997 : 2004- 66
996 : 1997-2005 43
993 : 1993-1998 9
964 : 1989-1993 7
Carrera SC : 1977-1983 0
Classic : 1950-1965 1
Boxster : 1997- 15
Cayenne : 2003- 9
912-914-924-928-944-968 4
BChivs
PostPosted: Wed Sep 13, 2017 3:35 pm    Post subject: Rev range data 996 Reply with quote
Hi, I have had a PPI carried out today on a 996 C4S including Ecuador rev data readings. This however means absolutely jack to me! Dont know
What does it mean when readings are range 1 or 2?
Norfolk & Idea
PostPosted: Wed Sep 13, 2017 4:09 pm    Post subject: Reply with quote
Rev range readings in range 1 & 2 are fine. Readings above RR 4 are not so fine. There are threads on here covering it in detail. But I'm a bit of a spaz and I don't know to dig out links. A cleverer chap will be along shortly... Smile
2012 997.2 Turbo Basalt Black
2008 Ducati 1098R (Track)
2016 Macan GTS
2008 Vito Sport- Household Star!
IanG1
PostPosted: Wed Sep 13, 2017 4:40 pm    Post subject: Reply with quote
996 only has ranges 1 and 2 the later cars more. Range 1 is at the limiter so expect to see some of these. Range 2 is an over rev so not desirable. If it has any in this range check the hours next to it that tells you when it occurred. Compare this to total run hours to see if recent. If not then you can assume no real damaged occurred if all still running sweet..
Post your data if that doesn't make sense and somebody will interprete.
BChivs
PostPosted: Wed Sep 13, 2017 5:39 pm    Post subject: Reply with quote
I don't have the full print out just the summarised figures in the report....He said Rev Range 1 '4015' range 2 '3'.
As I mentioned this may aswel be a verse of killing me softly in Spanish because I haven't got the slightest clue whether this is good bad or otherwise?
cheshire911
Estoril
PostPosted: Wed Sep 13, 2017 5:59 pm    Post subject: Reply with quote
This is spot-on. Only rev ranges 1 and 2 for this car. The reading of 3 (ignitions) in rr2 is nothing to worry about. If it was recent a d more of them, then you'd be advised to have a compression test to assess if any damage.
Cant comment on mileage validation as you don't give operating hrs and avg speed also given from the ECU.
996 2002 X50 Turbo Manual
BChivs
PostPosted: Wed Sep 13, 2017 6:13 pm    Post subject: Reply with quote
The operating hours etc he said were spot on....1391 hours at an average speed of 42.57??
BChivs
PostPosted: Wed Sep 13, 2017 6:15 pm    Post subject: Reply with quote
Forgot to say he borescoped and said all looked fine....very very slight marking on bank 4 but nothing to show concern.
Ronam2012
PostPosted: Wed Sep 13, 2017 6:35 pm    Post subject: Reply with quote
If the rev range 2s were low numbers and over 50 hours has passed it should be ok.
I'd be concerned if there are a high number and recent.
996 Turbo Manual Polar Silver
Demort
Estoril
PostPosted: Wed Sep 13, 2017 6:36 pm    Post subject: Reply with quote
The rev ranges are fine and what i would expect on a normally driven car.
It should be around 45 K miles on the clock at those hours.
At an Indy these days !
cheshire911
Estoril
PostPosted: Wed Sep 13, 2017 6:56 pm    Post subject: Reply with quote
[quote="BChivs"
The operating hours etc he said were spot on....1391 hours at an average speed of 42.57??[/quote]
I must have missed that data somewhere.
Marky911
PostPosted: Wed Sep 13, 2017 7:13 pm    Post subject: Reply with quote
Good info given already.
42mph is a high average speed but those Overrevs aren't bad at all.
You very often see tens of thousands of Range 1's.
See how long ago the Range 2's occurred.
As a rule if it's over 100 hours ago you should be fine. Some dealers won't take cars in if its within 100 hours. There has been the odd example of damage happening later. There was a guy on P'heads whose timing chain snapped 400 hours after a Range 2.
Also though if it's in single figures some believe that is just a spurious recording in the ecu.
As a quick calculation divide over revs by 400 and that will give you the amount of time the engine has spent in that zone.
E.g 2800 Range 1 over revs = approx 7 seconds hitting the limiter over the cars life. So that could just be bumping the limiter in 2nd 7 times.
cheshire911
Estoril
PostPosted: Wed Sep 13, 2017 7:35 pm    Post subject: Reply with quote
I also thought it was on the high side for avg speed. Typically, no matter how hard we drive the (except for sustained track use) the avg tends to be below 40mph and may often be around 30mph when used for road driving in the UK.
Demorts estimation at c45k is about right based on those hours and avg speed so lets see what the mileometer in the click reads (always a slight discrepancy between the click and ecu/dme).
The 3 ignitions in RR2 is trivial - I font think the OP will end up with a snapped timing chain with those - but certainly has been known to happen later on ibyo ownership but unclear how they can associate it with an earlier RR2 ignition range.
cheshire911
Estoril
PostPosted: Wed Sep 13, 2017 7:36 pm    Post subject: Reply with quote
Demorts estimation at c45k is about right based on those hours and avg speed so lets see what the mileometer in the clock reads (always a slight discrepancy between the clock and ecu/dme).
The 3 ignitions in RR2 is trivial - I don't think the OP will end up with a snapped timing chain with those - but certainly has been known to happen later on into ownership but unclear how they can associate it with an earlier RR2 ignition range?
BChivs
PostPosted: Wed Sep 13, 2017 8:23 pm    Post subject: Reply with quote
Wouldn't it be average speed (mph) x total hours = mileage?
1391 x 42.5 = 59,117
This is perfect to the dash. I will check with Autowerkes how long ago the small rev2 was.
Diggermeister
PostPosted: Fri Sep 15, 2017 2:32 pm    Post subject: Reply with quote
IIRC Porsche generally say, for warranty that 50 hrs ago and the issue may be okay but after 100 operating hours, then the car would be considered 'safe'. I think that's what their warranty policy was on these cars.
Unfortunately, what constitutes a range 2 is a mystery, since, unlike the 997, you have no higher rev ranges to provide guidance.
