997 : 2004- 86
996 : 1997-2005 42
993 : 1993-1998 6
Boxster : 1997- 15
Cayman : 2005- 14
Macan : 2014- 0
Cameltoe & Heel
PostPosted: Tue Oct 31, 2017 8:22 am    Post subject: Varioram Intake Reply with quote
Folks,
my engine is on a stand at the moment and I'm doing the usual cam cover seals, cam chain cover seals, plugs, leads, dissi, diss arms etc etc.
Other than being fairly grubby all seems well and she turns over nicely so I'm not going with a full rebuild at this stage (104k).
I have an oil leak from the lower Varioram actuator, I've removed the actuator and the shaft seals are shot (in fact one of them was missing as there is meant to be two) so ordered new seals from OPC.
I'm considering whether to pull the varioram intake off to allow me to test the varioram itself and enable easier cleaning of the surrounding engine parts. Anybody have experience of this?, any tips?, also what have you used to clean the varioram intake itself?, all tips appreciated Smile
Trev
A993LAD
PostPosted: Tue Oct 31, 2017 1:06 pm    Post subject: Reply with quote
I have no experience of doing this, but I have seen it done on Wheeler dealers - the Mike Brewer/Ed China program.
Have you seen the episode where they refurbish a 993 Targa?
I'm sure it's available online somewhere and it was repeated on TV last week. I think.
Anyway, Ed China has to repair the varioram unit as well as seeing him remove and strip it down to an extent he does also provide some good narrative and demonstration about how the thing works.
It didn't look too complicated to remove or work on from what I recall, but worth checking out the program. If you can find it.
cableguy
PostPosted: Tue Oct 31, 2017 1:50 pm    Post subject: Reply with quote
Wheeler Dealers 993 Episode here: https://www.youtube.com/watch?v=7jebYHRhvnk
Varioram stripdown starts at 18.30 Wink
C.
Pork!
madalaa
2009 Porsche Boxster 987
PostPosted: Tue Oct 31, 2017 2:38 pm    Post subject: Reply with quote
I haven't seen this episode I will look forward to watching later ....... thanks for posting the link ...... Smile
Cameltoe & Heel
PostPosted: Tue Oct 31, 2017 8:13 pm    Post subject: Reply with quote
Yeh I have seen it a number of times, well it's all off the engine now so time to get it all sorted and the rest of the engine cleaned up.
Trev
madalaa
PostPosted: Wed Nov 01, 2017 8:05 am    Post subject: Reply with quote
The quality of the reproduction was so bad I couldn't watch it and failed to find a better quality version ....... but I am sure I will catch up with some other time when it's a repeated.
P-Tek
PostPosted: Thu Nov 02, 2017 10:44 pm    Post subject: Reply with quote
Hey,
Which seals is it your replacing on the actuator ? there's the black one that seals the manifold to the unit and there's a shaft seal inside the unit, id change both personally.
If you simply want to remove the manifold its fairly straight forward to remove it few jubilee clips, wiring plug for the evap valve, knock sensor wiring, cylinder head temp sensor and crank sensor wiring, fuel pressure regulator vac line and wiring plugs for the solenoids for the vario ram its self and that's pretty much it i think ...
if you have a vacuum tester check all actuators are working and holding pressure well. there probably wont be much (dirt) as such to clean inside it, just oil tbh. had a few manifolds vapor blasted and must say .... they look good. however did strip them completly to the bare bones. Washing / cleaning them ive found doesnt really do alot. When its off defo give underneath it a good clean, check the trumpet rubbers arent swollen.
Good luck Thumb
Vapor Blasted
 Filesize:  546.89 KB
 Viewed:  3989 Time(s)
Cameltoe & Heel
PostPosted: Fri Nov 03, 2017 8:26 am    Post subject: Reply with quote
P Tek thanks for your response and the results of the vapour blast looks superb. I'll have to look up a local blaster.
Yes the unit is now off as well as the top plastic engine cowling, I had two bolts strip whilst removing but I wanted to give it a good clean underneath to get at the barrels. I've drilled the remaining stud and going to tap some fresh threads. I know they only hold the plastic cowling on the engine but I want it right.
Yes I've bought the large black seal and the two shaft seals, although mine only had one shaft seal which was perishing badly.I'm guessing the reason for the leaky. I'm hoping that will solve my actuator problems.
I'm waiting on a delivery from Rosepassion so I can finish off the valve chain covers, PAS belt and cover, several other bolts that stripped whilst dismantling the engine. I've also bought the N/S engine tin too which was a little messed up on mine.
New dissis and rotors are now on, with new Beru leads and plugs, sump plug, I've cleaned it up pretty well so far with still more to do.
Trev
Cameltoe & Heel
PostPosted: Mon Nov 13, 2017 9:06 pm    Post subject: Reply with quote
P-Tek, took your advice and got my varioram Unit vapourblasted.
Couple of pics below:
Also had the fan surround done, was tempted to leave it unpainted as the vapourblasting left it looking good but decided to paint it Ocean Blue to match the car body.
[/img]
Tobesetc
PostPosted: Tue Nov 14, 2017 10:49 am    Post subject: Reply with quote
Painting the fan housing is one of those totally pointless jobs that REALLY appeals to me! Can't wait to see it all assembled and pristine!
993 C4, Coupe '94 manual
Previous - '03 986 Boxster S
Cameltoe & Heel
PostPosted: Tue Nov 14, 2017 11:55 am    Post subject: Reply with quote
Completely pointless Tobes, but whilst it's out kind of thing...
It was a mess when I took it out, wasn't going to put this back in Hand
Cameltoe & Heel
PostPosted: Tue Nov 14, 2017 4:35 pm    Post subject: Reply with quote
Calling P-Tek, I'm struggling to re-install the pipe nozzles as per below, have you re-installed these before?, they need to be squeezed and pushed in at the same time to engage the lip, not at all easy and haven't managed so far.
Any advice gratefully received...
Trev
Cameltoe & Heel
PostPosted: Tue Nov 14, 2017 9:29 pm    Post subject: Reply with quote
All sorted guys, got them installed tonight Smile
Just takes time with a comfy seat and several different sized screwdrivers to prize the rings into place.
Phew and relax
Trev
Endoman
PostPosted: Wed Nov 15, 2017 4:40 pm    Post subject: Reply with quote
That vapour blasting looks really good, where did you have it done?
PostPosted: Wed Nov 15, 2017 7:36 pm    Post subject: Reply with quote
Just for info .. P-Tek has just moved house and has no internet atm , ill nag him tomorrow to get it sorted quick as hes wanted here !
Im afraid im no 993 guy so cant really help out much here Sad
At an Indy these days !
Cameltoe & Heel
PostPosted: Thu Nov 16, 2017 8:33 am    Post subject: Reply with quote
Jeff at JR Vapour Blasting 07891 432595, very local to your good self too (j4 M61) highly recommend his services, he does a lot of motorbike stuff. Check him out on Facebook.
Trev
Cameltoe & Heel
PostPosted: Wed Nov 22, 2017 8:28 am    Post subject: Reply with quote
Folks,
engine is now coming back together, the Varioram is now back on after vapour blasting and various new seals on actuators etc. Just needs final bottom actuator shaft seal, then all vacuum pipes connecting which all seem in great condition and flowing freely.
I seem to have a problem with the alternator belt I have bought which seems way too short, it's a 9.5 x 760, the fan belt in a 9.5 x 776 which seems fine, any ideas??.
Trev
A993LAD
PostPosted: Wed Nov 22, 2017 12:28 pm    Post subject: Reply with quote
Trev,
That's odd as the measurements you cite seem to be correct.
I changed my alternator last year and bought two new belts so I just checked the order form for the parts and it was 1 x 760 and 1 x 776, the same as you have bought, and they fitted perfectly as replacements for the originals.
Do you have the ones you removed so you can compare them?
I remember thinking how annoying it was that they had 2 belts doing similar jobs. With almost the same dimensions so why didn't they just make them both the same size.
I think I also remember reading something at the time about some cars having an upgraded pulley in which case a 3rd belt size was required so perhaps you have one of the newer improved pulley's?
Marc
Cameltoe & Heel
PostPosted: Wed Nov 22, 2017 5:08 pm    Post subject: Reply with quote
Marc, unfortunately no I don't I slung them a week or so ago, school boy stuff I know, I got the new ones from Design 911.
Just been onto OPC and they're saying for my car M64/21 I need 2 of the 9.5 x 776mm vbelts, so I've ordered a new one.
Doh!!
A993LAD wrote:
Trev,
Marc
decgraham
PostPosted: Wed Nov 22, 2017 5:49 pm    Post subject: Reply with quote
Cameltoe & Heel wrote:
Folks,
Trev
Trev,
That engine is looking sweet, I'll be calling on you when I drop mine. Thumb
ATB Smile
