I noticed this weekend that my wheel arches have started to rust, ie bubbling under the paintwork. A simple rub with Polish took the paint away and I dabbed each spot with rust inhibitor. I am taking it to a few places this morning for a quote to sort it out.
My question is, what should I expect to hear? Full wing respray, or is it a job that someone like chips-away could do?
Very common this. I had mine done by Riviera down near Reading - they do a lot of these and see them all the time; certainly sounded like they knew what they were talking about in any case. They stripped the arches right back, applied a load of gunky sealant and then blended the paintwork in as above. Looks like new now and should last pretty much forever.
Either way, it's a much bigger job than just touching it up.
It's common usually the rear arches that go first on the 996 and one to keep an eye on, the water gets under the underseal at the sharp lip of the arch and it lifts.
I re-painted mine a couple of years ago and made sure that I used good underseal again before just painting as it won't last long with just paint on it.
Just to worry people... if mud gets thrown up behind the wheel arch protector (big black plastic wheel well bit) and the bodywork.... and accumulates, it will block the drain down and out through the back of the bottom sill at the front of the rear arch... when water gets thrown up behind the arch protector the accumulated mud gets wet and now stays wet.... at which point galvanised bodywork will only last so long as the mud keeps the water in contact with the metalwork...
I recently removed the offside rear wheel well protector in order to fit GT3 style brake ducts - cue great big shower of dirt, followed by discovering the bottom corner of that sill, beneath the "other" bit of plastic (lower aero spat on a 996.1) is like a colander... I was on top of this re. the nearside having had metal cut out and welded back in on that side in order to address the arch that went first
- I remember checking the offside at the time and all appeared fine... that only took a couple of years to change with the "mud poultice" scenario
For my rear arch respray the bodyshop resprayed all the way to the front edge of the door (front fenders and bonnet had all been resprayed a couple of years previously)
i.e. With various partial resprays (even considerable ones) a 20 year+ car will eventually benefit from a full respray or those in the know will start to refer to your beloved shiney car as a "patchwork quilt" : '
luckily my car is black(!)
- a friend didnt appreciate my pointing out that his red alfa was in fact 3 shades of pink, 4 of red and at least 1 "brown".....
Just had my 997 done not pretty rotten as a pear once opened up top job by local paint shop rear arch rebuilt and small dents sorted and drivers door damage taken care off all for £700 and a fair colour match 8)
I just did the wing swap on the missus Seat Ibiza as it failed its MOT on a sharp edge on the front wing due to some rust on the lip. I managed to find a perfect condition and colour match wing for £40 (no Porsche tax) and it took me an hour to swap them over.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
