997 : 2004- 77
Boxster : 1997- 18
Cayman : 2005- 18
markrnorton
PostPosted: Fri Sep 08, 2017 12:02 pm    Post subject: A refit to my 996 C4 - coilovers, big brakes, aero, paint Reply with quote
So here we go again.
Plan is to fit coilovers all round, GT3 front end , side skirts keep the ducktail and then get it painted.
first off a full set of coilovers to be fitted. I've done this before and everytime I try to strip down the existing suspension bolts appear to be fused into place ! Even the steering arm taper did not want to release today, some heat sorted it, but the taper 'holder' came away as well from the front hub ! grrr
and now the normally solid one, the pinch bolt at the bottom of the shock. nut comes away, but can I move the bolt, nope. wd40, nope, heat, hope. the last time I did this I had to drill it out.
before I go that far does anyone have a trick to releasing the bolt ? apart from extreme violence !
I'll post some pics of progress when I get some
996 C4 Tip S
986 S
955 Cayenne S
coullstar
PostPosted: Fri Sep 08, 2017 12:57 pm    Post subject: Reply with quote
Watching this as its what Im hoping to do if the right car comes up.
paul987
PostPosted: Fri Sep 08, 2017 3:21 pm    Post subject: Reply with quote
Good luck Thumb I know the pain of a rusty nut Surprised
A truly wise man never plays leapfrog with a Unicorn.
2001 996 C4S - Silver
2006 987 Boxster S 3.2 - Guards red
Marky911
PostPosted: Fri Sep 08, 2017 3:48 pm    Post subject: Reply with quote
Sounds great!
Subscribed. Pop Corn
APL911
PostPosted: Fri Sep 08, 2017 8:00 pm    Post subject: Reply with quote
Looking forward to seeing this. thumbsup
markrnorton
PostPosted: Fri Sep 08, 2017 8:19 pm    Post subject: Reply with quote
At least I've started with a clean workshop
right stripped both front sides down to a point but both strut pinch bolts at the bottom are seized
I guess I'm going to have to drill these out as usual
996 C4 Tip S
986 S
955 Cayenne S
 Filesize:  1.58 MB
 Viewed:  7681 Time(s)
 Filesize:  1.42 MB
 Viewed:  7682 Time(s)
markrnorton
PostPosted: Mon Oct 02, 2017 10:06 am    Post subject: Reply with quote
Its been a while since my last post. However I have now got down to removing/fitting the suspension.
report so far...
I managed to buy a BC set of coilovers very cheaply, so I thought I'd test them out. If they are good or not at least it gives me a chance to check the stance !
First impressions of the units are they are pretty well made. To a budget but you get what you pay for I guess. threads for the drop links on the rear needed re-tapping as they had been painted, but that's not too much of an issue.
springs are not 2.25" , slightly bigger. rears ok, and come with an alloy top platform and bearing, the fronts do not, but I'm changing them for adjustable bearing type top mount and 2.25" springs too.
both front and rears have adjustable spring platforms and adjustable ride height (separate). I've dropped the rears to minimum and fitted. not sure where it will sit yet. needless to say I am copperslipping all bots and fittings so in future it will come apart !
pictures to follow later
996 C4 Tip S
986 S
955 Cayenne S
Sundayjumper
1999 Porsche 996 Carrera 2
PostPosted: Mon Oct 02, 2017 11:35 am    Post subject: Re: A refit to my 996 C4 - new suspension, aero kit and pain Reply with quote
I paid my Tuna to do it. It took them a couple of hours of extreme violence, but that was better than ruining an entire weekend trying to do it myself !
Since then, if I'm under the car doing other stuff, I try and remember to whip them out every now and then and give them a quick clean to make sure they don't seize up again.
markrnorton
PostPosted: Mon Oct 02, 2017 5:28 pm    Post subject: Reply with quote
Near side rear now in
996 C4 Tip S
986 S
955 Cayenne S
 Filesize:  1.49 MB
 Viewed:  7151 Time(s)
markrnorton
PostPosted: Mon Oct 02, 2017 5:29 pm    Post subject: Reply with quote
I've also stripped out the offside rear now. Different seized bits, but still came out with wd40 and some cutting !
drop links always seem to seize on the bolts
996 C4 Tip S
986 S
955 Cayenne S
Marky911
PostPosted: Wed Oct 04, 2017 12:26 pm    Post subject: Reply with quote
Good work Mark! Thumb
Everything seizes on the buggers doesn't it. Doesn't matter if it's M6 or M14.
Good work. I bet you dirty some of your carpet tiles though. Grin
markrnorton
PostPosted: Thu Oct 05, 2017 6:44 am    Post subject: Reply with quote
you're right on both counts, seizing up and carpet. had to get the vacuum out for a clean.
both rears on and car dropped to the ground. its low, very low !
on another note, just waiting for the new front springs to arrive.
when did spring rates change from lbs/in to kgs/mm, what a pain doing conversions ! things used to be simple.
996 C4 Tip S
986 S
955 Cayenne S
paul987
PostPosted: Thu Oct 05, 2017 8:14 am    Post subject: Reply with quote
Good work Thumb +1 on every fastener on a 996 is always siezed frustrated
I'm looking forwards to hearing your thoughts on your coilovers.. It's something I'm going to need to attempt myself in the future.. I'm just not sure which brand to go with. Question
1+ on the I'm sure it didn't used to be this much hassle too Laughing
markrnorton
PostPosted: Thu Oct 05, 2017 6:32 pm    Post subject: Reply with quote
Ok rant time
When I ordered the rear drop links , I was sent front ones !
What is wrong with people? But I have been sent the correct ones now
But..
Now today waiting for my 2 new front springs , 275lbs, to be delivered and hey presto what comes through my door. 2 new springs, however one is rates at 325 and the other 500lbs! So not even a pair
Is it me or are people becoming that slap dash they will sent out anything?
Not even a matched pair? What would you do with them?
Arghhhh
996 C4 Tip S
986 S
955 Cayenne S
markrnorton
PostPosted: Sat Oct 07, 2017 7:12 pm    Post subject: Reply with quote
Ok
Update
On the left the standard way the BC coilover comes delivered
On the right I have updated it with 2.25 coil and new spring top platform
Still waiting on the rose joint top mounts as I don’t want to use the old nasty existing ones
996 C4 Tip S
986 S
955 Cayenne S
 Filesize:  1.55 MB
 Viewed:  6663 Time(s)
markrnorton
PostPosted: Sun Oct 08, 2017 7:27 pm    Post subject: Reply with quote
Just as an add to the above the spring caps come in a variety of style and hole sizes. I bought the 10mm hole type and drilled them out to suit the new shock.
996 C4 Tip S
986 S
955 Cayenne S
 Filesize:  777.41 KB
 Viewed:  6543 Time(s)
 Filesize:  1.28 MB
markrnorton
PostPosted: Sun Oct 08, 2017 7:29 pm    Post subject: Reply with quote
This is a shot of the rear lowered to the floor
Not settled yet so I expect a little more drop
You get the idea though
996 C4 Tip S
986 S
955 Cayenne S
 Filesize:  890.08 KB
 Viewed:  6542 Time(s)
rhino-man
PostPosted: Sun Oct 08, 2017 7:39 pm    Post subject: Reply with quote
Nice!
2010 997.2 C4S
2001 996 C2 Convertible
PeterS
2003 Porsche 996 Carrera 2
PostPosted: Mon Oct 09, 2017 5:36 am    Post subject: Reply with quote
Nice stuff, good to see 996s getting some love.
Have you got the GT3 aerokit front bumper yet?
markrnorton
PostPosted: Mon Oct 09, 2017 6:37 pm    Post subject: Reply with quote
Yes got the front end and side skirts
Had them about 3 years
Still waiting for the new top mounts, very slow ebayer
Bought another set of front springs at a higher rate in case it needs beefing up!
996 C4 Tip S
986 S
955 Cayenne S
Goto page 1, 2, 3, 4, 5  Next
Page 1 of 5
