When I open the passenger door the window drops as it should but once the door is open the window it goes back up as if the door is closed then continues to do that the whole time the door is open. If I pull the door handle it will stay down.
Has anyone experienced this before or does anyone know what the likely cause is before I either attempt a self fix or get someone to take a look
