996 : 1997-2005 45
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 15
Cayenne : 2003- 8
Macan : 2014- 3
912-914-924-928-944-968 4
Nightrain QDUN4
PostPosted: Sat Sep 09, 2017 7:07 pm    Post subject: Transmition Mount oil Reply with quote
Need some help on this one please guys.
just returned from a 2k trip and I've noticed a small amount of oil coming from the transmition mount area, after wiping it looks like it may be comming from the small drain hole.
Car has been parked for a week and there is no oil on the garage floor just a small amount on the undertray.
Could this be the rear drive shaft seal or bearing if it has one on its way out. I was sure I could hear a worn bearing noise on the nice smooth French motaways, wife said I emajening it and paranoid.
2004 C4S
Thanks in advance
Mark
2004 C4S
2003 C4S
 Filesize:  78.61 KB
 Viewed:  1011 Time(s)
Shanghai
PostPosted: Sat Sep 09, 2017 7:11 pm    Post subject: Reply with quote
I,v got to admit im struggleing to see a leak there , normally when tips leak its obvious and even then its only a very small amount .
It could gaskets or seals but need some side on pictures to have a better idear.
For a bearing to make a noise because of lack of oil then it would be pretty dam low .. you would have banging on gear selection and i would hazard a guess that the box would be toast at that point !
At an Indy these days !
Nightrain QDUN4
PostPosted: Sat Sep 09, 2017 7:48 pm    Post subject: Reply with quote
Hi Demort, I should of taken a photo before wiping off the small amount of oil.
Gear change is smooth, will try and get some side pictures tomorrow.
Cheers, back to the wine thumbsup
2004 C4S
2003 C4S
Nightrain QDUN4
PostPosted: Sun Sep 10, 2017 6:00 pm    Post subject: Reply with quote
Couple of side shots Demort, had a good nose around it today looks like it's been misting from the gasket for a long time, not sure if the main seal is weeping too as the oil is an upper side of the mount.
It's the first time I've seen any oil residue on the rear undertray, front undertryes are spotless as I resently has the front diff overhauld with new seals and bearings.
I will keep an eye on it and will mention it to the garage when it goes for a service as it looks like a awkward job laying on your back.
2004 C4S
2003 C4S
 Filesize:  211.59 KB
 Viewed:  912 Time(s)
 Filesize:  213.79 KB
 Viewed:  912 Time(s)
shaunpr
2002 Porsche 996 Carrera 4
PostPosted: Wed Sep 13, 2017 9:52 pm    Post subject: Reply with quote
cant tell from your pictures where its coming from
mine was a bit more serious than yours.
First thing to check is you gearbox mount as this is the cause of it
http://911uk.com/viewtopic.php?t=121785
alex yates
PostPosted: Thu Sep 14, 2017 8:04 am    Post subject: Reply with quote
Reverse switch is weeping at a guess. Mine was (is it a manual?) in exactly the same place. About a tenner for a new switch and 20 minutes to swap over.
Used daily....rain, sun or snow.
