997 : 2004- 57
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
coullstar
PostPosted: Thu Jan 04, 2018 10:41 am    Post subject: Reply with quote
Wee present to myself arrived yesterday.
 Filesize:  459.79 KB
 Viewed:  4000 Time(s)
NLW73
PostPosted: Sat Jan 06, 2018 9:06 am    Post subject: Reply with quote
Very nice n coming on well.
Be interested to see how the 200 cell cats go. Are you getting it re mapped too?
Do folks put the gt3 74 mm tb and ipd plenum onto the 3.4 engines to get a bit more air flow and power out? Could be a good mod with the 200 cells and re map
997 C2s Schwarz
coullstar
PostPosted: Sat Jan 06, 2018 10:54 pm    Post subject: Reply with quote
No remap for me, don't think there is a larger TB for the cable throttle cars.
coullstar
PostPosted: Wed Jan 17, 2018 9:31 am    Post subject: Reply with quote
So Id thought about going with black wing mirror caps and a black side decals just for something a little different but then like the styling package that the new 991 Carrera T come with so Im going to try replicate that.
Hopefully it will be on the subtle side. First piece bought, some seal grey wing mirrors so I'll swap over the caps. Next I was looking at the side decal as per the 991 as its not OTT. I quite like it and was going to get it in the same colour to match the wing mirrors. Only thing Im not sure on is the text, should I put Carerra or Carerra 2 or just leave blank? Im erring on no text.
Last part would be refurb the wheels in the same colour. I think this will all tie in well and its all easily reversible.
Thoughts?
 Filesize:  173.11 KB
 Viewed:  3796 Time(s)
 Filesize:  270.3 KB
 Filesize:  239.47 KB
NLW73
PostPosted: Mon Jan 22, 2018 6:40 pm    Post subject: Reply with quote
I think it will look good on a C2 as they are not as fussy as a turbo or GT car down the flanks with all the vents and spoliers.
you will need dark wheels though to carry it off as it will look a bit odd? especially with black mirrors.
did you put the 200 Cells on and thoughts?
997 C2s Schwarz
coullstar
PostPosted: Mon Jan 29, 2018 1:48 pm    Post subject: Reply with quote
Still doing a running period to check oil again and sump off for tensioner bits so not really doing adding anything until that's all clear.
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Mon Jan 29, 2018 1:55 pm    Post subject: Reply with quote
I remember your 4S... you got that looking great if I recall.
Itll be interesting to see this one coming together.
coullstar
PostPosted: Thu Feb 01, 2018 1:32 pm    Post subject: Reply with quote
Thanks, didn't do much to the 4s when I had it. Helped with a nice spec from factory.
As per my other thread Ive found no more issues with the engine so Im happy its alright to start the changes.
So much so I stumbled upon these at lunchtime on ebay with 15min left so bid and won them. Chuffed as there the exact spec I would order from new. 8in et50 and 10in et40.
They have really good winter tyres fitted so I'll throw them on then swap over the summer tyres from the Panamera's when its nice weather again.
Probably sell the Panamra's on, maybe with the winter tyres all fitted if anyone is interested Thumb
 Filesize:  127.31 KB
 Viewed:  3741 Time(s)
Fast Bug
PostPosted: Fri Feb 02, 2018 8:42 pm    Post subject: Reply with quote
Nice! I'm hoping mine will be wering a set later this year
coullstar
PostPosted: Mon Feb 05, 2018 11:43 pm    Post subject: Reply with quote
Managed a few jobs tonight, decided I'd not inspected rads yet so bumper off. I decided to take out arch liners as well to inspect the inner sills as well.
They appear okay with very minimal surface corrosion which I rubbed where I could and sprayed in some stone chip I had sitting and also treated some very small bits on the inner arches as well. Ordered some Dinitrol cavity wax to get right in. Need to get in from rear end as well.
Rads were all fine so cleaned up. Drilled a few drain holes in the shrouds at lower rear so help with flushing out when power washing.
I had some mesh sitting around so put that on bumper to stop leaves getting into rads. Also tried out this universal splitter I had, the car had a small lip spoiler from aero kit but this is wider. Not the best close up if I'm honest but I'll see what its like.
Just waiting for these wheels then I'll look at getting exhaust and LTT done.
 Filesize:  344.08 KB
 Viewed:  3712 Time(s)
 Filesize:  346.23 KB
 Filesize:  1.27 MB
 Filesize:  1.25 MB
PostPosted: Tue Feb 06, 2018 9:03 am    Post subject: Reply with quote
Lip spoiler looks KaO to me Grin
coullstar
PostPosted: Thu Feb 08, 2018 10:08 pm    Post subject: Reply with quote
Inner Sills all coated with cavity wax along with the seam and lower section on the rear arches. I coated rear arch pieces with stone chip as well. Was going to leave the arch trim off but refitted and will remove to wash it out after 6 months for a look.
Note brown sections are the cavity wax not rust.
 Filesize:  1.17 MB
 Viewed:  3686 Time(s)
coullstar
PostPosted: Fri Feb 09, 2018 6:13 pm    Post subject: Reply with quote
Wheels arrived today out of nowhere, they had appeared to have been lost.
Rushed home from work keen to check rears and they fit, just. Tyre has a very small poke but I'm fine with it. Fronts I might get away with 15mm spacer to even out track increase as much as possible but I'll try 9mm to start with.
In the house getting waxed at the moment.
 Filesize:  545.69 KB
 Viewed:  3674 Time(s)
 Filesize:  413.17 KB
coullstar
PostPosted: Sat Feb 10, 2018 10:41 am    Post subject: Reply with quote
Wheels on. Fit well.
 Filesize:  672.56 KB
 Viewed:  3667 Time(s)
 Filesize:  884.84 KB
PostPosted: Sat Feb 10, 2018 4:56 pm    Post subject: Reply with quote
Look bl00dy well too! Cool
wasz
Paul Ricard
1999 Porsche 996 Carrera 2
PostPosted: Sat Feb 10, 2018 5:07 pm    Post subject: Reply with quote
Are they widebody offset? I drove a car with widebody rears once and the tyres touched arches on bumpy roads.
Fast Bug
PostPosted: Sat Feb 10, 2018 5:22 pm    Post subject: Reply with quote
Wheels look great!
coullstar
PostPosted: Sat Feb 10, 2018 6:29 pm    Post subject: Reply with quote
There 10in et40 so low offset for narrow body. Fronts I have 15mm spacers fitted to even out track increase a little. No scrubing when I went for a quick drive earlier over some bumpy back roads.
kas750
Shanghai
2006 Porsche 911
PostPosted: Sat Feb 10, 2018 6:45 pm    Post subject: Reply with quote
Looking good thumbsup
coullstar
PostPosted: Sun Feb 11, 2018 7:02 pm    Post subject: Reply with quote
Dirty shot.
 Filesize:  1.34 MB
 Viewed:  3644 Time(s)
Goto page Previous  1, 2, 3, ... 20, 21, 22  Next
Page 2 of 22
