997 : 2004- 63
Cayman : 2005- 22
Macan : 2014- 7
paul987
PostPosted: Fri Aug 25, 2017 4:23 pm    Post subject: Brake lines Reply with quote
I was just replacing my caliper afierce fitting new discs... and errrm I it fell off... Sad the metal line snapped.. it was heavily corroded so I would have needed to replace soon anyway.. but I wasn't planning on doing it now.. Sad
So.. has anyone bought any brake lines recently? Where's the best place to buy them?
A truly wise man never plays leapfrog with a Unicorn.
2001 996 C4S - Silver
2006 987 Boxster S 3.2 - Guards red
ragpicker
Reims
PostPosted: Fri Aug 25, 2017 4:59 pm    Post subject: Reply with quote
Dead easy to make your own and will cost you pennies. Have a look in my boxster thread in my sig, i'm sure I make some in that.
Anyway, any motor factors will sell you 10m of copper brake line, a bunch of ferrules and a tool to flare the edges. I quite like making brake lines actually.. I just stand there daydreaming whilst doing it...
996 turbo - FOR SALE, Price reduced: http://911uk.com/viewtopic.php?t=131025&highlight=
paul987
PostPosted: Fri Aug 25, 2017 5:58 pm    Post subject: Reply with quote
Thanks Ragpicker
I do seem to remember seeing you making some on your Boxster thread.. I shall indeed look into it.. I think I may need to concentrate whilst doing it Laughing Thumb
PostPosted: Fri Aug 25, 2017 6:32 pm    Post subject: Reply with quote
+1 on Rag's solution.
G3BML
PostPosted: Fri Aug 25, 2017 7:07 pm    Post subject: Reply with quote
Is it the hard lines on the body or the short line from the flexi to caliper? If it's the short one, you can by these pre made from OPC or Design911. Only cost 20 quid tops
2003 Guards Red 996 Carrera 4S
paul987
PostPosted: Fri Aug 25, 2017 7:25 pm    Post subject: Reply with quote
It's it enables no. 7 on this Thumb
 Filesize:  12.83 KB
 Viewed:  4375 Time(s)
Jamesx19
PostPosted: Fri Aug 25, 2017 7:52 pm    Post subject: Reply with quote
Cunifer......... Corrosion proof, not as soft (hence harder to form curves etc) as copper. Though better than copper as that does corrode too. Looks better quality than copper as well I think.
1998 C2 Manual + The Full Hartech.
ragpicker
Reims
PostPosted: Fri Aug 25, 2017 8:10 pm    Post subject: Reply with quote
Do you want me to make you one and send it to you?
Jamesyg
PostPosted: Fri Aug 25, 2017 8:30 pm    Post subject: Reply with quote
Did mine last week... cost me about £15 the pair. Make sure you buy a flare spanner for removing old lines /fixing new. Will save you rounding nuts!
‘84 73 RS Recreation
‘83 911 SC
‘79 1500 MG Midget
paul987
PostPosted: Fri Aug 25, 2017 8:56 pm    Post subject: Reply with quote
Cunifer, I've not heard of that before... Question sounds a bit offensive Laughing
paul987
PostPosted: Fri Aug 25, 2017 9:10 pm    Post subject: Reply with quote
Ragpicker that is very very generous of you.. thumbsup alas I've just ordered a pair of them online about 20mins ago..
Because it's my daily I chickened out on the diy front... but I do plan to use the approach on various other pipes when I'm not so limited on time Embarassed
paul987
PostPosted: Fri Aug 25, 2017 9:17 pm    Post subject: Reply with quote
Yes I was surprised how cheap they were... unlike a lot of the other pipes.. flare spanner I've been reading about them and was pleasantly surprised halfords sell them for about a fiver Thumb
Jamesyg
PostPosted: Sun Aug 27, 2017 5:53 am    Post subject: Reply with quote
Nice one mate, hopefully all went well! I also purchased a sealey brake / clutch bleeder. Amazing piece of kit!!
‘83 911 SC
‘79 1500 MG Midget
paul987
PostPosted: Sun Aug 27, 2017 12:59 pm    Post subject: Reply with quote
Sadly my parts haven't arrived yet.. Bank holiday post I guess. So I'm sat twiddling my thumbs..
I have seen the sealey brake bleeder I think I'm going to get one.. they do look very good Thumb
paul987
PostPosted: Mon Aug 28, 2017 11:25 pm    Post subject: Reply with quote
I've been looking into this Cunifer stuff.. it looks really good and not that expensive neither Thumb
maldren
PostPosted: Tue Aug 29, 2017 6:41 am    Post subject: Reply with quote
+1 on Kunifer, it's been around for years (I used it on a Viva in the 1970s) and has great reputation.
Mike
wasz
1999 Porsche 996 Carrera 2
PostPosted: Tue Aug 29, 2017 3:52 pm    Post subject: Reply with quote
you'd be hard pressed to find any actual copper brake line anymore.
They have been cunifer for decades. Just most people still call them "copper".
maldren
PostPosted: Wed Aug 30, 2017 7:28 am    Post subject: Reply with quote
Not sure that's actually correct, my Elan +2 has copper pipes fitted by a PO, they're very different in colour from Kunifer.
Kunifer is a silver/green colour whereas Copper is, well copper coloured like a 2p coin!
Mike
wasz
PostPosted: Wed Aug 30, 2017 11:47 am    Post subject: Reply with quote
Maybe true of your car, but its not good practice to use plain copper and hasn't been for a long time.
Copper work-hardens from vibrations and pressure cycling.
Exacerbated if not clipped up properly or ill fitting. I.e. you likely need more clips for a copper line than typically used on a steel factory line.
Apparently copper brake lines aren't legal in the USA, Canada or Australia.
Copper-nickel or cunifer brand is what you want.
X51 996
PostPosted: Wed Aug 30, 2017 12:01 pm    Post subject: Reply with quote
Pretty sure Kunifer isn't silver/green, it's mainly copper with nickel/iron added AFAIK. Thought it was like copper just a little lighter e.g. bronzey/gold rather than pure copper coloured.
I thought the silver/green was usually steel pipe with a coating on it?
2003 911 Carrera 2 coupé, Arctic Silver - 3.6 manual, X51 Carrera PowerKit, X74 Suspension, Sunroof delete, PSM delete. Black leather crested sports seats (XSC), XAG rear spoiler, 5-spoke 18" Carrera Alloys, Xenons.
2011 Mercedes E63 AMG Wagon
2004 Mercedes E55K AMG Wagon
1988 Mercedes 190E 2.3-16
1988 Mercedes 190E 2.5-16
Goto page 1, 2, 3  Next
Page 1 of 3
