996 : 1997-2005 45
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 15
Cayenne : 2003- 8
Macan : 2014- 3
912-914-924-928-944-968 4
stubbsy
PostPosted: Fri Sep 08, 2017 6:59 pm    Post subject: 996 Turbo Engine Issues Reply with quote
Need some assistance got a bit of a weird issue with my engine that would appear hasn't been fully diagnosed when run through the diagnostics, so:
Last Saturday engine wouldn't start, called out breakdown recovery after the bloke played around with a few wires and managed to get it started.
heres where my issue started driving it home I tried opening it up momentarily (was in residential area so just tried a quick blast of full throttle) engine threatened to wind up, started feeling the power being delivered and boost kicking in then the engine done this weird jolt/shake where you could literally physically feel it.
Took it for another spin same thing again, so parked it on my drive and left it as I thought best not to drive it when it is not right, I called a recovery vehicle and took it to my local independent, so diagnostics on it was showing a boost value fault, new part ordered and fitted got the car back today.
just taken it for it first spin and still having exactly the same issue giving it full tilt on the throttle it starts kicking in and then getting the engine jolt/stutter with power being lost.
Really not sure what the issue could be as after the new part was fitted my indy informed me there were no faults displayed, they did take it for a test drive but I don't think they gave it full throttle otherwise they would have noticed you can't not.
in general It drives finel under light and medium acceleration, engine sound is ticking over as per normal, its just when I go to open it up it is not working right, any fellow turbo members have experience of this sort of issue or anyone else I can contact for a second opinion.
Help appreciated, thanks!
easternjets
PostPosted: Fri Sep 08, 2017 7:11 pm    Post subject: Reply with quote
Could it be one of the turbo actuators?
997 Turbo Gen 2
997 Turbo Tiptronic S
Porsche 968 Coupe 1992
Porsche 928 S4
Porsche 911 3.2 Carrera 1985
ragpicker
Paul Ricard
PostPosted: Fri Sep 08, 2017 7:14 pm    Post subject: Reply with quote
Need more info dude... Is it standard or modified? What boost do you get to before it starts spluttering? When it does splutter does it keep running or shut down completely? When were coils and plugs last changed? Have you made sure the waste gates are free and moving easily? What exhaust is on it?
If its a standard car and everything else being equal it could be something as simple as a coil pack or plug.
Other extreme it could be the ECU pulling the timing because of 'knock' caused by all sorts of variables.
996 turbo - slightly modified....
stubbsy
PostPosted: Fri Sep 08, 2017 7:30 pm    Post subject: Reply with quote
It's modified , I have a carnewal gt exhaust (basically a reworked standard exhaust) and it's had a remap, also got custom steering wheel with flappy paddles fitted that's all the notable mods.
Re splutter it keeps running but just a shake of the engine and loss of power then obviously i have to ease off and drive steadily continuing on my journey .
Not sure re coil and plugs it had a service about three months ago,
Waste gates what are they and how would I check that ?
easternjets
PostPosted: Fri Sep 08, 2017 7:34 pm    Post subject: Reply with quote
Yeah forgot about the coil packs, I changed mine and they were in a pretty poor state. Don't know what it's like to visually look at them on a 996 but on a 997 it's about an hours work. You will see straight away if they have started to swell/corrode and then split, the 4 furthest rear ones seemed to be the most susceptible.
Check your service book to see if the plugs have ever been done, it should be ticked if they have been. It's common for customers to leave them when they get a quote for the cost of changing them, around £700!
997 Turbo Gen 2
Porsche 928 S4
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Fri Sep 08, 2017 7:35 pm    Post subject: Reply with quote
I would get a code reader and check for codes. If that doesn't show anything get it to a well respected indy for a proper check. If somebody who doesn't know what they are doing tries things it could get very exoensive very quickly.
Dammit
PostPosted: Fri Sep 08, 2017 7:41 pm    Post subject: Reply with quote
Sounds like it's under fuelling for the boost it's making, if experience with my Volvo translates to the Porsch world at all.
911tom
PostPosted: Fri Sep 08, 2017 7:59 pm    Post subject: Reply with quote
If the code has come come back and is boost related then it could be maf, actuators or n75. The symptoms you describe sound more like coils and plugs. Could also be a bad batch of fuel, fuel pump, failing injector, blocked fuel filter. Start with getting the codes checked again. Then depending on what codes are there if any be logical with your next steps. Go for a long drive to burn the fuel then fill up with fresh vpower, obviously not from the same garage you used last time.
996 Turbo - Link to my 3.8L turbo build thread
2011 Cayenne
2009 Ariel Atom 3 Supercharged
350Bhp astra van for work Surprised
plynchy
PostPosted: Fri Sep 08, 2017 8:15 pm    Post subject: Reply with quote
I'd guess an actuator stuck causing over-boost, ECU detecting this and shutting off fuel.
Vaguely related but my Cossie did this many, many years ago. Wastegate actuator was goosed causing a similar problem when the boost wound up.
Hope you get sorted without too much hassle. thumbsup
'02 996 Turbo Manual Coupe Lapis/Grey. Unlimited grins.
stubbsy
PostPosted: Sat Sep 09, 2017 10:59 am    Post subject: Reply with quote
Thanks for the advice so far , sounds like a few things to check , as a few of you have mentioned Ecu issues potentially, I've disconnected the battery to see if that makes a difference as I guess once I drive it again the Ecu will have to re learn my driving style not sure if it will make a difference but thought it's worth a try .
I did take it to a well respected Indy however I'm trying to get a second opinion from the reputable links on here I've left a message for rpm and nine excellence to see if they can potentially shed any light on the potential issues /cause
stubbsy
PostPosted: Sat Sep 09, 2017 1:55 pm    Post subject: Reply with quote
So just taken it round the block same issues, I had the boost guage on and once it's get to 0.7/0.8 that's when the engine jolt happens , it fine below that just when you want to open it up fully, will get straight on phone to my indy on Monday to find out more , i spoke to him earlier and he said it drove fine on the test drive and was put back on the p wiss recorded no faults
Shanghai
PostPosted: Sat Sep 09, 2017 6:09 pm    Post subject: Reply with quote
You have 2 issues here ..
1/ it didnt start .. why ?
2/ you have a "stutter / holding back " on heavy acceleration / high boost .
On paper they would be seperate issues and may well be as i dont know what the recovery driver did .
But if you want to combine the two then its a fuel pressure issue .. ie the pump is not generateing high enough pressure at load to supply the fuel the engine needs and may well not have been working causing the non start .
Thats my 2 pennys anyways Smile
At an Indy these days !
DJones
PostPosted: Sat Sep 09, 2017 9:42 pm    Post subject: Reply with quote
I'd check the vario cam bracket the one that sits between the spark plugs on both banks.
2002 996 GT2 recreation in Nogaro blue
2013 Ferrari 458 Italia Nero black
2006 Ford GT40 Gulf Racing colours
1994 AC Cobra 427 Guardsman blue
cheshire911
Estoril
PostPosted: Sun Sep 10, 2017 12:19 am    Post subject: Reply with quote
I'd be inclined to carry out leak tests on the boost pressure points, check the waste gates and actuators, presume N75 valve is fine or has been replaced.
Next suspicion would be the remap and fuel issue highlighted by Demort.
I assume you have a new set of plugs and new coil packs all-round.
If you don't know when/if BOTH were changed, I'd change them to establish a new line in the sand.
996 2002 X50 Turbo Manual
shantybeater
PostPosted: Sun Sep 17, 2017 10:56 am    Post subject: Reply with quote
Could be car going into 'limp' mode? do you lose all boost after the event occurs?
2002 996 X50 Turbo
2004 E46 M3
2005 182 Sport
stubbsy
PostPosted: Tue Sep 19, 2017 6:40 am    Post subject: Reply with quote
It's difficult to say as your natural reaction once you feel the car doing that is to momentarily step off the accelerator , I haven't tried accelerating through it to see what happens
Dammit
PostPosted: Tue Sep 19, 2017 7:00 am    Post subject: Reply with quote
If it's a fuelling issue that is causing the observed symptoms then accelerating through it could melt a piston- so you are doing the right thing.
If it's fuel this should be showing in the fault codes though- suddenly running lean when boost passes a certain threshold.
stubbsy
PostPosted: Mon Sep 25, 2017 8:59 am    Post subject: Reply with quote
So finally some good news and hopefully the car should be back with me later today and ready to boost/start properly again!
Turns out the fuel pump is knackered and needs replacing which I don't know the ins and outs but I guess wasn't showing on the diagnostics as my Indy have spent a number of hours further investigating and test driving to no avail before locating the issue
Bit frustrating from my perspective as I have to ultimately pay for that investigation but glad it's fixed , to add to matters my front radiator has decided to go at the same time so my Indy have replaced that but its cost enough without the radiator could have done without that !
Will update later but all being well back to be able normal behaviour on boost will full acceleration being delivered !
Shanghai
PostPosted: Mon Sep 25, 2017 6:03 pm    Post subject: Reply with quote
Diagnosis isn't always easy and without a fault code it can be difficult to know where to start .
The fuel pressure system wont give a fault code as there no way the car can see whats going on .. no sensors are fitted to this system.
Lambda and fuel trim are long term diagnostics the car monitors which would be unlikely to register a fault with this type of problem .
To Test then you would either need it to not start which was your first fault but ok after that time ..
Or you would need to pressure test it , that would only be at idle so it would need 2 people to drive and monitor the fuel pressure at higher RPM .. hence the cost here i would think .
996ttalot
Approved Trader
PostPosted: Mon Sep 25, 2017 6:43 pm    Post subject: Reply with quote
it takes 5 minutes or less to check fuel pressure at idle - testing what it is on boost ( assuming the tech knows what the fuel pressure should do a certain levels of boost ) involves teeing off, running a fuel line through the slats in the rear spoiler and putting a gauge on the rear window with a tech sitting in the back seat reading it whilst driver is reading boost - a pretty crude method but works - a pump can be fine at idle but not making the correct pressure on boost. I highly doubt this was done as you cannot rig that in only two hours and test.
nineexcellence.com
Tel: 01293 226911. Follow us on Facebook www.facebook.com/Nineexcellence
SALES, SERVICE, UPGRADES
