964 : 1989-1993 5
Boxster : 1997- 18
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
deutschland-dobson
PostPosted: Wed Aug 30, 2017 6:19 pm    Post subject: Jobs while engine is out Reply with quote
Hi gang,
I'm preparing for the engine on the '64 coming out in the new year, to sort a leak to the chain housing on the crank case. It's in for major service at the same time to combine the labour.
While the engine's out, can anyone recommend some jobs that should be done with the resulting improved access?
Chris
Porsche 911 (964) C4 - Project RED - Outlaw4
Guards Red & Linen, Custom Leather, BBS LM Split-rims, H&R Coilovers, Cleaned Bodywork, 90s audio instal...
ras62
PostPosted: Thu Aug 31, 2017 10:55 am    Post subject: Reply with quote
Oil breather gasket, Oil sender O ring, Intermediate shafe O ring, Crank nose seal, Timing chain dounut seals and gaskets. Highly likely the camshaft triangle gasket and associated O rings are shot but this requires retiming the cams. Check inlet stacks for cracks and replace stack bottom seals. New valve cover gaskets. Check clutch and flywheel condition, any oil in there means rear main seal or gearbox input seal. Thumb
Oh and renew the engine sound deadening pad.
deutschland-dobson
PostPosted: Thu Aug 31, 2017 12:22 pm    Post subject: Reply with quote
Thanks for the list, that's great!
Forgot to mention the '64 had a re-build about 10K miles ago, but will certainly check the above Smile
Im also going to paint and refurb a few bits as I go.
Chris
Porschekit
PostPosted: Thu Aug 31, 2017 12:45 pm    Post subject: Reply with quote
Chris, don't forget to bring it out and drive it for a while before you do 'more' work to it...... Grin The next NE run is........who's organising? come on boys the sun won't last forever...me and KeithP are the die hards so far this year...
997.1 C4S Meteor Grey Metalic
deutschland-dobson
PostPosted: Thu Aug 31, 2017 12:52 pm    Post subject: Reply with quote
Ill keep my eyes pealed Surprised
Even if the car is in bits i'll just blag a lift and catch up over tea and cake!
Chris thumbsup
backitoff
PostPosted: Tue Sep 19, 2017 9:42 am    Post subject: Reply with quote
I have just done this with my car.
Don't forget;
Power steering pump seals and belt
Exhaust studs and gaskets
New alloy washers on oil pipe fixings
May need to replace some engine tins.
HT lead clips
RMS and front worth changing whilst it's out.
Consider alternator and starter motor overhaul(Starters' a bitch to do when back in). Ask me how I know.
Replace clutch slave and flexi.
Overhaul clutch fork shaft.
Consider engine and gearbox mounts.
Driveshaft gaiters.
Check metal fuel pipes going to engine bay for corrosion.
Also metal brake pipes. (There is one that goes over the gearbox/ trans tunnel that cannot be replaced with gearbox in situ).
I replaced my clutch slave with an MPL unit and extended the bleed nipple down the side of the box for ease of access.
Previous to current.......
993 C4 Coupe - 996TT Coupe - 3.2 Carrera Sport - 964 C2 Coupe.
Wish list.... 997 GT3 comfort spec.
deutschland-dobson
PostPosted: Tue Sep 19, 2017 12:42 pm    Post subject: Reply with quote
Thanks for the useful comments bud Smile
A few are already taken care of, but loads more to do!
Thanks thumbsup
Chris
PeterS
2003 Porsche 996 Carrera 2
PostPosted: Tue Sep 19, 2017 3:55 pm    Post subject: Reply with quote
Take the deadening pad out and chuck it away. Loads more room to tinker then, and the engine sounds much better in the cabin.
Just a chance to give everywhere a really good clean.
deutschland-dobson
PostPosted: Tue Sep 19, 2017 3:56 pm    Post subject: Reply with quote
Thought about it, then decided to take a Singer twist...
Chris Very Happy
Ghengis
PostPosted: Fri Nov 17, 2017 10:37 pm    Post subject: Re: Jobs while engine is out Reply with quote
deutschland-dobson wrote:
Hi gang,
Chris
Me too!
1990 911 C4 in Guards Red with black leather. Tweeked and fettled ready for the summer.
deutschland-dobson
PostPosted: Sat Nov 18, 2017 12:29 pm    Post subject: Re: Jobs while engine is out Reply with quote
Hi gang,
Chris
Me too!
Engine rebuild time Thomas? Who’s doing the work bud?
Chris
Ghengis
PostPosted: Fri Dec 08, 2017 8:23 pm    Post subject: Re: Jobs while engine is out Reply with quote
Hi gang,
Chris
Me too!
Chris
It's in with D&G Chris. They are doing a full rebuild.
