997 : 2004- 71
996 : 1997-2005 36
Boxster : 1997- 25
porschepower
PostPosted: Mon Sep 25, 2017 4:50 pm    Post subject: Cayenne 2012 958 Key Not Working Reply with quote
Hi Guys I have noticed that my remote works to lock/unlock the car fine
But when i press the boot release button nothing happens?
I only really noticed it as the new cayenne courtesy car I had did work
PostPosted: Mon Sep 25, 2017 7:30 pm    Post subject: Reply with quote
If the key fob unlocks the car then the signal etc is working fine , if it doesnt open the boot then all i can think of is some sort of codeing issue as the car is recieveing the signal but not acting on it .
PeterS
2003 Porsche 996 Carrera 2
PostPosted: Mon Sep 25, 2017 8:20 pm    Post subject: Reply with quote
Hold it for about 2 seconds
porschepower
PostPosted: Tue Sep 26, 2017 8:50 pm    Post subject: Reply with quote
Hi guys tried holding the boot release button for 10 secs and nothing?
PostPosted: Wed Sep 27, 2017 6:58 pm    Post subject: Reply with quote
It needs a tester connected to check the coding so indy / OPC .
I take it your spare key does the same .. if not then its a single key fault .
