964 : 1989-1993 6
Boxster : 1997- 18
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
C2 YYY
PostPosted: Tue Oct 31, 2017 8:32 pm    Post subject: Intermittent Warning light. Reply with quote
Following on from my very expensive high beam fault. I now have an intermittent main warning light indication.
When I accelerate hard or when I hit a bump in the road, the main warning light flashes on. Initially I thought it was
A) one of the failed levels needing topping up.
B) the alternator belt slipping
C) handbrake or rear spoiler indicator.
All have been checked and no fault found.
Any better ideas?
Many thanks.
1990 964 C2 (manual) - a bit "Ruf"ed up
Chief
PostPosted: Tue Oct 31, 2017 9:35 pm    Post subject: Reply with quote
These intermittent faults can be erksome can't they !!!
My feeling is something has been disturbed in the fuse box.
If your mechanic has been rooting around in there he could have caused this.
Have you tried completely disconnecting the battery for an hour to reset the DME?
How's the main earth to the battery?
Also there are a number of earthing points including some behind the dash that should be investigated.
Keep us in the loop and we'll figure it out.....
- 964 C2 The Red Baron - 914 2.0 Project Blue Book - Cayman S Sport Edition Amber Alert! -
Instagram - @chiefporsche
C2 YYY
PostPosted: Wed Nov 01, 2017 10:21 pm    Post subject: Reply with quote
Many thanks, as it happens the high bean problem was caused by a loose connection in the fuse box, so shall start there.
Had not considered disconnecting the DME,so will give that a go as well.
Cheers.
