997 : 2004- 88
996 : 1997-2005 41
993 : 1993-1998 6
Boxster : 1997- 16
Macan : 2014- 0
willy
PostPosted: Mon Oct 30, 2017 5:33 pm    Post subject: Clutch Replacement - What Else While I'm At It? Reply with quote
Hi All
1998 C2 with 137K and the first clutch is finally showing its age - it is driving fine but if I floor the accelerator I get some slippage.
I plan to pick up a Sachs kit, but what else would to check and\or replace whilst the job is being done?
Thanks in advance
Al
1998 996 Carrera Ocean Blue
Marky911
PostPosted: Mon Oct 30, 2017 7:05 pm    Post subject: Reply with quote
Hi Willy,
My car comes back on Saturday from having a new clutch amongst a lot of other work.
While the box was out I had the following done -
Replace corroded brake pipes that run over the top of box.
Flip dust seal off IMS, though at your mileage it's probably safe to say it'll be ok now. It adds a bit of extra work.
I've had my IMS seal flipped off. It involves removing flywheel, locking engine timing gear, remove chain tensioners, then IMS cover. Inspect bearing, mine was perfect so seal then flipped.
New RMS seal, new IMS cover, new flywheel bolts. I also had a weak chain tensioner so glad that was spotted. No symptoms from it either.
I've also had a new Air/Oil Separator fitted. Mine was functioning perfectly but if it went in 6 months it would involve more labour to swap out. Access is much better with box out.
The IMS cover and AOS are about £100 each so it adds a little to the bill.
PS I'd be amazed if that's your original clutch. Wink
PostPosted: Mon Oct 30, 2017 7:24 pm    Post subject: Reply with quote
Your probably going to need a duel mass flywheel as well .
At an Indy these days !
Marky911
PostPosted: Mon Oct 30, 2017 8:08 pm    Post subject: Reply with quote
Good shout Demort.
My current flywheel has done 20k so I'm ok.
Other item could be a clutch slave cylinder but where do you stop. I've reused mine. The list was getting silly. Very Happy
PostPosted: Mon Oct 30, 2017 9:11 pm    Post subject: Reply with quote
Slave cyl is only needed if it is obviously damaged .. the rod end wears .. flywheel is always checked when doing a clutch but at that milage ( OP,s post ) or if original then i would certainly think it would need one .. and they aint cheap !
Your right though .. where to stop .. i think thats where a good relationship with your garage comes into it .. they say what they think you need .. you know they are acting in your best interests so go with the recomendation .
Some times we do try and help .. even if it costs you a fortune !!
willy
PostPosted: Mon Oct 30, 2017 9:48 pm    Post subject: Reply with quote
Smile
Thanks chaps - really appreciated.
I'm fortunate that the mechanic is a close friend so I will get nothing less than honesty there!
Have checked through the car's history and Marky911 is correct - a clutch change and RMS seal replacement at 42K way back in 2002. Nothing since and the records I have are pretty good (but could obviously be missing a sheet or two).
I'm seeing clutch and flywheel sets at about £550. Not great news but I've had 5yrs of pretty cheap motoring to date. No complaints.
Smile
plynchy
PostPosted: Tue Oct 31, 2017 9:21 am    Post subject: Reply with quote
Out of interest, where are you sourcing the clutch?
Just be very wary of eBay suppliers with huge positive feedback.... Question
'02 996 Turbo Manual Coupe Lapis/Grey. Unlimited grins.
911munKy
PostPosted: Tue Oct 31, 2017 10:40 am    Post subject: Reply with quote
Marky911 wrote:
Hi Willy,
Hi Marky,
Do you mind if I enquire what mileage you are up to?
Just thinking about future work for mine, I've only got the last 5 years worth of FSH (but OPC stamped logbook before that) so not sure if I'm still on the original clutch and appreciate that as I'm now on 100k things will be starting to wear out.
Ta,
2000 C2 996
wasz
1999 Porsche 996 Carrera 2
PostPosted: Tue Oct 31, 2017 11:25 am    Post subject: Reply with quote
Some replace the clutch arm and the pivot parts to remove any creaks or possibility of future creaks.
See pelican parts website they do a kit with everything they recommend to replace.
Also the gearbox mount will be saggy at this mileage.
Either replace with OE (need a press and awkward) or fit a powerflex insert.
Engine mounts too if they have never ben replaced.
.... as marky says, where to stop!
Gixxer996
PostPosted: Tue Oct 31, 2017 11:37 am    Post subject: Reply with quote
Having recently done this job myself i can confirm the trans mount replacement made a big difference on mine - less nodding on gear change but engine mounts prob made most of that difference.
I made a tool to insert the new trans mount without the use of a press - pretty simple using two lengths of stud to pull it into place (i did leave the new one in the freezer over night to help it reduce in size slightly). The original has a plastic outer which can simply be cut out.
If anyone wants to borrow my tool you are all welcome - but due to size and weight - you would have to collect from Essex and return please.
I would probably say this would be possible in situ - but i didn't try (just drop the nose of the trans to give clearance (supported by jack/ stand).
willy
PostPosted: Tue Oct 31, 2017 7:15 pm    Post subject: Reply with quote
Thanks plynchy. Haven't decided yet. Need to sort out the shopping list and will then see how much my mechanic friend can source for with his discounts.
There is a an ebay seller near to me trading under `parts2clear` e.g.
http://www.ebay.co.uk/itm/PORSCHE-911-3-4-Carrera-LuK-Flywheel-Clutch-Kit-301-09-97-09-01-Coupe-M96-01/131946536702?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Has anyone used them?
NLW73
PostPosted: Tue Oct 31, 2017 8:37 pm    Post subject: Reply with quote
stick a charger on it ? Question thumbsup Bandit
997 C2s Schwarz
willy
PostPosted: Wed Nov 08, 2017 9:29 pm    Post subject: Reply with quote
Hi chaps - just a brief update.
Sachs clutch kit, LUK flywheel, bolts and Porsche RMS ordered from carparts4less\eurocarparts. Came in at ~£555 including VAT & delivery.
Will put it on the ramps next week and take stock of anything else.
coullstar
PostPosted: Wed Nov 08, 2017 9:38 pm    Post subject: Reply with quote
For all that? That's cheap!!
2000 Audi B5 RS4
willy
PostPosted: Wed Nov 08, 2017 10:47 pm    Post subject: Reply with quote
Yes - I think it's there or there abouts. Carparts4less were still doing the WEEKEND14 14% discount so that helped. Then a phone call asking for a price match on both the clutch kit and flywheel against some ebay traders.
It's only the start though...
Very Happy
Marky911
PostPosted: Thu Nov 09, 2017 12:09 am    Post subject: Reply with quote
That's some good shopping there Willy! Good result. Thumb
911munky - sorry, I missed your post.
My car has covered 75k miles but the engine has done 10k less (due to earlier IMS bearing failure), so 65k.
At 100k I'd guess your car will be ready for most of the things discussed here if you want to go the whole hog. You could leave the AOS if no symptoms. My car doesn't smoke but the labour involved to do it later is quite a bit compared to doing it when box is out.
You may be lucky with the brake pipes over the box but I doubt it. Most cars are ready for them now and again it's so easy to do them with the box out.
I'm basically doing everything preventative you can that doesn't involve opening the engine.
Expensive but hopefully I'll have a couple of years of only minor servicing after this. Thumb
coullstar
PostPosted: Thu Nov 09, 2017 9:38 am    Post subject: Reply with quote
Very Happy
Looking at this now as well and cheapest I could get it around £650 for clutch and flywheel but I'll wait for one of these daft big % off things that Eurocarparts do although Im pretty sure they just hike the price or use some other means that is not as big a discount as you think.
Did they provide the flywheel bolts as well or does that come with the clutch kit?
2000 Audi B5 RS4
willy
PostPosted: Thu Nov 09, 2017 1:08 pm    Post subject: Reply with quote
Very Happy
Take a look at carparts4less.co.uk. They are still accepting WEEKEND14 so 14% off. Even without haggling, the order is coming in at ~£585.
Flywheel bolts are additional. You need 8 @ £1 each. My trusty mechanic said he could possibly make-do with the old ones but at that price its no need.
coullstar
PostPosted: Thu Nov 09, 2017 2:27 pm    Post subject: Reply with quote
Cheers, just checked and its still the same.
2000 Audi B5 RS4
Stoo.c
PostPosted: Thu Nov 09, 2017 2:34 pm    Post subject: Reply with quote
I wouldn't gamble on flywheel bolts. They're pretty cheap and meant to be changed every time they're removed.
02 996 C4S
93 Skyline R33 GTS-t
91 CRX vtec turbo
01 986 Boxster S
Goto page 1, 2, 3  Next
Page 1 of 3
