997 : 2004- 71
964 : 1989-1993 6
Boxster : 1997- 21
Cayenne : 2003- 4
Ozzyz
PostPosted: Mon Nov 27, 2017 3:20 pm    Post subject: 18" Fuchs Fitment Reply with quote
As its "Cyber Monday" i thought it would be a good idea to treat the car to some new wheels. I've always wanted a set of the Otto Fuchs so i went ahead and ordered a set from Design911 saving 10% on the price.
The specs of the wheels are :
Front 18x8 ET52
Rear 18X10 ET65
Is anyone else running these size wheels atm? and are you using spacers front or rear?
With the rear offset at ET65 I'm worried the wheel would need bringing out a touch at the back.
Interested to hear other peoples thoughts Question
997.1 GT3 RS
964 C2
Cayenne S (E-Hybrid)
ELA
PostPosted: Mon Nov 27, 2017 3:44 pm    Post subject: Reply with quote
Hi Ozzy, do you know what the dimensions are of the wheels you currently have fitted (including ET's), then I'll calculate how the new ones will fit in comparison
CLR996 1086kg bespoke design
Ozzyz
PostPosted: Mon Nov 27, 2017 3:57 pm    Post subject: Reply with quote
Hi ELA
I currently have 17" Cup 1 reps on, specs are:
Front 7.5J ET52
Rear 9J ET47
I'm thinking the new wheels would need 18 or 20mm spacers on the back as currently they fill the arch out nicely with the offset at ET47 on the Cup 1's
997.1 GT3 RS
964 C2
ELA
PostPosted: Mon Nov 27, 2017 4:30 pm    Post subject: Reply with quote
New fronts will stick out an extra 6mm but there will be 6mm less inner clearance.
Rears will sit in a further 5mm but you will lose 31mm inner clearance on the (suspension arms...)
cableguy
PostPosted: Mon Nov 27, 2017 5:31 pm    Post subject: Reply with quote
You might be lucky with these. OEM 964 RS Mags are 9j Rears with an ET55 offset, so basically 10mm more aggressive than the Fuchs and an inch narrower.
The wheels you have bought are NB 993 sizes. Fronts should be fine but the rears may need an arch tickle depending on tyre choice.
C.
Pork!
Gazc2
PostPosted: Mon Nov 27, 2017 6:35 pm    Post subject: Reply with quote
Paul has the Fuchs on his 964 (think 18)worth a read here
http://www.911uk.com/viewtopic.php?t=82941&start=1360&postdays=0&postorder=asc&highlight=
2007 997 Turbo & 924s in progress
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
paul284pt
PostPosted: Mon Nov 27, 2017 8:04 pm    Post subject: Reply with quote
Hi Ozzy,
As my old pal Gaz correctly points out (he's always right ha!) you will definitely need spacers with 18" Fuchs as you will be rubbing on off-side oil cooler pipe.
I have 18mm H&R magnesium alloy bolt on spacers on the rears and same (not bolt on) @ 5mm on the fronts, I couldn't get 7mm's at the time. Depending on your tyres you may still get a slight rub on your front arches on full lock.
Cheers,
Paul
1980 - 84 924 Turbo with mods. (ex Tony Dron - 12th at Le Mans 1980 with works 924 Carrera Turbo).
1984 - 89 911 SC (1982)
1989 - 93 911 Carrera Sport (1989)
2010 - 964 Carrera 2 (1990) Redtek 3.8RSR
2012 - 14 Porsche Cayenne (2012)
2015 - 17 Porsche Cayenne Diesel S (2015)
2017 - 18 Macan Turbo Performance Package (2017)
2018 - 991.2 Carrera 4 GTS (2018)
Ozzyz
PostPosted: Mon Nov 27, 2017 8:45 pm    Post subject: Reply with quote
paul284pt wrote:
Hi Ozzy,
Cheers,
Paul
Hi Paul
I thought I may need a set on the back. Do you by any chance have the part number for the 18mm H&R spacers you are using? I'm finding it a bit tricky to track them down, there seems to be 15 and 20mm available for the 964 but I can't find 18mm. Unless they are the same as 993 spacers kits Dont know
Thanks for all the replies so far all thumbsup
997.1 GT3 RS
964 C2
paul284pt
PostPosted: Tue Nov 28, 2017 8:06 am    Post subject: Reply with quote
Hi Ozzy,
I bought mine from JZM Porsche your contact in Parts & Service would be Simon.
https://www.jzmporsche.com/shop/shop/alloy-wheels/
Good luck,
Paul
Ozzyz
PostPosted: Tue Nov 28, 2017 8:37 am    Post subject: Reply with quote
paul284pt wrote:
Hi Ozzy,
Good luck,
Paul
Thank you Paul, I will give JZM a ring and get a set ordered.
997.1 GT3 RS
964 C2
Mondrian
PostPosted: Wed Nov 29, 2017 3:04 pm    Post subject: Reply with quote
I have recently put MY02 18 x 8(50) & 10(65) wheels on my 964. I used 7mm spacers on front with PS4 225/40 tyres & 18mm with PS4 265/35 tyres on rears with a ride height of RS + 10mm. I haven't had any problems with tyre rub but while fitting we noticed that the geo wasn't symmetrical as tyre to arch clearance/placement wasn't the same between left & right so had a basic geo refresh done at the same time. Will probably head to CG for a proper geo in the new year as I'd like to drop it by another 5mm and fine tune the geo.
I did have a suspension refresh prior to fitting them with PSS10 coilovers and refreshed/upgraded a few parts due to additional stress that 18's place on the front - Front wishbone bushes (Super Pro PU), 993 steering rack stabilizer, new top mounts rubber, upgraded track rod inner joints to RS. Would have liked to upgrade the steering knuckle to RS but couldn't find one in time.
Ozzyz
PostPosted: Thu Nov 30, 2017 10:11 am    Post subject: Reply with quote
Hi Mondrian
That is interesting info. I have KWV1 suspension set to RS ride height & camber settings on the car so I'm assuming it will be very similar to yours. Definitely worth doing the geo refresh to be certain.
Were you advised to run with the 7mm spacers on the front?
997.1 GT3 RS
964 C2
Mondrian
PostPosted: Thu Nov 30, 2017 11:17 am    Post subject: Reply with quote
Usual advice is to fit 5mm in front and 21mm on rear but I fitted the 18’s with tyres on prior to ordering the spacers and figured there was enough room for 7mm besides I couldn’t find any 5mm, Porsche do one but it’s for 993 which has a lip so won’t fit 964. On rear I could probably clear the oil line with 15mm but decided to play it safe and use 18.
I am very happy with how the 18’s handle on A & B roads, nothing like the horror most go on about and that’s on a setting of 5 on PSS10, but then again I was happy with my RS clutch driving in central London on a Friday afternoon on my maiden voyage post op. I think the key is to attend to the small complimentary details such as front suspension rubber ware or good mapping in case of lw clutch.
 Filesize:  149.38 KB
 Viewed:  6607 Time(s)
kitesurfer
PostPosted: Thu Jan 18, 2018 5:40 pm    Post subject: 18" wheels Reply with quote
Just a quick note to say I have just gone back to 17" Cups from 18" same spec you mention.
Suspension is KW3 and I found the ride a bit harsh and unpleasant compared with the cups.
Incidentally I left the 2cm rear spacers on the car and the 9"Cup rears look great.
Chief
PostPosted: Sun Jan 21, 2018 9:40 pm    Post subject: Re: 18" wheels Reply with quote
I agree here. PeterS and myself spent a lot of time driving his car with both 17's and 18's for the day back to back. We both now run 17's.
- 964 C2 The Red Baron - 914 2.0 Project Blue Book - Cayman S Sport Edition Amber Alert! -
Instagram - @chiefporsche
Ozzyz
PostPosted: Thu Mar 01, 2018 9:15 am    Post subject: Reply with quote
I'd love to post an update about how the wheels fit and ride but the truth is I'm still waiting for the wheels to arrive what
I've been in contact with Design911 on numerous occasions regarding updates but they keep telling me the Fuchs factory in Germany keep delaying delivery times due to production issues.
Just wondering if anyone else has ordered Fuchs wheels in the last few months and how long you've been told they would take to arrive?
997.1 GT3 RS
964 C2
Jay.
PostPosted: Thu Mar 01, 2018 12:47 pm    Post subject: Reply with quote
Might be worth asking them to put you in contact with the Fuchs representative, so you can talk to them direct.
2004 996 Turbo
Seal Grey
Motec 19" Alloys
AMG Flappy Paddles
1972 Datsun 240z
RB25DET
Devil Z
Follow me on Instagram! @rb.240z
crash7
PostPosted: Mon Mar 05, 2018 4:33 pm    Post subject: Reply with quote
For those of you that are running 10" rear wheels what was your target ET? For a narrow body car.
I have a pair of 10" Speedlines that I am looking to fit and need to work out what size spacer I need, ET of the wheels is 56 so I was planning on a 10mm to get to 46, but I see most are using 15-18mm spacer? Dont know
Ozzyz
PostPosted: Fri Apr 27, 2018 11:11 am    Post subject: Reply with quote
Well after a long wait the wheels finally landed in the UK and I took them straight to RPM Technik as my car was already with them having a major service.
After a few test fits and drives they got the car set up to a height they were happy with and that was safe for normal road driving.
The car was previously set to RS height and geo settings so if left as it was with the new wheels there was a serious case of arch rubbing and uneven tyre wear.
The 18mm H&R spacers on the rear just about cleared the the oil pipe by a fingers width, extremely close!
So with the suspension raised a touch and new geo done overall I'm very happy with the look and drive.
thumbsup
997.1 GT3 RS
964 C2
 Filesize:  1.15 MB
 Viewed:  4510 Time(s)
 Filesize:  1.21 MB
 Filesize:  1.35 MB
PostPosted: Fri Apr 27, 2018 2:44 pm    Post subject: Reply with quote
Looks great Thumb
