997 : 2004- 77
996 : 1997-2005 40
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 11
Stephenjk
PostPosted: Wed Nov 01, 2017 7:34 am    Post subject: Any ideas why touchup paint would do this? Reply with quote
I have a guard red 964 which I've had for a month and it has been touched up but touch up paint is darker than body colour. Do you think a prior owner has touched up in wrong colour or can the touch up paint age quicker than the normal paint? Anyone seem something similar?
 Filesize:  353.89 KB
 Viewed:  4675 Time(s)
Bonnet
 Filesize:  362.2 KB
Jcx
Estoril
2010 Porsche 997 Turbo
PostPosted: Wed Nov 01, 2017 8:17 am    Post subject: Reply with quote
Congrats on the car. I used to have a red c2 964. Great car. Enjoy.
Re the touch up. Looks like an old and poor effort. Try Chipex.co.uk.
PeterS
2003 Porsche 996 Carrera 2
PostPosted: Wed Nov 01, 2017 11:09 am    Post subject: Reply with quote
Welcome
Nice car. Regarding the paintwork, it looks like there was some ***** between the floor and the aerosol.
Very Happy
Stephenjk
PostPosted: Wed Nov 01, 2017 11:22 am    Post subject: Reply with quote
Thanks for your replies. If i do a good enough job redoing this ill post a before and after.
Thanks for comments on car, i got it from phil raby, it is this one if you are interested in taking a look https://youtu.be/nYAg-P0iVK8
Stephen
easternjets
PostPosted: Wed Nov 01, 2017 12:38 pm    Post subject: Reply with quote
Red is a very difficult colour to match, even when done professionally. Normally the only touch up that will match in perfectly is the one filled from the batch that was mixed when they sprayed the car.
You may need to go to a professional outfit to get a good match.
I had a bad chip on my bonnet and it took a week to build it up to the right depth so that it almost disappeared, fill it-let it dry-smooth down-fill again and so on.
997 Turbo Gen 2
997 Turbo Tiptronic S
Porsche 968 Coupe 1992
Porsche 928 S4
Porsche 911 3.2 Carrera 1985
Stephenjk
PostPosted: Wed Nov 01, 2017 12:45 pm    Post subject: Reply with quote
What do you smooth it down with inbetween layers? Fine sand paper by hand? Id worry my da is too big.
Jcx
Estoril
Thanks for comments on car, i got it from *****, it is this one if you are interested in taking a look https://youtu.be/nYAg-P0iVK8
Stephen
Gorgeous. Love the linen interior!
easternjets
PostPosted: Wed Nov 01, 2017 12:54 pm    Post subject: Reply with quote
First of all I build up the paint, that may take 3 or 4 dabs of touch up. Then let it dry for a day at least, then rub it gently with some 'T' cut, keep an eye on the level of the paint, when it's about level add some more and so on till you build it up to the same level as the original paint.
It is a bit of a laborious job but it only takes a few minutes each day, Black is probably the easiest colour to do.
Another tip is make sure the paint is warm, cold paint doesn't run nearly as well as warm paint. I normally stand the touch up in very warm water for 10 mins then use it.
There's also that 'warm' feeling when you get it just right and the chip is pretty much invisible.
997 Turbo Gen 2
Porsche 928 S4
Stephenjk
PostPosted: Wed Nov 01, 2017 3:08 pm    Post subject: Reply with quote
Thanks that is very helpful, will give that a go. It really stands out at the moment so would be great if i can fix it.
Stephenjk
PostPosted: Wed Nov 01, 2017 3:12 pm    Post subject: Reply with quote
Thanks, i liked it and leather has stood up very well to the 106k miles.
deutschland-dobson
PostPosted: Wed Nov 01, 2017 5:15 pm    Post subject: Reply with quote
Looking good!
Not many of us left with Linen interior, most swap to black. I love the look though!
Chris
Porsche 911 (964) C4 - Project RED - Outlaw4
Guards Red & Linen, Custom Leather, BBS LM Split-rims, H&R Coilovers, Cleaned Bodywork, 90s audio instal...
seeforez
PostPosted: Wed Nov 01, 2017 6:24 pm    Post subject: Reply with quote
Bit shocked the dealer didn't tidy that snot up before selling it Question
backitoff
PostPosted: Fri Dec 01, 2017 3:10 pm    Post subject: Reply with quote
Most likely that you need to really shake the touch up in order to be sure all of the colours that make up your touch up mix together when you need to use it.
There Will be 5 + (different) colour ingredients which make the colour ‘Guards Red’
Previous to current.......
993 C4 Coupe - 996TT Coupe - 3.2 Carrera Sport - 964 C2 Coupe.
Wish list.... 997 GT3 comfort spec.
