997 : 2004- 74
996 : 1997-2005 42
993 : 1993-1998 8
964 : 1989-1993 6
Classic : 1950-1965 1
Boxster : 1997- 10
Cayenne : 2003- 7
dissolved
PostPosted: Tue Aug 29, 2017 10:15 am    Post subject: Locking wheel nut key Reply with quote
Picked up a puncture at the weekend, no big deal but when I got it to the shop for investigation it turned out the locking wheel nut key was threaded. Some moron had obviously used it with a pneumatic gun Mad
So that was that, had to get the tyre pumped up & back to my mates, only a few mins up the road from the shop but 40 miles from where I live.
Annoying but no great shakes, just need to get a replacement wheel nut key, head back later this week & so on.
Ringing Porsche today, I had to call 4 different centres to find one that had the right key in stock. The fact Porsche don't just take on that responsibility itself is crap, but worse I didn't have to provide any proof that I owned the car before they took payment & shipped one out to arrive tomorrow. Nothing at all.
So basically if I was nefariously inclined I could call a number of centres, get all the variation of keys required & I'd be able to just help myself to wheels etc Mad
Demort
Estoril
PostPosted: Tue Aug 29, 2017 6:55 pm    Post subject: Reply with quote
Things must have changed since i was at OPC as in those days we had no record of what wheel nuts where fitted to a car .. all we could do was use a master set then try everyone untill we found the correct one to get the number .
That was 3 years ago.
At that point it was ordered as none of them were kept in stock.
If you have the key number then i would expect your local center if you had used them before would know you owned the car by the address and wouldn,t ask for more proffe .. you would usually be asked for a V5 if they didnt know you for anything security .
You may well have one of the set i refer to as Monkey metal .. it was a cheap 2 part socket that comes appart leaveing very little to lock into the nut and oftem sliped and damaged the key .
You can with this type hammer the 2 parts back together .
It will be somewhat different if you want the IPAS codes though .. the security numbers for your car .. youll be on your knees begging with every bit of paper you have before they will even Think of giving you THAT info !
At an Indy these days !
