997 : 2004- 74
996 : 1997-2005 42
993 : 1993-1998 8
964 : 1989-1993 6
Classic : 1950-1965 1
Boxster : 1997- 10
Cayenne : 2003- 7
peterzoom
2001 Porsche 996 Carrera 4
PostPosted: Wed Aug 30, 2017 1:57 pm    Post subject: 996 Carrera 4 (2001) Dual mass flywheel and clutch kit Reply with quote
Part used dual mass flywheel, pressure plate, friction plate, release bearing, release arm, pin and seal.
Removed today in full working order having covered less than 18,000 miles, so less than 30% worn!
All parts are Sachs or original Porsche, definitely top quality.
If I were reusing this unit I would perhaps use a new release bearing as they are only plastic and probably the only weak link even when new.
Images available on request.
The reason it was changed was for the fitting of a lightened and balanced single mass flywheel, so I took the opportunity to replace everything else while we had the 'box out.
£175 plus delivery at cost.
