996 : 1997-2005 48
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 14
Cayenne : 2003- 8
Macan : 2014- 3
912-914-924-928-944-968 4
Nattyboy
PostPosted: Thu Sep 07, 2017 12:34 pm    Post subject: Carbon fibre mirror triangles 997 boxster cayman Reply with quote
Brand new unused Euro cup GT carbon mirror triangles. For 997 and 987 boxster/Cayman gen2 models (2004-2012)
£85
2010 987 Spyder (replacing 997 C4S Aero kit)
2006 BMW X3 M Sport
2010 Fiat 500C
 Filesize:  1.67 MB
 Viewed:  1310 Time(s)
Nattyboy
PostPosted: Thu Sep 07, 2017 12:35 pm    Post subject: Reply with quote
Illustration of fitted parts (these are new and unused).
2006 BMW X3 M Sport
2010 Fiat 500C
 Filesize:  1.34 MB
 Viewed:  1307 Time(s)
Stuart Mackay
PostPosted: Thu Sep 07, 2017 9:54 pm    Post subject: Reply with quote
I ll take them please
2007 Speed Yellow 997 Carrera GT3 CS
2002 Guards Red Aerokit 996.2 C4S Cabriolet
2000 Westfield Cosworth
Nattyboy
PostPosted: Fri Sep 08, 2017 12:12 pm    Post subject: Reply with quote
Now sold
2006 BMW X3 M Sport
2010 Fiat 500C
Stuart Mackay
PostPosted: Sun Sep 10, 2017 8:03 pm    Post subject: Reply with quote
Thanks Nat, all fitted and looking good!
Nattyboy
PostPosted: Mon Sep 11, 2017 7:05 am    Post subject: Reply with quote
You're welcome mate !
2006 BMW X3 M Sport
2010 Fiat 500C
The return of Marty Wild
PostPosted: Mon Sep 11, 2017 7:36 am    Post subject: Reply with quote
How hard were they to fit?
Cayman S 987.1
Stuart Mackay
PostPosted: Mon Sep 11, 2017 8:52 am    Post subject: Reply with quote
You need to remove both mirror assemblies from car, Torx screws on inside behind inner triangle.
The mirror and casing need to be disassembled. Single screw on lower mirror body and be careful you dont break the moulded tabs on the plastic casings.
The mirror arm is fixed to the outer triangle with 3 small T8 Torx self tappers.
Remove the rubber gasket and you should be able to remove the mirror mechanics from the triangle by squeezing the arms gently.
Assembly is a reverse of the above. Fit the gasket after you have the mechanics through the triangle.
The small Torx self tappers were too small for the Carbon triangles, so either fill with epoxy or use a piece of cocktail stick inserted into hol;e in C/F part to give the retaining screws something to bite onto.
Nicely moulded and a massive weight saving puh puh
 Filesize:  577.83 KB
 Viewed:  1066 Time(s)
PostPosted: Mon Sep 11, 2017 10:01 am    Post subject: Reply with quote
Doesn't sound too complicated apart from that last bit you mentioned. Does look cool, I am thinking of a splash of exterior CF on my motor.
Cayman S 987.1
