997 : 2004- 64
paul987
PostPosted: Thu Sep 07, 2017 5:30 pm    Post subject: Reply with quote
Evening gents... OK so now I've sorted the coffin arms and track rods... I can finally continue with the brake lines.... Confused
I have replaced the hard line on the calipers.. I have also bought some shiny new Goodridge hoses to replace the old rubber lines... BUT.. There's a slight problem with the nut being rusted solid on the no.9 hard line.. wack I have bought a 11mm flare nut spanner it seems slightly too big.. I have bought a 10mm flare nut spanner it's too small.. so it needs a 10.5mm Question Dont know I suspect it's imperial.
So has anyone got any ideas Question I really don't want to replace the no. 9 line.. so my thoughts are... if I cut the nut off what and used a pipe cutter to chop the flange off... Embarassed I could then put a new male nut on the old line then reflange it Question
Is there any obvious flaws in my theory? ?
A truly wise man never plays leapfrog with a Unicorn.
2001 996 C4S - Silver
2006 987 Boxster S 3.2 - Guards red
PostPosted: Thu Sep 07, 2017 6:03 pm    Post subject: Reply with quote
Ive been keeping my eye on this thread as i did wonder if all the lines would come undone .
Its either a 10 or 11 mm as there is no imperial anything on Porsches and there is no 10.5 .. it should be an 11 which has corroded .
Your choices ..
Replace No.9 ..
Do a cut and join on No.9 .. i dont recomend that ..
Use mole grips on the corroded nut and either a spanner or more mole grips on the flexi pipe .. youll need to force it out of the bracket or at least far enough so it can be turned as the bracket locates the flexi pipe ... and whilst holding the metal pipe ( no.9 ) in place you will undo and twist off the flexi pipe .
Its important not to allow the metal pipe to twist .. it wants to be held ridgid as too much twist will fracture it .
Your kinda doing the job backwards basically .
You could cut the nut and re flair but if its steel pipes then i wish you the very best of luck there and if not it may well be too short to reach the pipe ... i think go down this route if my above suggestion doesnt work Smile
paul987
PostPosted: Thu Sep 07, 2017 8:46 pm    Post subject: Reply with quote
Your choices ..
Replace No.9 ..
Thanks Demort
The double mole grips method is getting my vote Thumb The rest of the no.9 pipe is in good condition.
But one question.... will the old nut be reusable if I get it off with the mole grips? Basically will I be able to use the mole grips or spanner to tighten it to the new flexible hose? Or will no.9 pipe need to be replaced?
wasz
1999 Porsche 996 Carrera 2
PostPosted: Thu Sep 07, 2017 9:01 pm    Post subject: Reply with quote
I had this problem.
But my brake lines were looking a bit manky, especially up above the steering rack where you can't normally see them.
So I replaced them with cunifer back to the pump.
PostPosted: Fri Sep 08, 2017 6:09 pm    Post subject: Reply with quote
If you use mole grips then you remove the flexi from the metal pipe and refit it the same way .. it wont be pretty but then it isnt now due to the corrosion.
You could use something else rather than mole grips if you want as thats just an example. .. there are pliers out there with plastic jaws .
The best way is obviously to replace all the pipes needed but this was an unexpected failure and so a quicker repair for now is IMHO fine .
If it doesnt work then you are left with replacing no.9 .. i think reflairing might be a problem .
Lets face it if it dont leak then theres nothing wrong with it , i dont condem things because they are ugly Very Happy
Anyways you got my number if you need it !
ragpicker
Reims
PostPosted: Fri Sep 08, 2017 7:06 pm    Post subject: Reply with quote
I usually heat them up with a blow torch, the crud falls off them and they unseize too. Sometimes you get the brake fluid catching fire as it drips out which is always interesting.
Another favourite trick is when the flexi pipe is siezed into the calliper and you heat the calliper so much the flexi blows off and makes a sound like a gunshot.
Neither of the above are the best way to do the job by the way.... I hadn't thought of the double mole grip method Embarassed
996 turbo - FOR SALE, Price reduced: http://911uk.com/viewtopic.php?t=131025&highlight=
diverzeusy
PostPosted: Fri Sep 08, 2017 7:45 pm    Post subject: Reply with quote
cunifer/copper comparison, just so you can identify what you are buying, copper is the bottom one and as mentioned, it is about the same colour as a 2p coin Thumb
 Filesize:  349.73 KB
 Viewed:  2602 Time(s)
paul987
PostPosted: Fri Sep 08, 2017 9:33 pm    Post subject: Reply with quote
Cheers Demort your a good un Thumb
paul987
PostPosted: Fri Sep 08, 2017 9:37 pm    Post subject: Reply with quote
Cheers Ragpicker your a good un too... But also a slightly dangerous un.. Laughing Thumb
paul987
PostPosted: Fri Sep 08, 2017 9:52 pm    Post subject: Reply with quote
Thanks diverzeusy Thumb I have just explained to my wife how someone had posted about spotting cunifer by its colour.. she's just said "conifers are always green they don't turn copper" eh!
I do wonder obout her sometimes Dont know
mr gill
PostPosted: Sat Sep 09, 2017 2:14 am    Post subject: Reply with quote
Kunifer can look indistinguishable from copper, the nickel content can range from over 93% down to 68% depending which alloy grade is used...
2007 Audi R8 V8
2007 BMW 320d M Sport
2004 996 C4S X73 and Aerokitted - Gone
2007 Alfa 159 sportwagon 1.9jtdm decat, dpf/egr delete - Gone
Gone but not forgotten 2002 E46 M3
7 more 3 series BMW.... (yes I like them!)
X51 996
PostPosted: Sat Sep 09, 2017 12:40 pm    Post subject: Reply with quote
Are you sure that's correct? Smile
I thought Cunifer/Kunifer was mainly copper, with a little nickel etc added not the other way round - ie circa 90% copper not mainly nickel.
The finish may vary slightly but generally copper coloured just a little lighter (bronzey/gold) Thumb
2003 911 Carrera 2 coupé, Arctic Silver - 3.6 manual, X51 Carrera PowerKit, X74 Suspension, Sunroof delete, PSM delete. Black leather crested sports seats (XSC), XAG rear spoiler, 5-spoke 18" Carrera Alloys, Xenons.
2011 Mercedes E63 AMG Wagon
2004 Mercedes E55K AMG Wagon
1988 Mercedes 190E 2.3-16
1988 Mercedes 190E 2.5-16
PostPosted: Sat Sep 09, 2017 6:03 pm    Post subject: Reply with quote
Thats one thing we would do at work .. i wont say we know what we are doing Razz but we do have plenty of fire extinguishers Very Happy
mr gill
PostPosted: Tue Sep 12, 2017 12:35 am    Post subject: Reply with quote
Oops yes, thats what i meant to say, i wrote nickel instead of copper!
2007 Audi R8 V8
diverzeusy
PostPosted: Wed Sep 13, 2017 7:47 am    Post subject: Reply with quote
Please please just look at my picture of the two, side by side in the picture I posted earlier in the thread. It is very clear how they look, frustrated
Now back to making brake pipes up Smile
paul987
PostPosted: Thu Sep 14, 2017 7:33 pm    Post subject: Reply with quote
OK so I finally got it sorted today Dance Tap
I tried a few days ago with no joy at all.. one of the molegrips I was using was crap and had way to much play in them.... so bought another better quality pair of molegrips...
2 secs it was off... nut and line salvaged by twisting the flexible line end (as recommended by Demort, I thank you sir)
Thanks for everyone's imput Thumb
uk996
PostPosted: Mon Oct 28, 2019 12:34 pm    Post subject: Reply with quote
I'm raising this thread from the forum depths.
Can any one tell me which fittings are used on the 996 brakes?
Type and size? 10mm with 1mm threads springs to mind.
Want to replace the little hardlines, the ones that connect to the caliper.
Also what diameter alloy/ cunifer pipes ?
Any one point me to a nice kit with a mini pipe bender?
Many thanks.
2002 996tt Aero in seal grey 6MT
skinny_monkey
PostPosted: Mon Oct 28, 2019 4:16 pm    Post subject: Reply with quote
unless you're really keen to do it yourself, they are (or at least were) less than a fiver each from OPC.
uk996
PostPosted: Mon Oct 28, 2019 4:18 pm    Post subject: Reply with quote
5 English Pounds ?? Surely not ?
It's a Pooorsha, must be at least 100 English pfunds each!
Any one got the part numbers handy ?
Many thanks.
uk996
PostPosted: Mon Oct 28, 2019 4:29 pm    Post subject: Reply with quote
Porsche Brooklands as of 28/10/19
- front £15.38 each
- rear £11.78 each
Page 2 of 3
