porsche system tester 2
paul987
Mexico City
27 Feb 2015
1,907
What is it? Where can I get one?
I'm at the brake bleeding faze of my unplanned brake line replacelment...I was planning on doing it this evening....
But my car has PSM is there anyway to bleed them without this PST2 or any ideas on options :dont know:
Either use a brake bleeder kit or someone pumping the pedal whilst you bleed it .. thats all you need .
tester is for when an abs unit has been drained .. not for normal bleeding .
That should do just fine .
If the resevoir emptyed out then you will need to bleed all the brakes .. care full as some of the nipples might be seized .. start with the one you replaced the pipe on and check the pedal after bleeding , youll soon know if you need to bleed the others as you will have no pedal !
The tester is not needed for things like this .. piwis 3 ( also called a piwis 2 by Porsche ) and a chinese version will start at £1200 btw :)
Ah right... good stuff :thumb:
£1200 :eek: does that include a team of guys to bleed your brakes for you :?: :lol:
Trust me thats just the tester and the english unlocked version starts at £2100 lol .
124,597
1,441,964
49,031
LB_85
