PSE valves - what to take off to see them
Scully
19 Apr 2017
105
Hi All,
Hopefully an easy question - I need to see the PSE valves and potentially adjust the throw on the valves on my PSE exhaust.
Do I simply need to remove the rear plastic bumper ('cover') or is there more that needs to come off?
Dave
Remove the bumper and then the heat shield behind it.
Thanks - do the heat shields come off as easily as the rear bumper?
Dave
Scully said:
Dave
Yeah they do - think there's 4 nut/screw things on each side. only bit to be careful of is the sides. They are joined to the rear heat shield and if you're too quick you could snap it
They come off easily if the nuts aren't corroded. Mine were a right PIA to remove.
Thanks all - we'll see how easy they are.
I've recently had a new valved exhaust fitted and need to check the throw of the valves, so if the garage needed to take them off to fit the system, then they should be easy!
Dave
124,590
1,441,841
49,020
cooper9000
