject: Reply with quote
nickjonesn4
PostPosted: Sun Dec 17, 2017 11:37 pm    Post subject: Reply with quote
I'm sure other chargers are good. The reality is that Ctek are the industry standard. All car storage operations and dealers use them because they work really really well. For the sake of £30 difference I would go for the CTek as it's total piece of mind.
The recondition function has cured a long running battery problem on my AMG.
1996 Carrera 2S Vesuvius Metallic
2016 Golf R
2005 E55K Wagon
911TEL
2011 Porsche 997 Turbo S
PostPosted: Mon Dec 18, 2017 8:16 am    Post subject: Reply with quote
C-Tek charger is my 1st choice ... it is a good piece of kit , easy to use , ergonomical controls are good and functions are adequate ..... MXS 5.0 is the best of them IMO
They are NOT infallible however and although supposed to be IP 65 I had a failure recently in our wintery weather when the snow melted of underside of DD car returned into the garage.... water seems to have got in ... I heard an unhealthy sizzling sound and it was tripping the RCD in the power circuit.
Replaced with the spare charger ( meant changing to the comfort connector tails direct to the battery, as it was the non-comfort early connector ) but now back up and charging ok.
I bought an Optimate to try out when opportunity permits and that one looks almost as functional as the C- TeK.
PS
There are instances though when the C-Tek smart charger ( and this type of charger ) cannot see the internal resistance of the battery if it drops too low ... it will not sense an start charging.
If you find that you have this , simply connect ( Viz mag wording ) a healthy battery in parallel until charging starts,then you may remove the healthy battery, the charger will only charge the unhealthy one obviously.
997 Gen 2 Turbo S Basalt Black -BBS CHR, Kline inconel exhaust, DSC V1 & Polished Bliss air freshener...
SL 55 AMG Obsidian Black
Brompton S2L Black edition
Citori
1996 Porsche 993 Carrera 2
PostPosted: Sat Jan 06, 2018 12:32 am    Post subject: Reply with quote
J
Hello.
I managed to modify my 1996 tip so that the lighter socket was live all the time. It was quite easy. It saves having to lift the bonnet each time you park the car and also reduces the risk of driving out the garage with the charger still connected.
You need to install a fused link (15A fuse)with a spade connector at each end from a perm live unused circuit in the fuse box to the the lighter socket.
It was a while ago now so I can't remember which circuit I used. You just have to make sure the circuit you link from is rated at about 15-20 Amp so the cig lighter will still work without causing problems with the wiring.
I used a CTEK on the 993, but I also have one of the cheap ones from Lidl which is excellent for the money.
The only working difference I have noticed between the two is that if you have a power cut (which happens regularly where I live) the CTEK will return to it's charging state and continue to work. Unfortunately the lidl one doesn't and just switches back to standby.
Previously enjoyed Porsche:
1996 C2 Coupe.
1983 911 Carrera Targa Sport.
1981 911SC Sport.
1978 911SC.
1970 911E.
I have CDO. It’s like OCD, but the letters are in alphabetical order, LIKE THEY ARE SUPPOSED TO BE..
Aircooled or nothin....
Albionmuz
PostPosted: Sun Jan 07, 2018 6:49 am    Post subject: Reply with quote
I recently bought a Ctek MXS 5.0 and have a couple of questions. I have removed the bonnet bulb and turned off the interior light which seemed to stay on when the bonnet was open, but the light that illuminates the ignition remains on. How can I use the charger and still be able to close the bonnet? Would I get away with leaving the cable coming out of the bonnet but then close the bonnet? I realise it would probably put an indent on the cable but can’t see a way to do it without having to remove the undertray to bring the cable through one of the grommet holes in the frunk.
993 Targa manual
Alfa GTV Twinspark
Citroen Deux Chevaux
Alfa 159 Sportwagon
Porsche 968 Cab Tip
Lexus IS 200
Jet Jock
PostPosted: Sun Jan 07, 2018 7:00 am    Post subject: Reply with quote
Hi Albionmuz,
I place the cable from the charger on the corner of the bonnet and gentle press the bonnet down. Second year doing this and with no issue. Hasn’t left a mark to date and means you don’t have to remove boot/frunk bulb.
HTH
Albionmuz
PostPosted: Sun Jan 07, 2018 7:05 am    Post subject: Reply with quote
Jet Jock wrote:
Hi Albionmuz,
HTH
Thanks for the very quick response. Do you mean the corner up by the window or at the side down by the bumper?
993 Targa manual
Alfa GTV Twinspark
Alfa 159 Sportwagon
Porsche 968 Cab Tip
Lexus IS 200
