Will soon be having these up for grabs.
These are the ones to upgrade your early GT3/ 996tt/ 997S easily.
Removed from a 997.1 GT3 last year...rhen rebuilt with new oil and dust seals.
Been on my 986S for a about 12 months.
Outer pad pins shaved to allow use of Cayenne 350mm discs.
All ceramic pucks are present and entire...bar one. One piston was damaged during rebuild and was replaced with a normal piston without the ceramic puck.
Said damaged piston and puck will be provided.
Will also include a set of barely used TRW brake pads and the hard lines that bolt to the caliper/hub.
1000gbp delivered. Pics up soon
