997 : 2004- 61
996 : 1997-2005 29
Boxster : 1997- 26
AdeD
2010 Porsche 997 Turbo
PostPosted: Wed Nov 15, 2017 11:03 pm    Post subject: Reply with quote
maph wrote:
Be really interested in how it compares to the ES650 kit you were running. It is obviously quicker, but can you feel the difference and does it deliver the power any differently? How does it put the power down, any traction issues?
Yes, put it this way on the road it's noticeable enopugh to make me want to upgrade to the 700 package Very Happy
On paper it doesn't seem as much but when you convert times to how far the car has actually traveled it is quite an improvement...
I don't know RIGGERZ vbox times but here is a comparison of the 2 packages below from another ES700, obviously all cars are slightly different but RIGGERZ will be very similar (Ignore the 0-xxx times as i had traction issues with old worn tyres, the PS4S fitted now are MUCH better) Cool
997.2 Turbo | 19" HRE's | BBI Cage | Ohlins | H&R Front & Rear ARB's | GT2RS Carbon Seats | DesignLS Custom Retrim | DO88 Intercoolers, Y-Pipe & Inlet Hoses | IPD Plenum | WaterMeth Injection | Equal Length Headers & 3" DeCat Exhaust
 Filesize:  108.48 KB
 Viewed:  3655 Time(s)
Desert Dragon
PostPosted: Thu Nov 16, 2017 7:17 am    Post subject: Reply with quote
So in real money that puts the ES 700 kit at 786bhp at the flywheel? Seems slightly conservative dyno considering the cars weight and those performance figures.
Here's a McLaren 720 S over those same performance stats. You'll note both the ES 650 and 700 would give it a hard time and that car is circa 500bhp per ton. The 997 turbo would need at least 800bhp to equal that 500 bhp per ton the McLaren has.
Think the ES 700 needs to be called the ES 800 or ES 850 Wink
VBOX never lies.
 Filesize:  785.33 KB
 Viewed:  3617 Time(s)
Riggerz
2010 Porsche 997 GT3 RS
PostPosted: Thu Nov 16, 2017 9:25 am    Post subject: Reply with quote
the Es650 kit is very good what i have found with the Es700 is how smooth it is because off the amount of time spent actually tuning it. It has a bit more power low down but things start to happen once the METH starts to come on, the power just ups and in damp conditions can get a bit side ways
Discovery 4 2014
997.2 Turbo S Cobb Accesport EsMotor tuned Es catless exhausts and headers Do88 intercoolers IDP inlet Plenum DO88 Y Pipe DO88 Boost pipes 3 Bar Map Sensors Forge Diverter Valves BMC Air Filter Meth Injection Cobb PDK Tune 2011
cayenne Diesel 2011 sold
911GT3RS 2010 sold
GT-R 35 2010 sold
 Filesize:  67.29 KB
 Viewed:  3586 Time(s)
maph
PostPosted: Thu Nov 16, 2017 12:56 pm    Post subject: Reply with quote
Impressive figures for both kits and as DD says they compare well to the MCL 720s which in real world terms is apparently as fast as a MCL P1.
Thanks good to hear a comparison between the two. I still find it amazing how much power these cars can put down without losing much traction. Are you running standard wheels/ sized tyres?
Did you have a previous dyno readout of your ES650 kit as a comparison? Not sure if you have one Ade?
2012 997.2 Turbo S - ES650
Riggerz
PostPosted: Thu Nov 16, 2017 3:26 pm    Post subject: Reply with quote
Hi AdeD sorry I don’t have dyno figures from the 650 kit. I’m running original turbo s wheels with Centre lock and Michelin pilot super sport must say these things grip unreal in most conditions
Discovery 4 2014
911GT3RS 2010 sold
GT-R 35 2010 sold
AdeD
PostPosted: Thu Nov 16, 2017 6:00 pm    Post subject: Reply with quote
No, mines never been put on the dyno, i have no idea what bhp i'm putting down... vbox estimated it at 720 once but tbh i don't know how accurate that is.
maph
PostPosted: Thu Nov 16, 2017 8:02 pm    Post subject: Reply with quote
Thanks guys. Mine is running the ES650 kit and likewise, I have no idea what it is putting out. Goes well though Very Happy
Not sure if I need more power or the complication of meth, but fair play to those that do!
AdeD
PostPosted: Thu Nov 16, 2017 8:23 pm    Post subject: Reply with quote
lol, it's not complicated, driving normal you don't use any, it must have been about 2 or 3 months since i last topped it up...
Riggerz
PostPosted: Thu Nov 16, 2017 10:15 pm    Post subject: Reply with quote
Spot on AdeD
Discovery 4 2014
911GT3RS 2010 sold
GT-R 35 2010 sold
Desert Dragon
PostPosted: Sat Nov 18, 2017 8:25 am    Post subject: Reply with quote
So all hardware being the same the only difference is software between ES650 and ES700?
Whats the maximum boost Ade's car runs and max boost for Riggerz car? I imagine in 5th and 6th its holding onto this max boost all the way to red line?
Riggerz
PostPosted: Sat Nov 18, 2017 10:22 am    Post subject: Reply with quote
Hi mate the difference in the 2 packages is meth see photo. mine is now running 1.65 peak and backs down to 1.6 off peak but its not just the boost it's the cam timing and the variable (vanos not to sure on spelling) can be moved due to running about 15 degrees cooler
Discovery 4 2014
911GT3RS 2010 sold
GT-R 35 2010 sold
 Filesize:  165.64 KB
 Viewed:  3292 Time(s)
 Filesize:  154.1 KB
Desert Dragon
PostPosted: Sat Nov 18, 2017 10:43 am    Post subject: Reply with quote
Ah got you now. So Ade's is also an ES700 not an ES650? His car just ran a bit slower due to worn tyres which makes sense?
Thats a lot of boost by the way. Really impressed the cars holding onto all that boost.
Riggerz
PostPosted: Sat Nov 18, 2017 10:59 am    Post subject: Reply with quote
At this moment I can’t fault it and the way these things still grip even after a tune is amazing. I put new rubber on mine before the last upgrades and unless it’s wet it grips
Discovery 4 2014
911GT3RS 2010 sold
GT-R 35 2010 sold
AdeD
PostPosted: Sat Nov 18, 2017 11:02 am    Post subject: Reply with quote
Mines more of a custom setup as i'm running meth but still on stock headers and coolers...
ironside
PostPosted: Wed Dec 06, 2017 12:07 am    Post subject: Reply with quote
Riggerz wrote:
Cheers the Es700 kit as made it into a proper beast mate
Glad you are Happy Ian,i'm running the ES650 Kit,with Cooler's & Exhaust Header's on my ES Exhaust,i'm very Pleased,has i'm Driving 1 Handed using Hand Control's i'm not upgrading to Meth,it's good to Know there are option's i can do,if i get Bored(which ain't going to Happen) Enjoy your car Buddy,She's Certainly a Weapon Now worship
Regards,
Ironside (Ian) Thumb
Desert Dragon
PostPosted: Sat Sep 07, 2019 1:15 pm    Post subject: Reply with quote
Hows reliability been on this kit a few years on?
Goto page Previous  1, 2
Page 2 of 2
