996 : 1997-2005 41
993 : 1993-1998 8
964 : 1989-1993 6
Classic : 1950-1965 1
Boxster : 1997- 10
Cayenne : 2003- 7
Macan : 2014- 3
kozzi
PostPosted: Sun Sep 24, 2017 3:22 pm    Post subject: 997 turbo engine mounts Reply with quote
Hi guys need to replace engine mounts. Original or rss? Which Rss model is best and where to get them? Replaced the gearbox mount in February with an insert wilhicj made some vibration in the cab so don't want to make it worse
I am the beast that feeds the beast
Mezgerite
PostPosted: Sun Sep 24, 2017 4:33 pm    Post subject: Reply with quote
Standard of you don't want additional vibration.
Boba fett
Watkins Glen
PostPosted: Sun Sep 24, 2017 6:32 pm    Post subject: Reply with quote
Can you give more detail, as what you have said don't make sense mate Thumb
kozzi
PostPosted: Sun Sep 24, 2017 8:14 pm    Post subject: Reply with quote
Made sense to me
Mezgerite
PostPosted: Sun Sep 24, 2017 10:30 pm    Post subject: Reply with quote
Sorry, typo!
of should be it.
Standard if you don't want additional vibration.
Any 997 will benefit from new engine mounts due to the engines movement influencing handling so much and the fact that all original mounts are now 5+ years old and have become more elastic,
M.
Martian
2007 Porsche 997 Turbo
PostPosted: Tue Sep 26, 2017 7:02 pm    Post subject: Reply with quote
If you don't want any more vibration, replace with stock mounts. The RSS ones do give a more noticeable vibration below ~1500RPM.
Boba fett
Watkins Glen
PostPosted: Tue Sep 26, 2017 7:13 pm    Post subject: Reply with quote
So what do people recommend, heard good things about RSS, and an even slicker gear change as well, but now is stock better???
Martian
PostPosted: Tue Sep 26, 2017 7:32 pm    Post subject: Reply with quote
RSS are better in every way over stock apart from NVH. When I had mine fitted, I was quite surprised by the extra vibration and nearly went back to stock. That was ~5 years ago and they're still fitted so no biggie, but I don't do many miles in it at the mo, doubt they'd stay if it was used more frequently TBH.
kozzi
PostPosted: Tue Sep 26, 2017 7:34 pm    Post subject: Reply with quote
I bought stock which will be fitted at the weekend.
Boba fett
Watkins Glen
PostPosted: Tue Sep 26, 2017 7:40 pm    Post subject: Reply with quote
Reading that you are on the fence Thumb
Iansta
PostPosted: Fri Sep 29, 2017 4:55 pm    Post subject: Reply with quote
After a year and 8500 miles the only difference in nvh I noticed was at 1900 rpm when it's a really nasty grinding noise but provided you don't hover 50 rpm either side you wouldn't ever notice it.
Benefits of them far outweigh this
kozzi
PostPosted: Sun Oct 01, 2017 3:40 pm    Post subject: Reply with quote
I bought stock mounts and fitted them yesterday with my friend on his ramp - which was a great help as we are both getting too Old to lay on the ground!! The exhaust tips now sit a lot higher, the gear change is slick again and the shunting on throttle lift off has gone!
Well worth the 1 hrs labour and £250 spend 👍
