997 : 2004- 71
996 : 1997-2005 48
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 15
Cayenne : 2003- 9
Macan : 2014- 1
912-914-924-928-944-968 3
ELA
PostPosted: Tue Oct 10, 2017 8:17 am    Post subject: Diagnostics gear Reply with quote
Has anyone tried the iCarsoft POR II equipment on an early 996?
I have found a full PIWIS set-up incl laptop... for €1355, however this icarsoft gear is only around £150 so I'm feeling it might be worth a try. Trouble is I have now bought 4 of these cheaper readers (£30-70 region) and they aren't really much good.
Any thoughts on whether a system upto say £200 is worth bothering with would be much appreciated?
CLR996 1086kg bespoke design
ELA
PostPosted: Tue Oct 10, 2017 8:58 am    Post subject: Reply with quote
I've just spoken to another company call Foxwell who make the NT510 Pro and they seem suggest for around €200 it is the best system for the 996. So I just ordered this. I'll let you know what it's like when it arrives...
Sundayjumper
1999 Porsche 996 Carrera 2
PostPosted: Tue Oct 10, 2017 10:26 am    Post subject: Reply with quote
I bought one of those recently, seems OK but I've not needed to use it in anger yet.
wasz
PostPosted: Tue Oct 10, 2017 10:30 am    Post subject: Reply with quote
Does it do any more than a full genuine durametric?
I have a £12 clone that does everything except things like open the abs pump for bleed and coding functions.
maldren
PostPosted: Tue Oct 10, 2017 10:33 am    Post subject: Reply with quote
Hi Rich,
I've also had no luck with a cheap one so I was planning to go for the 'Enthusiast' Durametric kit for £299, interested to see how you get on
Mike
Mike
2016comming
PostPosted: Thu Oct 12, 2017 2:24 am    Post subject: NT510 Pro Reply with quote
ELA, Where did you bought it?
markrnorton
PostPosted: Thu Oct 12, 2017 8:22 pm    Post subject: Reply with quote
Hi
I have the icarsoft Porsche II
It’s not bad, does more than most readers, live metrics and resets most issues
It’s not a durametric though
Ok for the money
Updated mine and it covers a good range of models
996 C4 Tip S
986 S
955 Cayenne S
stevemfr
PostPosted: Fri Nov 03, 2017 9:33 am    Post subject: Reply with quote
^this
I've had only very limited experience with the iCarsoft on a 996 - but quite a bit on Land Rovers / Range Rovers. If you are looking for much more than a simple fault code reader, it's not worth the aggravation IMO (I am part of GAP Diagnostic, tho, and we make Land Rover diagnostic tools. I believe I am being objective, but take my opinion as you see fit).
My experience with the iCarsoft: the menus are anything but intuitive, numerous functions are in the menus but don't actually work, and the live values are very difficult to use for anything other than static readouts (i.e. on/off, engine temp, battery voltage, etc).
10-15 years ago the iCarsoft would have been "the poop". Today there are so many better options in the market, that saving £100-150 is silly - even for an occasional user. Durametric...
If all you are looking for is a fault code reader, the iCarsoft could suffice.
nigel99
2009 Porsche 997 Carrera 2S
PostPosted: Fri Nov 03, 2017 2:28 pm    Post subject: Reply with quote
I bought the icarsoft for my 997.2 to reset the airbag light after I changed my wheel. It worked perfectly for that. It's limited to reading and resetting faults. Others such as Durametric and PIWIS can also be used for programming.
Current: 2009 997.2 C2S
Previous: 2008 Cayman 2.7, 2002 Audi TT, 1999 BMW 318!
maldren
PostPosted: Fri Nov 03, 2017 4:10 pm    Post subject: Reply with quote
Hi Rich,
any luck with this yet?
Mike
X51 996
PostPosted: Sun Nov 05, 2017 1:30 pm    Post subject: Reply with quote
Is this one of the ‘durametric/PIWIS’ leads from eBay etc? Sounds interesting - does it work okay/what functions etc. Eg can you read all the advanced stuff from the DME (rev ranges etc) and does it do the coding stuff for keys/stereo etc? Cool
2003 911 Carrera 2 coupé, Arctic Silver - 3.6 manual, X51 Carrera PowerKit, X74 Suspension, Sunroof delete, PSM delete. Black leather crested sports seats (XSC), XAG rear spoiler, 5-spoke 18" Carrera Alloys, Xenons.
2004 Mercedes E55K AMG Estate
1988 Mercedes 190E 2.3-16
1988 Mercedes 190E 2.5-16
searider
PostPosted: Sun Nov 05, 2017 7:49 pm    Post subject: Reply with quote
maldren wrote:
Hi Rich,
Id be interested to hear about this too.
Usual progression - 205 1.9 / Corrado VR6 / Audi B5 S4 / RS4 / 996 C2 Coupe.
ELA
PostPosted: Mon Nov 06, 2017 7:29 am    Post subject: Reply with quote
searider wrote:
maldren wrote:
Hi Rich,
Sorry guys, I forgot about this thread.
In simple terms it is an excellent bit of kit which does far more than I'll ever need.
I'll give a more detailed review when I have a spare 5 minutes.
maldren
PostPosted: Sun Dec 10, 2017 9:46 am    Post subject: Reply with quote
Hi Rich,
Christmas is coming, any more news?
thanks
Mike
John997
PostPosted: Sun Dec 10, 2017 8:10 pm    Post subject: Reply with quote
Looking around and reading this post then I think it just depends what you want to use the Diagnostic testers for, be it for servicing your own car and fault finding & troubleshooting.
There are quite a lot out there and TBH I cannot see the DIY’er spending a fortune on some of the more professional tools (unless you have very deep pockets..), so where does this leave us ? - Like I said so many out there but what do you choose, a dedicated tester like the Durametric or a multi-vendor one like the Foxwell NT644.
Two avenues, if you are ok with spanners, don’t mind getting stuck in, intend to service, fault find & repair your car then all for getting a diagnostic tool.
This then leads to the servicing booklet, does it really matter if you have all the stamps in and will it affect the resalable value if you can prove that you have maintained your car, if you’re not bothered then I don’t see why you shouldn’t purchase one. Then again you can still do in the in-between services, fix any issues and still get the major servicing done at your local Porsche/Indie and still have your servicing book stamped.
Anyway, have been looking at the Durametric both the Enthusiast & Professional versions, they are expensive for what they are and have read various mixed thoughts on “Are they really worth it ?..” – I think they are TBH, but that’s my own opinion.
Both the Enthusiast & Professional do the exactly the same as far as diagnosis goes but the Professional is not tied down to vehicles it can service/maintain and also has the coding function. So what is this coding function, from what I have read then it allows you to install/setup an modify certain features.
I still haven’t found out what all the features are and if they are indeed a benefit, also do they have all the features of the PIWIS ?. From I have found out, coding can do for example:
1.. Disable the rear spoiler if you wish to fit a fixed rear wing
2.. Enable the windows to open /close via the Key fob
3.. Adjust the ride height
4.. Help bleed the Primary & Secondary brake system
3.. There are probably more out there but have emailed Durametric if they have a “Layman’s” guide in plain English to what extent
Found these links below:
http://www.planet-9.com/reviews/electronics/p383-durametric-tutorial-part-1-3a-the-basics.html
http://www.planet-9.com/reviews/electronics/p384-durametric-tutorial-part-2-3a-advanced-functions.html
aerokit
PostPosted: Tue Dec 26, 2017 2:49 pm    Post subject: Reply with quote
Does anyone have a reliable link of where to buy the Durametric system that will work on the 996 please?
Got a potential mis-fire that needs decoding!! nooo
John997
PostPosted: Tue Dec 26, 2017 3:58 pm    Post subject: Reply with quote
Here you go mate, please see below. This is the cheapest you will find in UK, that price includes P/P & VAT so is a real bargain. These are the proper cables/kits and they get them directly from Durametric.
Give them a call, ask for Grant - he is good to speak with as well, and yes will work on the 996 - well according to Durametric Car Matrix:
https://www.gendan.co.uk/product_DURAENTH.html
I bought the Enthusiast version, reason why I did not go for the Professional was simple. I emailed and spoke with the Durametric guys in the states as was confused as to what exactly the Coding can do and the main differences are. So basically apart from the 3 VIN support then the only difference is the Coding, this coding is very limited to the Durametric software and the way it interacts with the ECU/modules..
So if you expect it to do the same as the PWIS then it will not...
If you expect to be able to install a new feature like Rear Park Assist or Cruise or install a new Steering Wheel Air Bag Module then it will not...
If for example you want to replace a module that has gone faulty, re-code it
and back/restore, then it will not... The backup feature is again purely related to the Durametric software and not to Porsche PWIS...
What the coding will do (again check Durametric website against your car..), will for example if you want to install a fixed rear wing then Yes it can disable the Auto-Rise feature, you can apparently adjust the ride height and also can do other stuff as well, but again is limited to the Durametric's own software constraints.... I could not get all the info out of Durametric to what exactly it can do !!
The Enthusiast will do exactly the same as the Professional but is limited to 3 VIN's and Coding side.
So basically if you intend to have more than 3 Porsches then get the Professional or if your in the Car servicing side then again get the Professional, or if you intend with play around with Durametric's coding then get the Professional.
Hope this helps fella..
