996 : 1997-2005 45
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 15
Cayenne : 2003- 8
Macan : 2014- 3
912-914-924-928-944-968 4
noel993
PostPosted: Mon Sep 11, 2017 9:43 pm    Post subject: Rear Seat and floor water coming in Reply with quote
Ive a 996 C4s convertible and my rear passenger seat is filling up with water, any help please,
Shanghai
PostPosted: Tue Sep 12, 2017 7:00 pm    Post subject: Reply with quote
Its probably going to be the rear drains blocked , you need to remove the arch liner that side , remove the rubber grommet in the picture and any dirt and pour water from the top at the side of the cab roof to clear it out .
Its also usefull to remove the rear quarter panel and have a look at the drain from that side , might be a split drain pipe .
You can remove the rear speaker and lift out the plastic splash guard for a quick look though .
Some more picts ..
https://rennlist.com/forums/996-forum/916484-my-eureka-moment-with-water-drains-in-our-996-cabs-2.html
At an Indy these days !
 Filesize:  227.74 KB
 Viewed:  636 Time(s)
 Filesize:  126.98 KB
 Viewed:  636 Time(s)
