997 : 2004- 80
996 : 1997-2005 44
993 : 1993-1998 6
Boxster : 1997- 19
Cayman : 2005- 11
Macan : 2014- 1
PostPosted: Sat Oct 07, 2017 7:18 am    Post subject: Standard Ride Height Reply with quote
Can i ask what is the standard ride height for a C2 and also how many ride heights are there if I decide to lower the car. Reason beings is am liking to overhaul my suspension and without going too low cos of speed bumps etc... don't want to be I using old springs on new shocks..
J
CarreraMonkey
Watkins Glen
2007 Porsche 997 Carrera 4S
PostPosted: Sat Oct 07, 2017 8:28 am    Post subject: Reply with quote
Porsche gave the MO30 kit a -20mm drop, but -25mm looks better still imo and won't give any clearance issues as far as I know.
Laters Taters!
-- 997 --
PostPosted: Sat Oct 07, 2017 4:50 pm    Post subject: Reply with quote
So from factory the C2 springs that's on my car are 20mm drop?
J
CarreraMonkey
Watkins Glen
PostPosted: Sun Oct 08, 2017 1:27 am    Post subject: Reply with quote
J
Only if you have mo30 suspension fitted.
Mine has 'sports chassis' which was a free option to replace the pasm with mo30 suspension and a LSD. Not sure if it is straight forward to just swap out springs on a pasm suspension car. Assume it is.
Laters Taters!
-- 997 --
PostPosted: Mon Oct 09, 2017 10:13 pm    Post subject: Reply with quote
I have PASM on my car but no MO30 kit, I guess if I were to get Bilsteins all round I'll be getting a set of H&R springs to match but need to avoid lowering and if I do it will have to be the least drop as the speed bumps around where I am is bloody ridiculous..
It's why I was asking what the factory spring drop would be so from there I can work out what would be the best bet for me etc...
J
SausageCreature
PostPosted: Sat Oct 21, 2017 12:11 pm    Post subject: Reply with quote
I am fairly certain that the C2 is 10mm higher than the C2S regardless of PASM/Non-PASM options.
So AFAIK you have 10mm you can lower before you are even matching the standard ride height of the C2S.
However, I cannot answer your specific question, sorry.
FZP
PostPosted: Sat Oct 21, 2017 1:07 pm    Post subject: Reply with quote
Aren't there 3 ride heights?
Std
PASM -10MM
Sport PASM -20MM
That sounds familiar to me but I may be incorrect
PostPosted: Sat Oct 21, 2017 4:10 pm    Post subject: Reply with quote
Std
PASM -10MM
Sport PASM -20MM
I think that's correct the lowest one is the sport chassis
the one fitted to most S cars is pasm and non S cars the highest std which is 10mm higher than the pasm.
SausageCreature
PostPosted: Sat Oct 21, 2017 7:29 pm    Post subject: Reply with quote
A C2 with PASM is not 10mm lower than standard, and that is what I think the OP has.
So to say that a PASM car is 10mm lower than standard height is not actually correct.
-- 997 --
PostPosted: Sat Oct 21, 2017 8:48 pm    Post subject: Reply with quote
So a C2S with PASM NOT activated just standard sits at 10mm??
J
MJA911
2012 Porsche 991 Carrera
PostPosted: Sat Oct 21, 2017 9:12 pm    Post subject: Reply with quote
PASM settings are normal or firm (not on or off) and don’t affect ride height - as far as I know.
-- 997 --
PostPosted: Sat Oct 21, 2017 10:19 pm    Post subject: Reply with quote
Ok, so what is the ride height then, would it be 10mm ?
J
MJA911
PostPosted: Sat Oct 21, 2017 10:24 pm    Post subject: Reply with quote
I agree with earlier post, PASM cars are 10mm lower than standard, PASM sport are 20mm lower.
-- 997 --
PostPosted: Sat Oct 21, 2017 10:30 pm    Post subject: Reply with quote
So what is the standard height? Presumably C2 and C2s with PASM would be the same?
J
MJA911
PostPosted: Sat Oct 21, 2017 10:55 pm    Post subject: Reply with quote
Sorry but I don’t know if that’s the case or not.
Visually you can see that a standard non S car sits higher than an S, it could well be because a non S sits 10m higher to start with and PASM on the S increases the difference by another 10mm. I can believe this is true, they do seem to ride high so your car could be riding 10mm higher than an S even though it has got PASM.
A suspension specialist like Centre Gravity would know this.
-- 997 --
PostPosted: Sat Oct 21, 2017 11:06 pm    Post subject: Reply with quote
Ok MJA911, did forget to mention in the original post the I have the C2S,
what it is ... is that I'm looking to wanna change my suspension and fit new springs BUT don't want to lower it cos of speed bumps etc so Im Looking for springs that's the same height as what I currently have that's factory standard, something like H&R springs, if I can't find like for like then probably the next best thing would be little lower in the range etc if that makes sense, I don't want to use my current springs on new SHOCKS which is why I'm asking what height would be my car so I can start from somewhere....
Cheers..
J
MJA911
PostPosted: Sat Oct 21, 2017 11:43 pm    Post subject: Reply with quote
Ah, understood, yes, the point of H&R springs seems to be to lower the car but still retain the ride quality (e.g. on a PASM car by 30mm) whereas if you want to keep ride height as it is, maybe the best option is to replacement Porsche springs, but I’m outside my knowledge now and there could well be alternatives.
SausageCreature
PostPosted: Sun Oct 22, 2017 8:46 am    Post subject: Reply with quote
Having owned my C2 PASM for seven years I have heard all sorts of different opinions on this, from specialists in the business as well as from OPC. There seems quite a lot of confusion and contrary views. So I made a point of trying to clarify this because like the OP at some point I am going to want to refresh my car's suspension.
I have also noticed that C2S do seem to sit lower - it is noticeable with the eye and I wondered about this as well. So, having looked into this for seven years....
In my mind I have come to the conclusion, beyond any doubt, that a C2, whether with PASM or not, is the standard height as called earlier here, and it is 10mm higher than a C2S with PASM.
As mentioned earlier - turning PASM to sport or normal does not change the ride height.
So, it seems to me the three are:
standard height
-10mm
-20mm
As for what that height is I do not know, and the Carrera owners manual only confuses things more by stating :
Dimensions
Length 175.6 in./4461 mm
Width 71.2 in./1808 mm
Height 51.6 in./1310 mm
Wheelbase 92.6 in./2350 mm
Ground clearance 4.2 in./106 mm
at maximum gross weight 3.4 in./86 mm
Turning circle 35.8 ft./10.9 m
Vehicles with PASM
Height 51.2 in./1300 mm
Ground clearance 3.8 in./96 mm
at maximum gross weight 3 in./76 mm
Which mentions a lower height and less ground clearance on a PASM car.
OP - can you just buy your replacements and specify you want standard, or lowered by x cm, when you buy them? Is this is the easiest approach ?
Mark
PostPosted: Sun Oct 22, 2017 2:46 pm    Post subject: Reply with quote
standard height
-10mm
-20mm
Dimensions
Vehicles with PASM
Mark
That does seem to make sense Mark and is also how I understood it. I had also assumed that a non S car that does not come as std with PASM if the car was optioned to have PASM would also now be 10mm lower as the S cars
Your post does seem to concur with that as it specifies PASM or non Pasm and doesnt mention S or non S Thumb
SausageCreature
PostPosted: Sun Oct 22, 2017 4:33 pm    Post subject: Reply with quote
Hi Phil -
no mate, sorry, my car is a NON S car, it is a C2, not a C2S, so sorry if that wasn't clear.
So, just to be clear. A Carrera (NON S) that was bought with PASM still sits at the standard height with no 10 (or 20) mm reduction Smile
This contradicts lots of opinions and also the owners manual, but I have owned the proof for 7 years.
M
