996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
Desert Dragon
PostPosted: Thu Oct 12, 2017 8:25 am    Post subject: Reply with quote
On suspension chassis I'd go to Mike Gardner Racing. Ohlins dealers and they have just released a very reasonably modern set of shocks for the 993. Much higher quality like for like than Bilsteins which rust with our salty roads for fun.
nickjonesn4
PostPosted: Thu Oct 12, 2017 11:36 pm    Post subject: Reply with quote
Thanks. I really fancy those Ohlins shocks. Have them on my Golf R
Desert Dragon
PostPosted: Fri Oct 13, 2017 8:26 am    Post subject: Reply with quote
Interesting i find the mk7 Golf R chassis wise amazing straight out the box. Whats it like on Ohlins as you lose the ACC? Question
nickjonesn4
PostPosted: Fri Oct 13, 2017 11:32 am    Post subject: Reply with quote
I didn't spec the ACC as Race/Sport unusable in Edinburgh due to terrible roads. The Ohlins just add to the fun IMO as they go through the travel much less quickly than stock. This means the car rides better and has less body roll on the ploughed fields we have here instead of roads.
Desert Dragon
PostPosted: Sat Oct 14, 2017 10:13 am    Post subject: Reply with quote
Have ACC and never use sport or race. Always leave it in individual with everything in sport apart from dampers. ACC brilliant on give and take roads like the ones you mention! Try one with the active dampers next time -Thumb
nickjonesn4
PostPosted: Sat Oct 14, 2017 1:18 pm    Post subject: Reply with quote
The standard dampers give exactly the same ride as DCC set in Normal. The set up is the same. I would use the Comfort setting if I'd had them but never Sport which is ubsuable on UK roads. I knew l would be getting coilovers (and upgraded brakes and tuning) hence saving a few quid on DCC.
Desert Dragon
PostPosted: Sat Oct 14, 2017 5:53 pm    Post subject: Reply with quote
The standard dampers give exactly the same ride as DCC set in Normal. The set up is the same. I would use the Comfort setting if I'd had them but never Sport which is ubsuable on UK roads. I knew l would be getting coilers (and upgraded brakes and tuning) hence saving a few quid on DCC.
Thanks for this. I had not appreciated they were the same ride. The body control on the dynamic dampers (not driven passive set up) on twisty roads with crests and dips is frightengly good. Better than most sports cars costing triple the amount. I've never understood why people do not find the R or GTI CS/PP quick. They're 911 fast if driven properly down those sort of roads especially with your goodies thumbsup
nickjonesn4
PostPosted: Sat Oct 14, 2017 6:37 pm    Post subject: Reply with quote
Agreed, one of the fastest UK road cars available. As you say, especially when you get into giving the engine some encouragement with a map and sort the exhaust out.
Steering is a bit dead and there is some lag but other than that pretty amazing for £35k
Still not a Porsche tho!
Desert Dragon
PostPosted: Sat Oct 14, 2017 7:23 pm    Post subject: Reply with quote
Have a look at the new autocar vid comparing R to Civic R. The journos both come to same conclusion after I'd spent a few hours in one! Best car in the world thumbsup
Goto page Previous  1, 2
Page 2 of 2
