991 : 2011-2019 0
997 : 2004-2012 1
Boxster : 1997- 22
Cayman : 2005- 14
Thefinn
PostPosted: Thu Nov 30, 2017 3:54 pm    Post subject: Techart springs Reply with quote
Following on from the lowering thread i thought i would get in touch with Parr to see what deal they could do on Techart springs if we get a group buy together.
As yet no deal on the table until they know numbers but the current retail price and lowering height is:
Techart spring kit £382+vat/uk delivery
Fits OE dampers 20mm ride height lowering (vehicles with PASM 15mm)
I don't actually need the springs yet as i have a warranty that doesn't run out till May, but if the price is right i will buy a set and sit on them till then. Boing!
anyone interested?
997.1 C4S CAB
RXP.
PostPosted: Thu Nov 30, 2017 11:15 pm    Post subject: Re: Techart springs group buy Parr Reply with quote
anyone interested?
I would be up for this. Parr is 10 minutes from me.
Just one small problem. I haven't actually bought a 911 yet. However that should change within the next week or so. Hopefully.
Thefinn
PostPosted: Fri Dec 01, 2017 8:27 am    Post subject: Reply with quote
they might do you a deal on fitting as well if you want it? I can check when i get back to them, although numbers look a little slow on the uptake so we don,t have much of a group yet
997.1 C4S CAB
squelch
PostPosted: Fri Dec 01, 2017 11:16 am    Post subject: Re: Techart springs group buy Parr Reply with quote
Fingers crossed with the search, RXP. But if you have no joy, and if we get enough group buy deals on parts, you could build one Mechanic
From Stuttgart: 997 GTS, 997 GT3 (Kermit)
From Munich: 535d M Touring
From Bologne: Ducati Superlight
Gone but not forgotten: 996 C4S, 964, 924
S14
PostPosted: Sat Dec 02, 2017 12:16 am    Post subject: Reply with quote
I may well be interested for a 997.2 turbo
wildej
PostPosted: Mon Dec 04, 2017 9:52 pm    Post subject: Reply with quote
Have you tried Tech 9 for group buy prices, they are the Techart distributor in the UK.
http://www.tech9.ms/techart
997 GTS
Previous
991.1 C4S
997.1 Turbo
997.2 C4S
997.2 Carrera
Thefinn
PostPosted: Tue Dec 05, 2017 1:08 pm    Post subject: Reply with quote
Hi Guys i have an update for you as i have got a better deal come through from Tech9 who have offered a set of springs for £399 including Vat and delivery. If we get 3+ confirmed they will offer a 12% off this price so do we have any more takers to see if we can better this. So far suggested takers are =
1. Thefinn
2. RXP
3. S14
997.1 C4S CAB
wildej
PostPosted: Tue Dec 05, 2017 2:25 pm    Post subject: Reply with quote
Aren't the Techart springs just rebranded Eibach ones ?
997 GTS
Previous
991.1 C4S
997.1 Turbo
997.2 C4S
997.2 Carrera
RXP.
PostPosted: Tue Dec 05, 2017 3:57 pm    Post subject: Reply with quote
In a word NO.
The techart license eibach to their own specification. If you look online you will see the eibachs have a different ride height to the techarts.
either are great.
But if it was me, I would choose the Techarts over the Eibachs and H&Rs for various reasons.
For me the Techarts are the pick of the bunch. Perfect ride height, OEM like ride quality and now thanks to Phil and Finn a great price.
RXP.
PostPosted: Tue Dec 05, 2017 4:00 pm    Post subject: Reply with quote
1. Thefinn
2. RXP
3. S14
Mr Finn,
Great work on the negotiations.
However I have been on the phone this morning to Design911 in regards to the OHLINS DFV.
I am debating as we speak to place an order with them. Just going to finish this coffee and see whats what.
PostPosted: Tue Dec 05, 2017 4:19 pm    Post subject: Reply with quote
Thats a good price Finn Thumb
I agree with RXP the techarts are the optimum ride hight etc they are not just rebranded eibach springs they are made by eibach but to a different spec for techart.
I had them on my gen1 and found them the perfect ride height not too slammed and the ride was virtually stock with the advantage of flatter cornering .
and most importantly unlike some other brands they did not continue to drop over time and use.
silvermilnec
PostPosted: Tue Dec 05, 2017 4:25 pm    Post subject: Reply with quote
I agree with RXP the teacarts are the optimum ride hight etc they are not just rebranded eibach springs they are made by eibach but to a different spec for techart.
Phil what are these like with speed bumps, mine are stock and I do love boba stance but not at the expense of a much firmer ride.
Cheers for any advice as always.
1998 968
2000 996 C2
2006 997 4S
2009 997 1.5 Turbo basalt black on black
PostPosted: Tue Dec 05, 2017 4:59 pm    Post subject: Reply with quote
[quote="silvermilnec"]
Cheers for any advice as always.[/quo
When I fitted them pre my aerokit it rarely scraped and if it did it was only either the tip air outlet plastic lip in the centre under the car or the two plastic lips infront of the front wheels. all of which caused minor scrapping. and might have needed replacing at some point if really worn or your ocd kicked in lol. the bits are under £20 each to replace and in reality maybe need to be done every couple of years.
after fitting the aero the lower front lip would scrape as well as the other 3 bits not as often and not on speed bumps but on slopes in carparks etc . this never happened with the stock front bumper fitted when it was first lowered. but the front lip ids only £185 and again might need replacing every couple of years . bearing in mind I was doing 15k pa in mine and it lasted 18/20 months before getting the front lip replaced.
For me the small cost to replace these few plastic parts was well worth it to get the stance and improved handling right on the car. Thumb
the nice thing with the techarts is they only drop 15mm on pasm cars and 20mm on non pasm cars which considering some others drop 25/30mm is the reason I preferred them as its a nice balance of lower but not too low.
I wanted to still have a small gap between the tyre and the arch lip so it looked less slammed and just nicely lowered.
The actual ride with techarts was almost the same as stock so not firmer in a negative way at all
heres a few pics of how mine looked with TECHARTS Thumb
 Filesize:  78.94 KB
 Viewed:  7937 Time(s)
 Filesize:  101.4 KB
 Filesize:  163.02 KB
 Filesize:  120.58 KB
 Filesize:  78.37 KB
 Filesize:  180.71 KB
Thefinn
PostPosted: Tue Dec 05, 2017 5:14 pm    Post subject: Reply with quote
no worries RXP just keep us update on what you decide as I hope we get a few more takers to make up the numbers anyway.
with regards to the eibach springs, I had them fitted on my last 997 and they felt fine but the back of the car didn't drop enough for my liking so want to go Techart this time as the stance looks more even on both arches
997.1 C4S CAB
silvermilnec
PostPosted: Tue Dec 05, 2017 5:34 pm    Post subject: Reply with quote
cheers Phil!!
1998 968
2000 996 C2
2006 997 4S
Arabduke
PostPosted: Tue Dec 05, 2017 9:37 pm    Post subject: Reply with quote
If going for these what other low hanging fruit can be done at the same time or is worth checking/replacing?
PostPosted: Tue Dec 05, 2017 11:23 pm    Post subject: Reply with quote
I Would be looking at doing spacers and braded brake lines while I was in the arch area. Thumb Thumb
roocat
PostPosted: Wed Dec 06, 2017 9:13 am    Post subject: Reply with quote
Morning chaps, i may be interested in joining this buy.
Just to confirm, these would be ok on a Gen 2 C2S and would lower by 15mm all round?
cheers thumbsup
RXP.
PostPosted: Wed Dec 06, 2017 5:47 pm    Post subject: Reply with quote
[quote="Phil 997"]
BAD and ASS.
No further comments your honour.
RXP.
PostPosted: Wed Dec 06, 2017 5:48 pm    Post subject: Reply with quote
Hey Finn,
I have decided.. finally.
I am 911% going to go with the Ohlins. (I got the car now btw lol).
Goto page 1, 2, 3, 4  Next
Page 1 of 4
